help
hi i installed windows 7 but didnt know u had to partition the hard drive the instalation got to setup services and restarts then it says that the hard drive is in bad condition but i cant open any options such as bios or setup only thing i can do is press f1 to resume which does same thing wit services setup then goes back to the black screen with f1 resume plz can any help me cancel the install or sort the hard drive out plz
Are you booting up from the windows 7 CD? If so Remove CD and reboot. You may need to do a hard boot. Press and hold down power button on PC untill it turns off, let it set for a minute and then turn back on. Then try reinstalling your OS.
