Windows 7 How to open pinned WinExplorer with a certain pre-selected and auto-expanded directory?
pstein
In Windows XP I put a shortcut to WindowsExplorer on the desktop resp. the QuickLaunchBar
and specified in the properties the following opening command:
%SystemRoot%\explorer.exe /n,/e,D:\work
When I clicked on this shortcut WinExplorer opened with the pre-selected and auto-expanded directory D:\work.
Now in Win7 this does not work any more.
When I right-click on the pinned WinExplorer icon in TaskBar there is no context menu entry "Properties" and hence no entry field where I can enter the opening command and pre-selected directory.
How else can I achieve the same effect as under WinXP?
Peter
Create a shortcut for whatever you need -> right click the shortcut -> pin to taskbar.
Or pin notepad, then right-click it -> properties -> change target path.
Enjoy.
Enjoy.
