Windows 7 how to install 32bit driver for x64 system
D3adM4n
because the driver for usb Kingsun KS-959 IrDA there is only 32bit version.:(
You could try to let Windows Update locate the driver automatically for you or check the manufacturer's website for 64-bit drivers.
Should you require additional assistance and guidance, Microsoft does have an official Windows 7 Support Forum located here Link Removed . It is supported by product specialists as well as engineers and support teams.
Jessica
Microsoft Windows Client Team
Jessica
tnx for help. I tried all from this ideas, but there is only 32bit driver:( that is so unfortunately.
I was search for this more then 5hour on G.
