helpp pls
what's wrong ?
plssssssssss help me
i want tis program work
Threads merged to save confusion, also title shortened.
no 1 understand ?
jeradw
Could you maybe explain in a little more detail what you are trying to do? I am unfamiliar with that program and the screenshot means nothing to me without some more background information.
Thanks! :rolleyes:
jeradw
I posted on your other thread...
this programe (switch sniffer) help me in my network
it let me know who download or browse
and wht speed he useing
and i can make his stop from downloading and browse
there alot programe work at them but me not
i don't know why
sry bad english
ok i post there too
#7
I don´t know this program, but to me, the .cpp files seems to be your parsers. Files that contains information about how to interpret the capture.
Seems that your program isn´t able to read the capture and interpret it.
Maybe instalation problem, maybe capture problem,
Anyway, why don´t you use Network Monitor that I´m sure it works on Windows 7 ?
Brgs,
#8
sry bad english
that why i need this 1
other 1 do same things ?
Trouble
Noob Whisperer
#9
Can't find out much about this program, it seems NextSecurity (the program publisher) has let their website expire so unless you have an email or phone number, or a link to some forums specific to the product, well....
Could be a problem with IPv6 in windows 7 turn it off and see
Could be a problem with the windows 7 firewall turn it off and see
Could be a problem that the software itself is not Windows 7 ready and is making some bad api calls but is not producing an error, at least not one that is a typical msgbox type error, do you have this running on anyother windows 7 boxes, does it work ok on them?
The reason I ask, is because most of the download sites where you can still acquire the software, list NT/2000/XP for system compatability, so that might be an issue.
#10
i setup windows xp for trying but have same
yes it work once in windows 7 by luck
i have old network driver
so i add it in my pc to try it with programe and it work
but netcut was not work so i setup winpcap
netcut work but the same problem back to switch sniffer
i try delet wipcap but still problem and netcut not work so i setup wipcap again netcut work but switch sniffer not
i try remove my network driver and add it again like before but this time not work
so if i setup windows like old windows then i put suddenly new old network driver will programe work like before ?
or it was just luck or i do something else without note
#11
sry bad eng
#12
It looks like your software isn´t able to comunicate with your network interface.
OpenAdapter : EXCEPTION!
SendPackage : EXCEPTION!
I would try some things . ..
Have you tried running your software in Windows XP compatibility mode ?
Do you have other network interface, that you could plug and try to use it ? Maibe with another driver, your software can work.
Have you tried using the latest version of WinpCap ?
This software is trying to send Spoofed packages. Most Lan cards nowadays are able to do that. But if your card doeasn´t support it ?
I´m not trying to solve your problem, but I´m giving you some ideas, so we can think together ...
Let´s try
#13
Let´s try
ok let's try
i try xp compatibitiy mode but same problem
yes i have 1 other i try first time work but when i setup winpcap not work anymore
yea i using last version of winpcap 4.1.1
my lan card is Realtek PCIe GBE Family Controller i don't support or not
Trouble
Noob Whisperer
#14
See if you can use device manager to determine the actual Realtek chipset, if it is one of these
RTL8111B/RTL8168B/RTL8111/RTL8168
RTL8111C/RTL8111CP/RTL8111D(L)
RTL8168C/RTL8111DP/RTL8111E
RTL8105E
Then go here Realtek and download the windows 7 driver for it.
#15
ok i downloading and will setup it
then try
Windows Forum Admin
Microsoft MVP
#16
Threads have been merged to save confusion. Please do not double post.
Thankyou.
#17
same problem still
i think it's very hard problem we can't do anything with it
what ever if any1 can help or wanna try something i here
#18
up
help pls :(
