lozzy123456
- Joined
- Nov 24, 2010
i was trying to install windows 8.1 preview and it downloads fine but when it says "gathering info" it hangs at 71%
reply ASAP
reply ASAP
Windows 8.1 Preview isn't currently supported on some tablets and PCs with newer 32-bit Atom processors, including:
- Lenovo ThinkPad Tablet 2
- ASUS VivoTab TF810C
- Samsung ATIV Smart PC
- HP ElitePad 900
- HP ENVY x2
- Fujitsu ARROWS Tab
Lozzy is your system in the list below:
If your system should be compatible then have you considered burning to disk and doing a clean install ( to be honest this is probably the best way to install windows 8.1 imo)
You can find the iso files for download here:
Windows 8.1 Preview ISO files - Microsoft Windows
it installedLozzy is your system in the list below:
