you change settings like cmd rate etc via the bios.
We really need to see a dmp file as the information contained allows us to diagnose your system at the time of said bsod. Are you running with a pagefile? Also did you follow Ickymays post just below the main thread opener? I'll re-iterate just in case:
Open control panel, click on 'System and security' followed by 'System'. On the left you'll see 'Advanced system settings', click that. You'll then see a new dialogue box open, click 'Settings' under 'Start up and Recovery' and make sure that under 'write debugging information', 'Small memory dump (256kb)' is selected from the drop down menu. In the box marked 'Small dump directory' make sure it say's this: %SystemRoot%\Minidump...
