Okay it's been enough of a pain for me trying to figure out how to open the dump file, got that sorted and now I'm trying to understand it. I get it's obviously a hardware issue, lol, but any ideas beyond that??
Any help is appreciated, thanks in advance~
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000006b19220, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88006b3569e, address which referenced memory
Debugging Details:
WRITE_ADDRESS: 0000000006b19220
CURRENT_IRQL: 2
FAULTING_IP:
WmXlCore+669e
fffff880`06b3569e 0100 add dword ptr [rax],eax
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffff80000ba2280 -- (.trap 0xfffff80000ba2280)
rax=0000000006b19220 rbx=0000000000000000 rcx=fffff88006b2f000
rdx=fffffa8006c1eeb0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88006b3569e rsp=fffff80000ba2410 rbp=0000000000000000
r8=0000000000000000 r9=0000000000000000 r10=0000000000000000
r11=fffff88006b3c240 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl zr na po nc
WmXlCore+0x669e:
fffff880`06b3569e 0100 add dword ptr [rax],eax ds:00000000`06b19220=????????
Resetting default scope
EXCEPTION_RECORD: fffff880009ebec0 -- (.exr 0xfffff880009ebec0)
ExceptionAddress: 0000000000000000
ExceptionCode: 00000000
ExceptionFlags: 0ad8bdb0
NumberParameters: 0
MISALIGNED_IP:
WmXlCore+669e
LAST_CONTROL_TRANSFER: from fffff8000448d769 to fffff8000448e1c0
STACK_TEXT:
fffff800`00ba2138 fffff800`0448d769 : 00000000`0000000a 00000000`06b19220 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff800`00ba2140 fffff800`0448c3e0 : fffff800`04498085 fffff880`009e7180 00000000`00000005 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`00ba2280 fffff880`06b3569e : 00000000`06b19220 00000000`00000246 fffffa80`061e0984 fffff800`00ba254c : nt!KiPageFault+0x260
fffff800`00ba2410 00000000`00000001 : fffff800`00ba2720 fffff880`06b364c6 fffffa80`00000000 fffff800`00ba2720 : WmXlCore+0x669e
fffff800`00ba26b0 fffff800`00ba2720 : fffff880`06b364c6 fffffa80`00000000 fffff800`00ba2720 fffff800`00ba2720 : 0x1
fffff800`00ba26b8 fffff880`06b364c6 : fffffa80`00000000 fffff800`00ba2720 fffff800`00ba2720 fffffa80`00000001 : 0xfffff800`00ba2720
fffff800`00ba26c0 fffff880`06b37947 : fffffa80`06b19470 00000000`1b35c31c fffffa80`06b19510 fffffa80`06b19220 : WmXlCore+0x74c6
fffff800`00ba2700 fffff800`04498e3c : fffff800`00ba2830 00000000`00000000 00000000`00000001 00000000`00000000 : WmXlCore+0x8947
fffff800`00ba27a0 fffff800`04498cd6 : fffffa80`0480e358 fffffa80`0480e358 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x6c
fffff800`00ba2810 fffff800`04498bbe : 00000426`e4157de9 fffff800`00ba2e88 00000000`01be8535 fffff800`04603928 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00ba2e60 fffff800`044989a7 : fffffa80`0528dcc2 fffffa80`01be8535 fffffa80`05287000 00000000`00000035 : nt!KiTimerExpiration+0x1be
fffff800`00ba2f00 fffff800`04491305 : 00000000`00000000 fffffa80`05e16760 00000000`00000000 fffff880`0696d480 : nt!KiRetireDpcList+0x277
fffff800`00ba2fb0 fffff800`0449111c : fffffa80`05df2370 fffff800`04a01895 fffff800`04a27460 fffff880`07a8dbc0 : nt!KyRetireDpcList+0x5
fffff880`07a8db00 fffff800`044d9193 : fffff800`0448a740 fffff800`0448a7ac fffff880`07a8db80 00000000`000000f4 : nt!KiDispatchInterruptContinue
fffff880`07a8db30 fffff800`0448a7ac : fffff880`07a8db80 00000000`000000f4 00000000`00000001 00000000`00000000 : nt!KiDpcInterruptBypass+0x13
fffff880`07a8db40 fffff880`06950363 : fffff880`009ebec0 fffff880`0694fdc0 fffffa80`05df2370 fffffa80`05df2370 : nt!KiInterruptDispatchNoLock+0x1fc
fffff880`07a8dcd0 fffff880`0694fe96 : 00000000`00000000 fffffa80`03f00010 00000000`00000080 fffffa80`05df2370 : dxgmms1!VidSchiSubmitQueueCommand+0x1b
fffff880`07a8dd00 fffff800`04724e6a : 00000000`06ba6da1 fffffa80`05e16760 fffffa80`039e89e0 fffffa80`05e16760 : dxgmms1!VidSchiWorkerThread+0xd6
fffff880`07a8dd40 fffff800`0447eec6 : fffff880`009e7180 fffffa80`05e16760 fffff880`009f1f40 fffffa80`04960e70 : nt!PspSystemThreadStartup+0x5a
fffff880`07a8dd80 00000000`00000000 : fffff880`07a8e000 fffff880`07a88000 fffff880`07a8cf30 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
WmXlCore+669e
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: WmXlCore+669e
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_IP_MISALIGNED_WmXlCore.sys
Followup: MachineOwner
0: kd> lmvm hardware
start end module name
Arguments:
Debugging Details:
CURRENT_IRQL: 2
FAULTING_IP:
WmXlCore+669e
BUGCHECK_STR: 0xD1
WmXlCore+0x669e:
NumberParameters: 0
MISALIGNED_IP:
WmXlCore+669e
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
WmXlCore+669e
