Windows 7 how can i get volume control on task bar ?
hello i have just installed windows 7 ultimate on my hp laptop but i cannot see the volume icon,any ideas how i can put it to the task bar please ?
thank you.
patcooke
Microsoft MVP
Microsoft MVP
Right click on the Windows 7 orb, select Properties, Task bar, customize and pick which ones you want.
thank you.
Click on the icons notification area in the tray, or start menu > properties > taskbar, and choose "Customize".
i did what you said and volume says show icon and notifications ?
Yes, that's what you need to set for the sound icon, show icon and notifications.
ok thank you.
