VIDEO How To Make/Crimp RJ45 Ethernet Network Patch Cables (Cat 5e and Cat 6)
whoosh
Cooler King
:up:
How To Make/Crimp RJ45 Ethernet Network Patch Cables (Cat 5e and Cat 6) In today's tech-centric world, understanding how to make and crimp your own RJ45 Ethernet network patch cables is a valuable skill. The video tutorial titled "How To Make/Crimp RJ45 Ethernet Network Patch Cables (Cat 5e and Cat 6)" provides a clear and engaging guide on this practical task.
Overview​
The video starts with an introduction to the benefits of creating your own cables, emphasizing the convenience of having cables tailored to your specific needs—no more excess lengths tangling around your workspace. It highlights the affordability of purchasing a spool of Cat 5e or Cat 6 cable, with around 1000 feet typically costing around $100.
Tools Required​
  1. Ethernet Cable: A spool of either Cat 5e or Cat 6.
  2. Crimping Tool: Essential for cutting and crimping; these can be found for about $15.
  3. Crimp-On Connectors: You’ll need one for each end of your cable.
    Step-by-Step Process​
  4. Measure Your Cable: Measure the length necessary for your setup. Custom lengths can help avoid excess slack.
  5. Cutting the Cable: Use the crimper's cutting section to trim the cable.
  6. Stripping the Cable: Strip about an inch of the outer casing off both ends using the stripper's groove.
  7. Untwist Pairs: Inside the cable, you’ll find pairs of wires that need to be untwisted and straightened out.
  8. Wire Order: Organize the wires in the following order for standard Ethernet:
    • White with Orange Stripe, Orange
    • White with Green Stripe, Blue
    • White with Blue Stripe, Green
    • White with Brown Stripe, Brown
    []Insert Wires: Fit these wires into the crimp-on connector all the way until you can see the copper at the end. []Crimp the Connector: Place the connector in the crimping tool and squeeze until you hear a click, securing the connection.
  9. Testing: It’s advisable to test the cable using a cable tester, especially if you're planning on making multiple cables.
    The tutorial captures not only the instructions but also the subtleties of crafting your cables efficiently, saving money in the long run. The ability to create custom lengths tailored to your environment is a significant advantage. Have you ever attempted to crimp your own cables? What challenges did you face? Share your experiences and tips below! And for tips on other tech DIY projects, feel free to explore more threads in our community.
