Windows 7 [HELP] Windows 7 Keyboard problem in EVERY SINGLE GAME!
I have this problem since I installed Windows 7. Now when I hold a button on the keyboard for example "W" games register that I've held it two times as long! I do not know what to do I've lost the will to play.:(
fugno
It would help if you listed your system specs.
My system specs are:
AMD Athlon x64 (Dual core) 4000+
2.00 RAM
ENGTS 250 DDR3 1GB
320 GB HDD
GIGABYTE S-Series Motherboards GA-M56S-S3
Windows 7 Ultimate 32 Bit
DirectX 11.0
With this system i can play Crysis on MAX details in 1280x1024.
I hope you can help me. :(
My keyboard is: Standard PS/2 Keyboard
fugno
I would try to reinstall your keyboard thru the device manager,here is a link to get your drivers.
Software Download
I found out what is my keyboard it's :
Logitech Y-SU45 Deluxe Keyboard
There is no drivers for my keyboard neither on site you post neither on logitech site so i dont know where should i find that stupid driver for windows 7.
You keyboard uses the native USB driver already present in the OS.
Reference:
Deluxe Desktop
How did you come to the conclusion that "games register that I've held it two times as long"?
Is it possible that your system specs are below average, making the games not as responsive as you'd like them to be?
I do not really understand the question but I guess it's probably the key delay/repeat rate you are talking here. these settings are part of the keyboard driver - try the vista driver maybe?
#8
It's called input LAG and can happen when you play at high res on LCD monitors with low response times ie: greater than 5ms
#9
My computer isn't below system requirements of my games, i am talking about:
Just Cause 2
Portal
Battlefield Bad Company 2
SWAT 4
PES 2010
TM Nations Forever
#10
Which monitor, gpu and cpu are you using?
What res are you playing games at?
#11
I have:
2.00 RAM
ENGTS 250 DDR3 1GB
320 GB HDD
DirectX 11.0
and my monitor is LG Flatron L1953PR.
I play at 1280x1024.
Is that a problem because this games ran properly in windows xp but then i was playing at 1024x728.
#12
I was saying before get the keyboard driver from Logitech - it is there for download (Win7)
I bet you have not installed it :)
btw, your keyboard is U-SU45, no?
#15
here we go but no 7 driver... try the Vista one
Deluxe Desktop
If you look earlier in the thread, I've already posted that the keyboard uses native OS drivers. There are none available from Logitech. From the link:
"This product does not ship with software. It uses the native USB drivers already present in your operating system. "
It's system lag causing the issue as Athlonite and I are saying.
George, If you're running AVG, this could be a problem.
#16
try turning down some of the graphical eye candy settings an see if that helps if not then your just going to have to put up with it or buy better hardware that can cope with the visual demands of the games you want to play
Windows Forum Admin
Microsoft MVP
#17
I noticed you wrote that you were using a PS/2 connection, you could try changing to USB but really it should be fast enough..
You could try messing with the settings highlighted in the screenshot as well as giving your machine a general clean using something like this free app: CCleaner - Optimization and Cleaning - Free Download
Finally if all else fails... Buy, beg or borrow another k'board. :)
#18
Going by the cpu comparison chart here, you'll notice the AMD Athlon x64 4000+ Dual Core is not considered blazing fast by any means. These games could be suffering in performance because of the cpu bottleneck.
PassMark CPU Benchmarks - Common CPU's
Windows Forum Admin
Microsoft MVP
#19
One way to find would be to do a little overclock.. ;)
Highwayman
#20
also try cleaning crumbs and old spills from between keys
