Windows 7 how to connect two routers over VPN
macedonia
Active Member
Can someone help me how to connect two routers over VPN, the routers are on two different locations and can be run like one network .
Saltgrass
If I even understand it correctly, the VPN is a tunnel between 2 specific devices. The devices have to be VPN capable and use the IP address associated with the VPN.
In the Network and Sharing Center, if you select to set up a connection or network at a workplace, it will take you through the process for setting it up using your VPN connection.
If you have tried that process and are having problems at a certain point, perhaps if you tell us where the problem is happening, the situation could be resolved.
