B bugmenot123 Banned Joined Nov 2, 2008 Messages 60 Nov 2, 2008 Thread Author #1 Hi how do I obtain windows 7 pre beta Thank you
Solution Matt Nov 2, 2008 If you go to WinHEC, you can get it. The only other way to get it is to pirate it, which will not be discussed here. However, you might want to keep a eye at Microsoft Connect for a beta in a few months.
R Rulerz New Member Joined Oct 28, 2008 Messages 14 Nov 2, 2008 #2 Yup i want to know aswell. Upvote 0 Downvote
K Kyle New Member Joined Feb 7, 2008 Messages 1,634 Nov 2, 2008 #3 The best way to get it, is directly from Microsoft. But good luck with that. =P Last edited: Nov 2, 2008 Upvote 0 Downvote
Matt Senior Member Joined May 7, 2007 Messages 861 Nov 2, 2008 #4 If you go to WinHEC, you can get it. The only other way to get it is to pirate it, which will not be discussed here. However, you might want to keep a eye at Microsoft Connect for a beta in a few months. Upvote 0 Downvote Solution
