Windows 7 Help with USB-UIRT
reghakr
In order to troubleshoot your problem we need to know more detailed specs of your system hardware.
1. Go to Start > Run, and type msinfo32, look under the Components section for hardware identification
2. Go to Control Panel > Device Manager and look for any entry that has a yellow flag beside it
3. The manufacturer name and model number of your PC, if applicable
4 Please fill out your computers specs in the User Control Panel here on the site as well. It will then appear next to your name. look at my posting and you'll see the drop-down arrow.
The exact make and model of your motherboard and TV tuner card would be of great help.
sudokujesus
when i go to msinfo it says its a problem device (the usb-uirt) and it says the drivers are not installed for it, but when i try to install the drivers from their website, it doesn't work.
