Help with random BSOD
gp2
Well-Known Member
My vaio VGN-fz485u it's having random BSOD's I need to stop this.
please help and thanks in advance.
OS Windows 7 64bit
Ram looks alright. Thanks for attaching.
The crash was caused by Ricoh USB Video Class Image Capture Controller (WebCam).
Update drivers:
R5U870FLamd64.sys Tue Sep 04 05:01:44 2007
R5U870FUamd64.sys Tue Sep 04 05:01:41 2007
InterVideo
regi.sys Mon Apr 16 11:19:10 2007
IDT Audio
stwrt64.sys Thu Sep 13 11:30:19 2007
Wacom Mouse
wacommousefilter.sys Fri Feb 16 13:12:17 2007
Sony Firmware Extension Parser driver
SFEP.sys Fri Nov 27 00:39:13 2009
VMware
vmci.sys Thu Oct 22 05:26:48 2009
VMkbd.sys Thu Oct 22 06:51:05 2009
VMNET.SYS Mon Aug 10 08:04:50 2009
vmnetbridge.sys Mon Aug 10 08:05:58 2009
vmnetuserif.sys Thu Oct 22 06:17:07 2009
vstor2-ws60.sys Mon Oct 12 17:06:26 2009
WsAudioDevice_383S(1).sys Thu Jul 23 08:04:10 2009
Marvell Yukon Ethernet Controller
yk62x64.sys Mon Feb 23 10:02:27 2009
Intel WiFi
netw5v64.sys Thu Mar 26 12:21:24 2009
Mediafour MacDrive
MDFSYSNT.sys Mon Sep 28 15:02:26 2009
Eset Smart Security
eamon.sys Wed Oct 07 03:05:58 2009
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031611-36083-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 UP Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02e10000 PsLoadedModuleList = 0xfffff800`0304de50
Debug session time: Wed Mar 16 02:47:57.436 2011 (UTC - 4:00)
System Uptime: 0 days 10:04:59.356
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 3B, {c0000046, fffff80002eaf034, fffff88009f2e040, 0}
Unable to load image R5U870FUamd64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for R5U870FUamd64.sys
*** ERROR: Module load completed but symbols could not be loaded for R5U870FUamd64.sys
Probably caused by : R5U870FUamd64.sys ( R5U870FUamd64+3ba0 )
Followup: MachineOwner
kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000046, Exception code that caused the bugcheck
Arg2: fffff80002eaf034, Address of the instruction which caused the bugcheck
Arg3: fffff88009f2e040, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000046 - An attempt to release a mutant object was made by a thread that was not the owner of the mutant object.
FAULTING_IP:
nt!RtlRaiseStatus+18
fffff800`02eaf034 488b8424b8010000 mov     rax,qword ptr [rsp+1B8h]
CONTEXT:  fffff88009f2e040 -- (.cxr 0xfffff88009f2e040)
rax=0000000000000000 rbx=00000000c0000046 rcx=fffff88009f2e040
rdx=0000000000000001 rsi=0000000000000001 rdi=fffff80002ffae80
rip=fffff80002eaf034 rsp=fffff88009f2df80 rbp=0000000000000000
 r8=0000000000000000  r9=0000000000000200 r10=fffff80002e10000
r11=fffff88009f2e550 r12=0000000000000000 r13=0000000000000000
r14=fffffa8007808060 r15=0000000000000000
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00000282
nt!RtlRaiseStatus+0x18:
fffff800`02eaf034 488b8424b8010000 mov     rax,qword ptr [rsp+1B8h] ss:0018:fffff880`09f2e138=fffff80002eaf034
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  chrome.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002e89610 to fffff80002eaf034
STACK_TEXT:
fffff880`09f2df80 fffff800`02e89610 : 00000000`00000000 fffffa80`0743bab0 00000001`07060001 fffff880`09f2e538 : nt!RtlRaiseStatus+0x18
fffff880`09f2e520 fffff880`07db9ba0 : fffffa80`00000001 fffff800`00000001 fffffa80`04917b00 00000000`00000000 : nt!KeReleaseMutant+0x260
fffff880`09f2e5d0 fffffa80`00000001 : fffff800`00000001 fffffa80`04917b00 00000000`00000000 00000000`00000000 : R5U870FUamd64+0x3ba0
fffff880`09f2e5d8 fffff800`00000001 : fffffa80`04917b00 00000000`00000000 00000000`00000000 fffff880`03e8c5fb : 0xfffffa80`00000001
fffff880`09f2e5e0 fffffa80`04917b00 : 00000000`00000000 00000000`00000000 fffff880`03e8c5fb fffffa80`0683f3d8 : 0xfffff800`00000001
fffff880`09f2e5e8 00000000`00000000 : 00000000`00000000 fffff880`03e8c5fb fffffa80`0683f3d8 fffff8a0`049febd0 : 0xfffffa80`04917b00
FOLLOWUP_IP:
R5U870FUamd64+3ba0
fffff880`07db9ba0 ??              ???
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  R5U870FUamd64+3ba0
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: R5U870FUamd64
IMAGE_NAME:  R5U870FUamd64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  46dd1ef5
STACK_COMMAND:  .cxr 0xfffff88009f2e040 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_R5U870FUamd64+3ba0
Drivers:
fffff880`07f6a000 fffff880`07f95000   000      000.fcl      Fri Sep 26 09:11:22 2008 (48DCDF7A)
fffff880`04063000 fffff880`040a1000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f1c000 fffff880`00f73000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02ef6000 fffff880`02f80000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03e92000 fffff880`03ea8000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00e5e000 fffff880`00e69000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`03f6c000 fffff880`03fbb000   Apfiltr  Apfiltr.sys  Fri Apr 09 04:01:50 2010 (4BBEDEEE)
fffff880`04845000 fffff880`04850000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`01047000 fffff880`01050000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00d7f000 fffff880`00da9000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00980000 fffff960`009e1000   ATMFD    ATMFD.DLL    Fri Jan 07 00:49:20 2011 (4D26A960)
fffff880`0101e000 fffff880`0102a000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`01a33000 fffff880`01a3a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03998000 fffff880`039a9000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`049d6000 fffff880`049f4000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`01a00000 fffff880`01a2a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01b87000 fffff880`01bb7000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d21000 fffff880`00d7f000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`039e5000 fffff880`039e9500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`01577000 fffff880`015ea000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`01015000 fffff880`0101e000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`03fd7000 fffff880`03fe7000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`07dc2000 fffff880`07dc5800   copperhd copperhd.sys Tue Nov 10 02:50:17 2009 (4AF91B39)
fffff880`07de2000 fffff880`07df0000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`038f7000 fffff880`0397a000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`0397a000 fffff880`03998000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02ec0000 fffff880`02ecf000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01b71000 fffff880`01b87000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03e6a000 fffff880`03e8c000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`07c0b000 fffff880`07c1e000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`07c00000 fffff880`07c0b000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`07df0000 fffff880`07dfc000   dump_pciidex dump_pciidex.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`07c1e000 fffff880`07c2a000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03800000 fffff880`038f4000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`10000000 fffff880`10046000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`09384000 fffff880`093d2000   eamon    eamon.sys    Wed Oct 07 03:05:58 2009 (4ACC3DD6)
fffff880`01a3a000 fffff880`01a4b000   easdrv   easdrv.sys   Wed Oct 07 03:06:57 2009 (4ACC3E11)
fffff880`07c5b000 fffff880`07c72000   epfw     epfw.sys     Wed Oct 07 02:55:13 2009 (4ACC3B51)
fffff880`03fe7000 fffff880`03ff2000   Epfwndis Epfwndis.sys Wed Oct 07 02:55:11 2009 (4ACC3B4F)
fffff880`017e3000 fffff880`017f8000   epfwtdi  epfwtdi.sys  Wed Oct 07 02:55:12 2009 (4ACC3B50)
fffff880`00fdf000 fffff880`00ff3000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00da9000 fffff880`00df5000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01400000 fffff880`0140a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b37000 fffff880`01b71000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01789000 fffff880`017d3000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`03fca000 fffff880`03fd7000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`033ed000 fffff800`03436000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`07f0d000 fffff880`07f19000   hcmon    hcmon.sys    Thu Oct 22 06:00:49 2009 (4AE02D51)
fffff880`03f2a000 fffff880`03f4e000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`03e00000 fffff880`03e19000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`03e19000 fffff880`03e21080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`07dc6000 fffff880`07dd4000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0490e000 fffff880`049d6000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01b2e000 fffff880`01b37000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03f4e000 fffff880`03f6c000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0103f000 fffff880`01047000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`039cf000 fffff880`039e5000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`045eb000 fffff880`045fa000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`07dd4000 fffff880`07de2000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bab000 fffff800`00bb5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`10053000 fffff880`10096000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`0155d000 fffff880`01577000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0175e000 fffff880`01789000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`03e8c000 fffff880`03e91200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`07bc8000 fffff880`07bdd000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`07c38000 fffff880`07c5b000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cc9000 fffff880`00d0d000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`01ad3000 fffff880`01b2e000   MDFSYSNT MDFSYSNT.sys Mon Sep 28 15:02:26 2009 (4AC10842)
fffff880`016e6000 fffff880`016f3000   MDPMGRNT MDPMGRNT.SYS Wed Sep 23 15:23:04 2009 (4ABA7598)
fffff880`07d46000 fffff880`07d55000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`07c2a000 fffff880`07c38000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`03fbb000 fffff880`03fca000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04b7e000 fffff880`04b8b000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e39000 fffff880`00e53000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04800000 fffff880`04818000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04818000 fffff880`04845000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`07e9c000 fffff880`07eea000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`07eea000 fffff880`07f0d000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`00e53000 fffff880`00e5e000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01aa9000 fffff880`01ab4000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011b3000 fffff880`011bd000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`093f9000 fffff880`093faa80   MSPQM    MSPQM.sys    Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`014ff000 fffff880`0155d000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02eb5000 fffff880`02ec0000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`016d4000 fffff880`016e6000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0140a000 fffff880`014fc000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03ea8000 fffff880`03eb4000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`048cb000 fffff880`048de000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04a80000 fffff880`04aaf000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04b93000 fffff880`04ba8000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02e00000 fffff880`02e0f000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02f80000 fffff880`02fc5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`016fe000 fffff880`0175e000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`040b0000 fffff880`045eb000   netw5v64 netw5v64.sys Thu Mar 26 12:21:24 2009 (49CBAB84)
fffff880`01ab4000 fffff880`01ac5000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02ea9000 fffff880`02eb5000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e10000 fffff800`033ed000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01223000 fffff880`013c6000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01a2a000 fffff880`01a33000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`10ddb000 fffff880`10ddc180   nvBridge nvBridge.kmd Thu Jun 03 20:46:40 2010 (4C084CF0)
fffff880`1009c000 fffff880`10dda580   nvlddmkm nvlddmkm.sys Thu Jun 03 21:03:58 2010 (4C0850FE)
fffff880`04878000 fffff880`048cb000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02fd9000 fffff880`02fff000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`01000000 fffff880`01015000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`011ca000 fffff880`011fd000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fcf000 fffff880`00fdf000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00e00000 fffff880`00e39000   pcmcia   pcmcia.sys   Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015ea000 fffff880`015fb000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`09200000 fffff880`092a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`048de000 fffff880`048ea000   pnarp    pnarp.sys    Sat Jun 06 02:06:44 2009 (4A2A0774)
fffff880`03e2d000 fffff880`03e6a000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d0d000 fffff880`00d21000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`048ea000 fffff880`048f6000   purendis purendis.sys Sat Jun 06 00:32:06 2009 (4A29F146)
fffff880`00ff3000 fffff880`00ffee00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`07d74000 fffff880`07d87780   R5U870FLamd64 R5U870FLamd64.sys Tue Sep 04 05:01:44 2007 (46DD1EF8)
fffff880`07db6000 fffff880`07dc1280   R5U870FUamd64 R5U870FUamd64.sys Tue Sep 04 05:01:41 2007 (46DD1EF5)
fffff880`02ecf000 fffff880`02ef3000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04aaf000 fffff880`04aca000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04aca000 fffff880`04aeb000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04aeb000 fffff880`04b05000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02e58000 fffff880`02ea9000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04b05000 fffff880`04b10000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01a8e000 fffff880`01a97000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01a97000 fffff880`01aa0000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01aa0000 fffff880`01aa9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0169a000 fffff880`016d4000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0937c000 fffff880`09384000   regi     regi.sys     Mon Apr 16 11:19:10 2007 (462393EE)
fffff880`048f6000 fffff880`0490e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02e3e000 fffff880`02e58000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`01184000 fffff880`011b3000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`093d2000 fffff880`093dd000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`040a1000 fffff880`040a3f00   SFEP     SFEP.sys     Fri Nov 27 00:39:13 2009 (4B0F6601)
fffff880`01654000 fffff880`0169a000   snapman  snapman.sys  Sat Apr 10 05:16:30 2010 (4BC041EE)
fffff880`0164c000 fffff880`01654000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01054000 fffff880`0117b000   spyz     spyz.sys     Wed Apr 07 21:29:00 2010 (4BBD315C)
fffff880`07e00000 fffff880`07e96000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07f95000 fffff880`07ffc000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`07f31000 fffff880`07f5e000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04a00000 fffff880`04a64000   stwrt64  stwrt64.sys  Thu Sep 13 11:30:19 2007 (46E9578B)
fffff880`04b10000 fffff880`04b11480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`093dd000 fffff880`093ef000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`01ac5000 fffff880`01ad2000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`013c6000 fffff880`013e4000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02e2a000 fffff880`02e3e000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00550000 fffff960`0055a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`039a9000 fffff880`039cf000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04b12000 fffff880`04b24000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`07d55000 fffff880`07d72000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`07d72000 fffff880`07d73f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`03f19000 fffff880`03f2a000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04b24000 fffff880`04b7e000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03ec3000 fffff880`03f19000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`10046000 fffff880`10053000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`07d88000 fffff880`07db5200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`011bd000 fffff880`011ca000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01a4b000 fffff880`01a59000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01a59000 fffff880`01a7e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`07f19000 fffff880`07f31000   vmci     vmci.sys     Thu Oct 22 05:26:48 2009 (4AE02558)
fffff880`040a4000 fffff880`040af000   VMkbd    VMkbd.sys    Thu Oct 22 06:51:05 2009 (4AE03919)
fffff880`07bbe000 fffff880`07bc8000   VMNET    VMNET.SYS    Mon Aug 10 08:04:50 2009 (4A800CE2)
fffff880`07bae000 fffff880`07bbe000   vmnetbridge vmnetbridge.sys Mon Aug 10 08:05:58 2009 (4A800D26)
fffff880`093ef000 fffff880`093f9000   vmnetuserif vmnetuserif.sys Thu Oct 22 06:17:07 2009 (4AE03123)
fffff880`017d3000 fffff880`017e3000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`092a6000 fffff880`0937c000   vmx86    vmx86.sys    Thu Oct 22 07:36:57 2009 (4AE043D9)
fffff880`0102a000 fffff880`0103f000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00f73000 fffff880`00fcf000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01600000 fffff880`0164c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`04ba8000 fffff880`04bfa000   VSTAZL6  VSTAZL6.SYS  Wed Oct 15 20:53:42 2008 (48F69096)
fffff880`07c7b000 fffff880`07d46000   VSTCNXT6 VSTCNXT6.SYS Wed Oct 15 20:52:22 2008 (48F69046)
fffff880`07a19000 fffff880`07b8d000   VSTDPV6  VSTDPV6.SYS  Wed Oct 15 20:57:45 2008 (48F69189)
fffff880`07f5e000 fffff880`07f6a000   vstor2_ws60 vstor2-ws60.sys Mon Oct 12 17:06:26 2009 (4AD39A52)
fffff880`04b8b000 fffff880`04b93000   wacommousefilter wacommousefilter.sys Fri Feb 16 13:12:17 2007 (45D5F401)
fffff880`045fa000 fffff880`045fca00   wacomvhid wacomvhid.sys Mon Sep 21 19:29:14 2009 (4AB80C4A)
fffff880`02e0f000 fffff880`02e2a000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01a7e000 fffff880`01a8e000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e69000 fffff880`00f0d000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f0d000 fffff880`00f1c000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02fd0000 fffff880`02fd9000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003b0000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`0117b000 fffff880`01184000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02fc5000 fffff880`02fd0000   ws2ifsl  ws2ifsl.sys  Mon Jul 13 20:10:33 2009 (4A5BCCF9)
fffff880`03e22000 fffff880`03e2d000   WsAudioDevice_383S_1_ WsAudioDevice_383S(1).sys Thu Jul 23 08:04:10 2009 (4A6851BA)
fffff880`07b8d000 fffff880`07bae000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`04000000 fffff880`04063000   yk62x64  yk62x64.sys  Mon Feb 23 10:02:27 2009 (49A2BA83)
Unloaded modules:
fffff880`0a21a000 fffff880`0a28b000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01bb7000 fffff880`01bc5000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bc5000 fffff880`01bd1000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01bd1000 fffff880`01bdc000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01bdc000 fffff880`01bef000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
gp2
Well-Known Member
Thanks so very much sir, 4 the light on this.
gp2
Well-Known Member
Still by the looks of it, my system is way too unstable. I will have to keep working like this.
Thanks again
You're welcome.
- To update Intel devices use Intel® Driver Update Utility in IE.
- To update Marvell look up its ID in windows device manager and use the ID to download from Marvell: Support
- Also visit your PC/motherboard support
- Wacom Mouse Wacom Hardware Drivers
- You can uninstall InterVideo if not using it
- Update Eset from eset.com/download
- Or you could use MSE instead https://www.microsoft.com/security_essentials/
Should crashes re-occur after you have updated those listed drivers, uninstall Mediafour MacDrive.
gp2
Well-Known Member
Thanks that appears to be working and I also used a ASO registry cleaner and it has stopped BSODing.
Still have Mediafour MacDrive. and NOD same version.
#7
If crashes reoccur, update all the mentioned drivers including NOD.
