Are these devices deliberately disabled? If so, why?Broadcom Virtual Wireless Adapter ROOT\NET\0000 This device is disabled.
Realtek PCIe GBE Family Controller PCI\VEN_10EC&DEV_8168&SUBSYS_85051043&REV_09\6&13BEB306&0&004800E7 This device is disabled.
Broadcom 802.11n Network Adapter PCI\VEN_14E4&DEV_4359&SUBSYS_850C1043&REV_00\6&3A39CE57&0&004000E7 This device is disabled.
Universal Serial Bus (USB) Controller PCI\VEN_1033&DEV_0194&SUBSYS_00011B96&REV_03\6&2B013E3C&0&003800E7 The drivers for this device are not installed.
Bluetooth module USB\VID_0B05&PID_17B5\0008CAE5F2F5 This device is disabled.
sptd.sys Sat Aug 18 17:05:38 2012 (503003A2)Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):[DEL] DuplexSecure - FAQ [/DEL]Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Link Removed - Invalid URL
[font=lucida console]**************************Sat Oct 27 11:39:01.289 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102712-28423-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:22:14.132[/B]
BugCheck Code: [B]BugCheck A, {680052a0cea, 2, 0, fffff800034c13fb}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_SEGMENT::SafeProbeAndLockPages+229 )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
Arguments:
Arg1: 00000680052a0cea, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff800034c13fb, address which referenced memory
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: [B]TESV.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_dxgmms1!VIDMM_SEGMENT::SafeProbeAndLockPages+229[/B]
CPUID: "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed: 3500
CurrentSpeed: [B]3510[/B]
BIOS Version 1206
BIOS Release Date 06/05/2012
Manufacturer System manufacturer
Product Name System Product Name
[/font]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
CLBUDF.SYS Thu Jul 15 06:05:36 2010 (4C3EDD70)
CLBStor.sys Thu Jul 15 06:05:41 2010 (4C3EDD75)
AsUpIO.sys Mon Aug 2 22:47:59 2010 (4C57835F)
ICCWDT.sys Wed Aug 18 04:27:45 2010 (4C6B9981)
AsIO.sys Mon Aug 23 21:53:02 2010 (4C7325FE)
rikvm_38F51D56.sys Fri Oct 29 06:52:09 2010 (4CCAA759)
CORSGKB.sys Mon Jun 20 22:38:24 2011 (4E000420)
BCM42RLY.sys Tue Jul 19 23:22:48 2011 (4E264A08)
mvxxmm.sys Mon Sep 19 07:31:37 2011 (4E772819)
mvs91xx.sys Mon Sep 19 07:31:51 2011 (4E772827)
mv91cons.sys Mon Sep 19 07:36:08 2011 (4E772928)
PxHlpa64.sys Mon Oct 17 10:29:34 2011 (4E9C3BCE)
asmtxhci.sys Wed Nov 2 23:00:22 2011 (4EB203C6)
asmthub3.sys Wed Nov 2 23:00:32 2011 (4EB203D0)
HECIx64.sys Wed Nov 9 19:52:25 2011 (4EBB2049)
avgidsdrivera.sys Fri Dec 23 07:05:21 2011 (4EF46E81)
avgidsfiltera.sys Fri Dec 23 07:05:40 2011 (4EF46E94)
avgmfx64.sys Fri Dec 23 07:08:12 2011 (4EF46F2C)
RTKVHD64.sys Tue Jan 3 05:51:09 2012 (4F02DD9D)
asahci64.sys Thu Jan 5 00:08:19 2012 (4F053043)
iusb3hub.sys Thu Jan 5 06:54:43 2012 (4F058F83)
iusb3xhc.sys Thu Jan 5 06:54:45 2012 (4F058F85)
iusb3hcs.sys Thu Jan 5 06:56:40 2012 (4F058FF8)
avgrkx64.sys Mon Jan 30 22:11:41 2012 (4F275BED)
iaStor.sys Wed Feb 1 19:15:24 2012 (4F29D59C)
LGSHidFilt.Sys Tue Feb 7 08:12:39 2012 (4F312347)
e1c62x64.sys Thu Mar 15 23:57:28 2012 (4F62BA28)
avgidsha.sys Wed Apr 18 22:19:15 2012 (4F8F7623)
GEARAspiWDM.sys Thu May 3 15:56:17 2012 (4FA2E2E1)
nvhda64v.sys Tue Jul 3 11:25:04 2012 (4FF30ED0)
avgldx64.sys Wed Jul 25 20:56:48 2012 (501095D0)
[COLOR=RED][B]sptd.sys Sat Aug 18 17:05:38 2012 (503003A2)[/B][/COLOR]
avgtdia.sys Fri Aug 24 09:20:13 2012 (50377F8D)
nvlddmkm.sys Tue Oct 2 14:21:13 2012 (506B3099)
[/font]
