help! win 7 stuck at shutdown screen
hey guys,
I'm new here and having problems with my girlfriends laptop. it's a Toshiba Satellite A505-S6005, only a few months old. Recently, within the past 2 days, it's been giving trouble with shutting down or restarting... in other words.... it won't. only way seems to be to hold down the power button. It shuts down fine in safe mode with network. Even no apps running still does it. could it be one of the processes, in task manager. i tried defaulting the power mode and somewhere even said to turn off the fax through windows features and still nothing. seeing as it's relatively new, i would assume all the drivers are up to date. stressin' out here... :(
zvit
Honorable Member
If it restarts fine from Safe Mode, that means that something you installed or did in the past 2 days is the cause. It could be a new firewall or AV you installed or even something as simple as a new game.
So do a restore to at least 3 days ago and that should solve it.
Tell us how it went.
Saltgrass
Check the event viewer to see if any error or warning messages show up around the actual time the errors or problems occur.
where do you find the restore option under. i did it once on a xp and ended up clearing the whole laptop.
Trouble
Noob Whisperer
kyle2blue:
Hello and welcome to the forum
In your original post you asked "could it be one of the processes, in task manager"
Yes, it could be a process or service and Captain Jack's link to the selective startup instructions will help you chase it down. There is also an additional link to clean booting Windows 7 which may help here http://support.microsoft.com/kb/929135/
but if you still want to try a system restore
Click the start orb, right click computer, choose properties, select the System Protection tab at the top, then the system restore button, and check the box that says show more restore points if needed.
#7
woohoo! system restore worked. thanks guys.
#8
I have a Dell Studio 14z and ever since upgrading to Windows 7 from Vista we have had nothing but issues with the unit. Recently, we have started to experience shutdown issues along with periodically it freezes for 2-5 minutes and then continues on. I would like to first resolve the shutdown issues so I am attaching the minidump zip file as suggested in other posts. Thanks for any help you can provide.
Captain Jack
#9
Hello MISSupport ! Welcome to Windows7 Support Forums !
We will be glad to help you but please create a new thread and post your request there it will be less confusing for us.
Thanks,
Captain
zigzag3143
Honorable Member
Microsoft MVP
#10
These were all caused by a priver power state issue. I suspect from one of the outdated drivers on you system.
Old drivers nneding update
CVirtA.sys        0xa1bd4000    0xa1bd5460    0x00001460    0x45afd851    1/18/2007 16:28:01
dne2000.sys        0x96ae3000    0x96b00b80    0x0001db80    0x45b70804    1/24/2007 03:17:24
CVPNDRVA.sys        0x9f344000    0x9f3d4000    0x00090000    0x4612ee83    4/3/2007 20:17:07
RtNdPt60.sys        0x96823000    0x9682f000    0x0000c000    0x475dfaea    12/10/2007 22:50:18
Apfiltr.sys        0x8f722000    0x8f757000    0x00035000    0x49d4f7d2    4/2/2009 13:37:22
btwl2cap.sys        0xa1b19000    0xa1b24000    0x0000b000    0x49d6a9b3    4/3/2009 20:28:35
nvsmu.sys        0x8f764000    0x8f76d000    0x00009000    0x49f27e67    4/24/2009 23:07:19
dump_nvstor32.sys        0x97f13000    0x97f49000    0x00036000    0x49f90477    4/29/2009 21:52:55
nvstor32.sys        0x833b2000    0x833e8000    0x00036000    0x49f90477    4/29/2009 21:52:55
nvhda32v.sys        0x97edf000    0x97ef2000    0x00013000    0x49fa7de0    5/1/2009 00:43:12
spldr.sys        0x8ae00000    0x8ae08000    0x00008000    0x4a084ebb    5/11/2009 12:13:47
spsys.sys        0xa1b61000    0xa1bcb000    0x0006a000    0x4a085436    5/11/2009 12:37:10
amdxata.sys        0x8aa51000    0x8aa5a000    0x00009000    0x4a12f30f    5/19/2009 13:57:35
btwavdt.sys        0xa1a25000    0xa1a98000    0x00073000    0x4a430ffc    6/25/2009 01:49:48
btwrchid.sys        0xa1b24000    0xa1b26d80    0x00002d80    0x4a431063    6/25/2009 01:51:31
stwrt.sys        0x97e30000    0x97e97000    0x00067000    0x4a48ff1e    6/29/2009 13:51:26
btwaudio.sys        0xa1a98000    0xa1b19000    0x00081000    0x4a4b6a95    7/1/2009 09:54:29
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
