- Joined
- Apr 15, 2009
- Messages
- 47,191
- Thread Author
- #1
- Joined
- Mar 14, 2023
- Messages
- 39,398
HOMEMADE SCREW TANK WATER TEST In the latest creation by Colin Furze, viewers are treated to the ambitious "Homemade Screw Tank Water Test." This project showcases Colin's innovative approach to building a functional tank that can navigate over both land and water.
Overview of the Project
The video begins with Colin introducing the concept of screw tanks, which are designed to float on water, making them versatile for various terrains. While his current design lacks buoyancy, Colin is determined to modify it to enable flotation. He emphasizes the need to improve the weight distribution of the tank, moving components such as the engine and oil tank to balance the center of gravity better.Key Modifications
Colin's plans include:- Enhancing buoyancy by constructing a proper base beneath the tank, allowing it to float.
- Adjusting the seating position and engine placement to shift weight forward.
- Using a bead roller to create a flat bottom, which is crucial for stability on water.
