Windows 7 Help with folders
mgroessl
Is there a way to designate what file types are able to be included in a folder? For example, I would like to create a folder that will ONLY accept Excel files. Any ideas?
Thanks in advance!!
Mark
Unfortunately, the feature that you are looking for doesn’t exist in Scheduled tasks and Events. If you have any programming experience, you can create a simple filesystemwatcher class via C++, Vbnet etc. If not, you can use simple coding with something like Autohotkey Link Removed - Invalid URL (free), Autoit Link Removed - Invalid URL (free) or user friendly macro setup - Winautomation Link Removed (30 day trial).
