Windows 7 Home Group, sharing certain folders do not work
Garethp
Hey, I have a PC running Enterprise 32 Bit which created the homegroup, and a table running the same. They're both on the same home group, and the Tablet can see the PC's library, but when I share my music folder (on the desktop) with Homegroup (read and write or just read, it makes no difference), the Tablet can't see that folder.
Check everything again
Hi!
I`m using home group and sometimes there are little bugs. However, just try something different, for example add the folder to some library that you are sharing and check if it works. Check everything again.
For more info about setting up home group check this page.
Hope you can find the answer ;)
Top Bottom
