Help with blue screen
Hi All
I am not very clued up on pc tech but would very much appreciate any help you could offer me. I have had this pc for about 2 months now and lately it has started to display error messages of the blue screen veriaty.
This is what i tend to see!
Problem signature
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 2057
Extra information about the problem
BCCode: 1e
BCP1: 0000000000000000
BCP2: 0000000000000000
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Bucket ID: X64_IP_MISALIGNED
Server information: f7ff094a-899f-475b-bc11-cdfbedadc4b0
if anyone has a clue how to resolve this i would be forever gratefull.
Thanks Hurdy
Saltgrass
There is a BSOD forum located here. They will request you set your system up to do mini dumps and after you have one or more, zip them up and attach.
Trouble
Noob Whisperer
HurdyGurdy
Hello and welcome to the forums. As Saltgrass has already commented, I have moved your thread to the BSOD forum where I'm sure you will receive the help you require.
Please refer to and do your best to comply with the following three links to the sticky posts in the root of the BSOD forum.
SF Diagnostic Tool
Important! Every thread starter please see.
How to ask for help with a BSOD problem
You may be able to use safemode with networking to help make this easier.
If you have any problem with these please post back and we will attempt to advise you further. Make sure you pay particular attention to the instructions regarding compressing these file before uploading as well as taking ownership of the dump folder if you have problems accessing these files.
Thank you very much for moving my thread to the correct location.
I also thank you for the advice on how to post the correct information. I have tried to follow it as best i can with my limited skills.
here are the pictures you have asked to see from CPU-Z
I do hope i have done everything correctly and thank you for your help so far
Best regards
Hurdy
Your RAM is currently set 1390Mhz which is not good. In the bios, set Dram frequency "automatic".
1. Set Dram "AUtO" in the bios.
2. Update:
Neutral Wireless Solution
scmndisp.sys Wed Jan 17 02:48:03 2007
Marvell
mv91xx.sys Fri Dec 25 01:45:39 2009
mvxxmm.sys Fri Dec 25 01:45:15 2009
Symantec looks good so far. Report your results, we'll see.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\020511-18517-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`0304b000 PsLoadedModuleList = 0xfffff800`03288e50
Debug session time: Sat Feb  5 07:48:30.481 2011 (UTC - 5:00)
System Uptime: 0 days 12:54:43.543
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {538426, 2, 8, fffff800030bed9a}
Probably caused by : win32k.sys ( win32k!RawInputThread+6ed )
Followup: MachineOwner
2: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000538426, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, bitfield :
Arg4: fffff800030bed9a, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032f30e0
 0000000000538426
CURRENT_IRQL:  2
FAULTING_IP:
nt!KeWaitForMultipleObjects+2c0
fffff800`030bed9a 83c820          or      eax,20h
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  csrss.exe
TRAP_FRAME:  fffff880029a66b0 -- (.trap 0xfffff880029a66b0)
rax=0000000000000001 rbx=0000000000000000 rcx=0000000000000001
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030bed9a rsp=fffff880029a6840 rbp=0000000000000004
 r8=0000000000000002  r9=000000000000000d r10=0000000000000004
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!KeWaitForMultipleObjects+0x2c0:
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030baca9 to fffff800030bb740
STACK_TEXT:
fffff880`029a6568 fffff800`030baca9 : 00000000`0000000a 00000000`00538426 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffff880`029a6570 fffff800`030b9920 : 00000000`00000000 fffffa80`09031920 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`029a66b0 fffff800`030bed9a : 00000000`00000000 00000000`00000000 fffff880`00000000 fffff800`03104fdc : nt!KiPageFault+0x260
fffff880`029a6840 fffff960`000e35cd : 00000000`00000004 fffffa80`090671a0 00000000`00000001 00000000`0000000d : nt!KeWaitForMultipleObjects+0x2c0
fffff880`029a6af0 fffff960`00074528 : fffffa80`0000007b 00000000`0000000f fffff880`00000001 ffffffff`800003b0 : win32k!RawInputThread+0x6ed
fffff880`029a6bc0 fffff960`000f409a : fffffa80`00000002 fffff880`0298bf40 00000000`00000020 00000000`00000000 : win32k!xxxCreateSystemThreads+0x58
fffff880`029a6bf0 fffff800`030ba993 : fffffa80`09087b60 00000000`00000004 000007ff`fffd3000 00000000`00000000 : win32k!NtUserCallNoParam+0x36
fffff880`029a6c20 000007fe`fda33d3a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`01b7f8f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fda33d3a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff960`000e35cd 8bf8            mov     edi,eax
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  win32k!RawInputThread+6ed
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4cbe5d3e
FAILURE_BUCKET_ID:  X64_0xA_win32k!RawInputThread+6ed
Drivers:
fffff880`04ce8000 fffff880`04d26000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f60000 fffff880`00fb7000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`0409b000 fffff880`04125000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04d60000 fffff880`04d76000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010d9000 fffff880`010e4000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04d26000 fffff880`04d2e000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`087de000 fffff880`087e9000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00de7000 fffff880`00df0000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0101b000 fffff880`01045000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05200000 fffff880`052d0000   bcmwlhigh664 bcmwlhigh664.sys Thu Nov 05 19:27:07 2009 (4AF36D5B)
fffff880`02d00000 fffff880`02d07000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04400000 fffff880`044ed000   BHDrvx64 BHDrvx64.sys Mon Nov 15 18:11:35 2010 (4CE1BE27)
fffff880`04597000 fffff880`045a8000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03dc0000 fffff880`03dde000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`07470000 fffff880`075fc000   CAHS164  CAHS164.sys  Tue Jun 29 07:06:02 2010 (4C29D39A)
fffff880`044fb000 fffff880`04597000   ccHPx64  ccHPx64.sys  Fri Feb 05 16:05:45 2010 (4B6C8829)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      Tue Nov 02 00:59:22 2010 (4CCF9AAA)
fffff880`02ccd000 fffff880`02cf7000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cd8000 fffff880`00d98000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`013a6000 fffff880`013d6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c7a000 fffff880`00cd8000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`014f6000 fffff880`01569000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04d50000 fffff880`04d60000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`04cd5000 fffff880`04ce3000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0439b000 fffff880`043b9000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0438c000 fffff880`0439b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`015d0000 fffff880`015e6000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`053b9000 fffff880`053db000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`053f6000 fffff880`053ff000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04df0000 fffff880`04dfc000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04a67000 fffff880`04a7a000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`053ea000 fffff880`053f6000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04a95000 fffff880`04b89000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`04b89000 fffff880`04bcf000   dxgmms1  dxgmms1.sys  Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`042f1000 fffff880`04367000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`087ba000 fffff880`087da000   ENG64    ENG64.SYS    Mon Dec 13 20:47:30 2010 (4D06CCB2)
fffff880`04367000 fffff880`0438c000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`08600000 fffff880`087ba000   EX64     EX64.SYS     Mon Dec 13 20:55:48 2010 (4D06CEA4)
fffff880`0119e000 fffff880`011b2000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010e4000 fffff880`01130000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0157a000 fffff880`01584000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0143a000 fffff880`01474000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0162b000 fffff880`01675000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04d3a000 fffff880`04d47000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03002000 fffff800`0304b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04bcf000 fffff880`04bf3000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0720e000 fffff880`07227000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`053e1000 fffff880`053e9080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`07200000 fffff880`0720e000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`03cf8000 fffff880`03dc0000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017ef000 fffff880`017f8000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0426b000 fffff880`042e6000   IDSvia64 IDSvia64.sys Fri Nov 05 17:13:11 2010 (4CD47367)
fffff880`045ce000 fffff880`045e4000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04014000 fffff880`0403b000   Ironx64  Ironx64.SYS  Tue Apr 27 20:48:23 2010 (4BD785D7)
fffff880`00d98000 fffff880`00db8000   jraid    jraid.sys    Mon May 31 01:44:28 2010 (4C034CBC)
fffff880`04c3b000 fffff880`04c4a000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04a7a000 fffff880`04a88000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bc3000 fffff800`00bcd000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04c59000 fffff880`04c9c000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`014dc000 fffff880`014f6000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`053db000 fffff880`053e0200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`04c9c000 fffff880`04c9fd80   LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`087db000 fffff880`087dd480   LGVirHid LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`045e6000 fffff880`045fb000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`03c5b000 fffff880`03c70000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04257000 fffff880`0426b000   LMouFilt LMouFilt.Sys Tue Aug 24 13:21:43 2010 (4C73FFA7)
fffff880`04066000 fffff880`04089000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c22000 fffff880`00c66000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`061e5000 fffff880`061f3000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04c4a000 fffff880`04c59000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04a88000 fffff880`04a95000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c00000 fffff880`00c1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03dde000 fffff880`03df6000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`07655000 fffff880`07682000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`07682000 fffff880`076d0000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`076d0000 fffff880`076f3000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02d65000 fffff880`02d70000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fc0000 fffff880`00fca000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0147e000 fffff880`014dc000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`0405b000 fffff880`04066000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017dd000 fffff880`017ef000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01045000 fffff880`010d1000   mv91xx   mv91xx.sys   Fri Dec 25 01:45:39 2009 (4B345F93)
fffff880`010d1000 fffff880`010d9000   mvxxmm   mvxxmm.sys   Fri Dec 25 01:45:15 2009 (4B345F7B)
fffff880`0168b000 fffff880`0177d000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04d9a000 fffff880`04da6000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03cc3000 fffff880`03cd6000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04da6000 fffff880`04dd5000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0533e000 fffff880`05353000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`041af000 fffff880`041be000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04125000 fffff880`0416a000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0177d000 fffff880`017dd000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02d70000 fffff880`02d81000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0404f000 fffff880`0405b000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0304b000 fffff800`03627000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01203000 fffff880`013a6000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02cf7000 fffff880`02d00000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`04cbd000 fffff880`04cd5000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`043b9000 fffff880`043e9000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`061e3000 fffff880`061e4180   nvBridge nvBridge.kmd Sat Oct 30 07:31:36 2010 (4CCC0218)
fffff880`05353000 fffff880`0537c000   nvhda64v nvhda64v.sys Tue Sep 07 16:08:40 2010 (4C869BC8)
fffff880`05606000 fffff880`061e2c00   nvlddmkm nvlddmkm.sys Sat Oct 30 07:35:56 2010 (4CCC031C)
fffff880`03c70000 fffff880`03cc3000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`04173000 fffff880`04199000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e0d000 fffff880`00e22000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fca000 fffff880`00ffd000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e93000 fffff880`00e9a000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e9a000 fffff880`00eaa000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01569000 fffff880`0157a000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`076f3000 fffff880`07799000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0537c000 fffff880`053b9000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c66000 fffff880`00c7a000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04d76000 fffff880`04d9a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04dd5000 fffff880`04df0000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04c00000 fffff880`04c21000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04c21000 fffff880`04c3b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02dac000 fffff880`02dfd000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02d4a000 fffff880`02d53000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02d53000 fffff880`02d5c000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02d5c000 fffff880`02d65000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01400000 fffff880`0143a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`03cd6000 fffff880`03cee000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04200000 fffff880`04257000   Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`0722c000 fffff880`07452300   RTKVHD64 RTKVHD64.sys Fri Jan 29 01:48:35 2010 (4B6284C3)
fffff880`01675000 fffff880`0167f000   scmndisp scmndisp.sys Wed Jan 17 02:48:03 2007 (45ADD4B3)
fffff880`00db8000 fffff880`00de7000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`07799000 fffff880`077a4000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04d2e000 fffff880`04d3a000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`041be000 fffff880`041db000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0167f000 fffff880`01687000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07c00000 fffff880`07c86000   SRTSP64  SRTSP64.SYS  Wed Feb 24 18:59:29 2010 (4B85BD61)
fffff880`0403b000 fffff880`0404f000   SRTSPX64 SRTSPX64.SYS Wed Feb 24 18:59:48 2010 (4B85BD74)
fffff880`07cf4000 fffff880`07d8a000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07c8d000 fffff880`07cf4000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`077a4000 fffff880`077d1000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04cbb000 fffff880`04cbc480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01130000 fffff880`0119e000   SYMDS64  SYMDS64.SYS  Mon Aug 17 19:35:30 2009 (4A89E942)
fffff880`011b2000 fffff880`011ed000   SYMEFA64 SYMEFA64.SYS Wed Apr 21 17:47:39 2010 (4BCF727B)
fffff880`02c76000 fffff880`02cac000   SYMEVENT64x86 SYMEVENT64x86.SYS Thu Aug 13 18:28:21 2009 (4A849385)
fffff880`02c00000 fffff880`02c76000   SYMTDIV  SYMTDIV.SYS  Tue May 04 00:38:27 2010 (4BDFA4C3)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`077d1000 fffff880`077e3000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02d9f000 fffff880`02dac000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02d81000 fffff880`02d9f000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`04000000 fffff880`04014000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004b0000 fffff960`004ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`045a8000 fffff880`045ce000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04ca0000 fffff880`04cb2000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`07453000 fffff880`07470000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`045e4000 fffff880`045e5f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04a56000 fffff880`04a67000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`052e4000 fffff880`0533e000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04a00000 fffff880`04a56000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04bf3000 fffff880`04c00000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02d07000 fffff880`02d15000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02d15000 fffff880`02d3a000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00e22000 fffff880`00e37000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e37000 fffff880`00e93000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01584000 fffff880`015d0000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`052d0000 fffff880`052dd000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`04199000 fffff880`041af000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03cee000 fffff880`03cf8000   vwifimp  vwifimp.sys  Mon Jul 13 20:07:28 2009 (4A5BCC40)
fffff880`041db000 fffff880`041f6000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02d3a000 fffff880`02d4a000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ead000 fffff880`00f51000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f51000 fffff880`00f60000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0416a000 fffff880`04173000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00330000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`04d47000 fffff880`04d50000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fb7000 fffff880`00fc0000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02cac000 fffff880`02ccd000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`03c2a000 fffff880`03c5b000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`087f2000 fffff880`087fb000   cpuz134_x64.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`087e9000 fffff880`087f2000   cpuz134_x64.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`087ba000 fffff880`087da000   ENG64.SYS
    Checksum:  00000000
    ImageSize:  00020000
fffff880`08600000 fffff880`087ba000   EX64.SYS
    Checksum:  00000000
    ImageSize:  001BA000
fffff880`04276000 fffff880`042f1000   IDSvia64.sys
    Checksum:  00000000
    ImageSize:  0007B000
fffff880`087bb000 fffff880`087db000   ENG64.SYS
    Checksum:  00000000
    ImageSize:  00020000
fffff880`08601000 fffff880`087bb000   EX64.SYS
    Checksum:  00000000
    ImageSize:  001BA000
fffff880`07d8a000 fffff880`07dfb000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`015e6000 fffff880`015f4000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`015f4000 fffff880`01600000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01474000 fffff880`0147d000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`013d6000 fffff880`013e9000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04c8a000 fffff880`04cbb000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`04c59000 fffff880`04c8a000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
#7
Thanks Cybercore
I am at work just now so will sort the Dram frequency once i am home.
Sorry for being stupid here but point 2 you say Update
Marvell
how do i go about this?
again i am sorry for being stupid and very much appreciate your patience.
Best Regards
Hurdy
#8
Netgear Neutral Wireless Solution
Support Home Page
Marvell MV91xx AHCI/RAID driver
support.asus.com
Marvell: Support
Cybercore
I have done as you have said and had no problems this evening i will see what the rest of the week brings. Everything seems more stable now for sure. Thank you for your help.
Best Regards
Hurdy
#10
Cybercore
Best Regards
Hurdy
You're much welcome, Hurdy.
Should crashes reoccur, attach the new crash dumps and new CPU-Z screenshot of the memory tab.
#11
memory.PNG speed 2.PNG speed.PNG speed 3.PNG View attachment Seven Forums.zip
Hi Again
It would appear that i got lucky having an evening or so without any trouble but the good old BSOD is back.
cybercore
Your RAM is currently set 1390Mhz which is not good. In the bios, set Dram frequency "automatic".​
I had a look and to me it looks like that is what the auto is trying to achieve also.
Maybe i am wrong but looks that way I have uploaded the latest files for you to take a look at. I think i done everything you ask so hopefully you can see what you think of this now.
Thanks in advance for anyone who can help me out
Gratefull
Hurdy
#13
Hi Cybercore
Thanks for responding so quickly and here is what you gave asked.
Thanks
Hurdy
#14
Set DRAM frequency 1333Mhz.
#15
Have done
I only have option to set it to 1395 will go with that and keep my fingers crossed! Alough thats it back to what it had originally been set at.
Thanks again for helping
Hurdy
#16
If that's the only option in the bios then your motherboard may be incompatible with the RAM sticks installed.
Although I can hardly imagine 1395 being the only option. You may want to load setup defaults for the entire bios.
#17
Poor wording on my behalf I mean thats the only option close to what you suggested.
#18
This also means that the motherboard is probably incompatible with the RAM installed. Check the manufacturer's site.
But again, I hardly imagine DRAM frequency 1395 - something's not right here. Try setup defaults for the entire bios.
