Windows 7 help whit soundmax mother m2n sli deluxe
willyangerosa
Hello. I wanted to know which driver should I install to m2n sli deluxe motherboard. some versions that I had no problem, my pc crashes, please pass me a driver that works
Well they look like the driver that should be used. When you get a crash is it an actual blue screen? If so, post the dump file and I'll read it for you. Another suggestion would be to check your event logs.
directly goes slow, then reboot and load the start up repair, then that solves the problem, when restarted, the soundmax disappeared. no blue screen
Top Bottom
