Help with a WebCam
I don't this goes here, so if it goes somewhere else, please move it. Nor do I know if this is the only OS that this happens with.
Anyway, I recently bought a GE MiniCam Pro 98756[b/], and have installed the drivers via CD-ROM. That's not the problem though, I don't think. I'm currently using Windows 7 RC 1(Build 7100) on the PC I'm using for it.
Now, the problem I have is with multiple programs that can use a Web Camera. I plug it in, start a connection with someone, and for about 2-3 minutes, everything works just fine. But after a certain amount of time, the camera "freezes", in a way. It still shows the preview of what it's showing the other person, but the other person just sees a frozen image. The built-in microphone keeps working though, too.
I have tried Skype and Windows Messenger, and both do the same thing. GMail's built-in video-enabled messenger does this as well. I've tried reinstalling the drivers a few times, but it keeps doing it. I've also tried with multiple USB Ports, and they all do the same thing.
Can anyone help or does anyone know of a solution?
cherrio
Help with Agama V-315 Webcam
Is there anything listed in the V-315 properties below that I could use to search on that would lead me to a folder that might contain the application that has grabbed this webcam device?
(these are only the video parameters - the audio section works)
V-315 Hardware IDs
USB\VID_093A&PID_2900&REV_1007&MI_00
USB\VID_093A&PID_2900&MI_00
V-315 Compatible IDs
USB\Class_0e&SubClass_03&Prot_00
USB\Class_0e
Service
usbvideo
Device class
Device class guid
{6bdd1fc6-810f-11d0-bec7-08002be2092f}
driver key
{6bdd1fc6-810f-11d0-bec7-08002be2092f}\0004
Manufacturer
Microsoft
Friendly name
Agama V-315
location information
0000.001d.0000.001.003.000.000.000.000
Physical Device Object name
\Device\00000073
capabilities
000000A4
CM_DEVCAP_REMOVABLE
CM_DEVCAP_SILENTINSTALL
CM_DEVCAP_SURPRISEREMOVALOK
Bus type guid
{9d7debbc-c85d-11d1-9eb4-006008c3a19a}
Legacy bus type
0000000F
Bus number
00000000
Enumerator
USB
Address
00000003
Power data
D3
Power capabilities:
0000005D
PDCAP_D0_SUPPORTED
PDCAP_D2_SUPPORTED
PDCAP_D3_SUPPORTED
PDCAP_WAKE_FROM_D0_SUPPORTED
PDCAP_WAKE_FROM_D2_SUPPORTED
Power state mappings:
S0 -> D0
S1 -> D2
S2 -> D2
S3 -> D2
S4 -> D2
S5 -> D3
Removal policy
00000003
Removal policy default
00000003
Install state
00000000
location paths
PCIROOT(0)#PCI(1D00)#USBROOT(0)#USB(1)#USB(3)#USB(3)
Base Container id
{e5f0b27a-2b1b-11df-bdf8-e0cb4e473c0f}
Display name
Agama V-315
Device Instance Path
USB\VID_093A&PID_2900&MI_00\7&26B997E7&0&0000
DevNode status
0180600A
DN_DRIVER_LOADED
DN_STARTED
DN_DISABLEABLE
DN_REMOVABLE
DN_NT_ENUMERATOR
DN_NT_DRIVER
Problem code
00000000
parent
USB\VID_093A&PID_2900\6&14b00c3a&0&3
siblings
Container id
Safe Removal Required
<false>
Bus reported device description
Agama V-315
device categories
Imaging
Driver Node String Name
usbvideo.inf:Microsoft.NTamd64:USBVideo:6.1.7600.16385:usb\class_0e
Install Date
3/8/2010 7:53:29 PM
First install date
3/8/2010 7:53:29 PM
Driver Assembly date
6/20/2006 5:00:00 PM
Driver Assembly version
6.1.7600.16385
Driver assembly description
USB Video Device
Inf name
usbvideo.inf
Inf section
USBVideo
Inf section extension
.NT
Matching device id
usb\class_0e
Provider
Microsoft
Device co-installers
mmcico.dll,MediaClassCoInstaller
Rank of installed Driver
00FF2002
Included Infs
ks.inf
kscaptur.inf
Generic driver installed
<true>
Class upper filters
ksthunk
Class long name
Imaging devices
Class short name
Class installer
sti_ci.dll,ClassInstall
Class icon path
%systemroot%\system32\sti_ci.dll,-1000
