srleslie
Every time I touch my laptop in the wrong place the DVD drive opens. That's annoying. But not half as annoying as the fact that, when I close the drive, Windows Media Player interrupts whatever it's doing to start whatever disk in it. I have AutoPlay in Control Panel set for "Take no action" in every case, but it makes no difference. Control Panel/Default Programs/Set your default programs/Windows Media Player shows it has "all its defaults" and clicking on "Choose defaults for this program" yields a long list of checkboxes all filled in and totally resistant to any efforts to uncheck them.
I'm the sort who puts a manual choke in every car he owns, and I hate AutoPlay. Can someone tell me how to make it go away? Or is there something else I need to do here?
Windows 7 Home Premium x64 on a Celeron laptop.
The attachment comes form the Windows 7 Help and Support section and describes Autoplay and Autorun. There are some internet sites that describe turning off Autorun, but some do not include Windows 7 and the iniFileMapping work around is not suggested due to side effects.
So, it appears the answer is you may not be able to turn Autorun off. Maybe someone else will have a different answer.
Holding down the shift key when inserting the media might be an alternative, doing that may not even still work.
Thanks. I suspected an important distinction between AutoPlay and AutoRun, and this verifies it. The fact that "Autorun is incorporated into the media types that use it..." would bolster the sad news that it may indeed be un-turn-off-able. Thanks a lot, once again, Microsoft.
The shift key, alas, has no effect.
I use this page Link Removed to make my Autorun work again after it has been "disabled". I'm assuming that doing the reverse of what I use it for will disable it! Note the reg codes!
Hmm, worth a try. But didn't work. Set Registry bit to 0 as specified, restarted computer, checked that change "stuck," Autorun still ran when DVD inserted into drive.
Damn! I hate it when that happens (i.e. nothing!!).
Sorry but that is about my best shot!!
