I have 2 problems that I need help with, first of all I am running windows 7 ultimate 32bit, explorer 9, and everything on my pc is all updated and checked for viruses, addware, spyware, malware, root kits, everything is all clear. okay 1st problem: windows media player 12 just quit working, how do I un-install it so that I can re-install it. 2nd problem: I have to have ctrl-alt-del/ task manager running in the background at all times for my pc to function at all, if its not running in the background nothing will work. nothing is clickable without it running in the background. I have searched all over the net and all kinds of fourms and can't find a solution for my problem, so I am really hoping that you can and will help me please. thank you very much and thank you for your time. Daniel T. Crocker
