Windows 7 Help with Windwos 7 installation.
ccog
Okay, I screwed up badly. I had the Windows 32 bit RC build 7100, I wanted the 64 bit version after that.
So whenever I would insert the disc and restart computer, the installation screen comes up, I hit install now.
"No device drivers were found. Make sure that the installation media contains the correct drivers, then click OK." That's what comes up when I hit my Hard Drive. It says I can use it if I formatt it, so then I click that and it says "Windows can't format C. Check to see that the disk and drive are connected properly, make sure that th e disk is not read only, and then try again. For more information search Help for read-only files and how to change them."
Another problem, I wiped my hard drive (I can still access the bios and stuff.) Does anybody know how to fix this? I have a 500 GB SATA II Hard Drive.
Top Bottom
