Windows 7 How to split one ISP IP address with a switch?
freshmeat30
Trying to get two computers running on one IP through a simple dynex switch. Can comp 2 mimic the ISP's address?
Edit: Or could I manually assign the homegroup an IP for the ISP and split it from there like a router? Trying to do this without a router.
You can of course try anything you want to try, it's your equipment, but I can tell you that it will not work reliably, because MAC address have to be unique on a single network segment (broadcast domain) or the return packets will not be able to determine the proper return path. You'll almost certainly begin getting errors right away.
Nope, I don't think you are going to have much luck with that approach.
If you have two network cards in one of the computers (or can add a second card) your best bet would probably be to use....
Internet Connection Sharing
Is there way to trick the IP to be recognized as the ISP IP on both computers? Cut the bandwidth in a way I guess?
As I said originally, I don't think so. Most if not all ISPs provide (unless you pay for more) one single IP address and it is applied to and identified with a particular MAC address. So even if you could somehow manage to clone the MAC address of one to the other the network would go toes up if you tried to use them simultaneously since Media Access Control addresses need to be unique on a single network.
Yes your right. I changed the comp2 MAC to match comp1 through registry and my comp actually detected comp1's network adapter for a second. Both computer now say theres internet, but comp2 won't load websites etc.
