Homegroup Problem IPv6
I have installed Windows 7 on my PC and laptop.
One problem I have though is that I have created a Homegroup on my PC, I have a password and all seems fine, but on the laptop it does not recognise that there is a Homegroup on the network.
If I try to create a Homegroup on the laptop I get the message: "Your network connection must have IPv6 enabled to create or join a homegroup. To enable IPv6, start the HomeGroup troubleshooter."
The thing is, I DO have IPv6 enabled!!
Any ideas?
Joe S
Did you create Homegroup on the laptop too? If not try that. I didn't mess with home group.
Joe
I was reading about this and several people said that disabling ipv6 would likely cause problems
If you google Ipv6 you'll find a lot to read. There is a thread here about disabling it.... use the search and try the reverse of what they say disables it.
Thanks for the replies - this has been solved.
My laptop was on a different workgroup to the PC. There were a few other things too but I'm not too sure. I had a computer whiz look at it and he solved it.
