Windows 7 How do you manually remove virtual ROMs/Devices
SirBehl
So I've known for a while that the problems I had with my computer were from Daemon Tools and when I was looking for a replacement I got bluescreens again so I uninstalled everything but I'm still having a problem now and I think it's because of the virtual devices or whatever it's called left from whatever program I was using but I can't remember what program I used to install those things on and you can't just remove them with another type of software so they are stuck on my computer and I don't know how to remove them. Right clicking and pressing eject doesn't work either. DVD.png
Alright so I found out how to do it so now I'm wondering which drives I should disable. I'm pretty sure the first two are fine but I'm not sure if the third one I should disable too.
Top Bottom
