Hi, another homegroup problem here. Basically, I can create a homegroup on either of my two computers, but I can't join them. It'll just say 'there are no homegroups in this network'.
I've followed all the instructions here, including disabling mcafee and norton which seems to be a commonly suggested solution. Still doesn't work. Maybe I didn't disable mcafee and norton properly? (I opened Start, searched for 'services.msc', clicked services and disabled the programs.)
Then I came across Link Removed - Invalid URL which brought up something I hadn't done, i.e. disable WLAN partition. Apparently WLAN partition prevents computers from communicating with each other even if they're linked by the same wireless network. Assuming WLAN partition is the only thing standing in between me and homegroup awesomeness now, could anyone tell me how to follow this instruction:
And/or if there're other things I should be doing, please tell me. Help is much appreciated!
1. Login to DIR-600 setup page, default url is http://192.168.0.1, default username is admin and empty password.
