Windows 7 help
sholmes169
after installing windows 7 the install goes fine and then reboots and completes the install. the os restarts and the graphics card doesn't initiallise after that has anyone else seen this problem. if so does anyone know how to fix it.
reghakr
Well, if it's an older card, it may not be supported if you can get on the Internet, or if you have another computer.
You could always go to the Manufacturers website and look for updated drivers
Or....
Take a look at this page:
Engineering Windows 7
sholmes169
It's a 7600 gtx should be alrite. Will try updating the graphics drivers but in theory that shouldn't matter as they are wiped when you install a clean copy on an empty hard drive. Hmm bit of a puzzler. Will keep trying though
