- Thread Author
- #1
Hey everyone, I was directed to the windows 7 forums by some friends of mine from wargamer.com after I told them I was having some issues with my computer. This website generated a lot of praise and its my first time making use of your knowledge and experience.
I have an M17x Alienware gaming computer, which I have had for a little over a year now. A few months back it began overheating while I was playing a computer game, which had never happened before. I am very diligent about keeping my air vents clear and yesterday took a can of compressed air to the vents as well. I also have it sitting on a USB powered cooling pad. Last time it was overheating someone suggested that I download any updates for my BIOS that I could find on Dell's driver page and it worked! For the last 3 months or so my computer never overheated again, which led me to believe it was all software related and not hardware. But now, for the last 4-5 days its been doing it again. I think a program that I ran might have tinkered with my default settings in regards to my main CPU fan or the fans on my graphic cards, or both, without me knowing it. I am not one to just go into BIOS or the advanced settings for my graphics cards or through ATI's catalyst control center because I know I dont know what im doing, thats why im here. If any of you can suggest a piece of software, or a diagnostic, or a website that could be useful I would very much appreciate it. Money is tight for me so any advice I can get will be much appreciated. My computer is under warranty but I wanted to see if I could get pointed in the right direction before calling dell tech support. My specs are below, any other information that would be useful to you in assisting me, just ask. (Also, Speccy says my Crossfirex is disabled but when I open up ATIs catalyst control center the box next to enable crossfirex is checked, dont know if that relates to my heating issues) I also attached my Dxdiag file as well. Thanks again!
Source of heat is back left corner of the laptop (after running a game for a bit, almost hot to the touch) picture;
Specs:
Operating System
MS Windows 7 Home Premium 64-bit
CPU
Intel Core i7 720QM @ 1.60GHz 45 °C
Clarksfield 45nm Technology
RAM
4.0GB Dual-Channel DDR3 @ 661MHz (9-9-9-24)
Motherboard
Alienware (CPU 1)
Graphics
Generic PnP Monitor @ 1920x1200
ATI Mobility Radeon HD 4870 (Dell)
CrossFire Disabled
Hard Drives
488GB TOSHIBA TOSHIBA MK5056GSY ATA Device (SATA) 40 °C
Optical Drives
HL-DT-ST DVD+-RW GA31N ATA Device
Audio
IDT High Definition Audio CODEC
Specs:
Operating System
CPU
RAM
Motherboard
Alienware (CPU 1)
Graphics
CrossFire Disabled
Hard Drives
Optical Drives
Audio
