busydog
- Joined
- Feb 11, 2009
This might be worthy of a sticky
From keznews......
How to Upgrade Windows 7 RC/Beta to Windows 7 RTM
1. Mount Windows 7 RTM Build 7600 ISO and Extract content to any folder or USB drive
2. Now go to Sources folder of Windows 7 and open “cversion.ini†file in notepad
3. Modify the “MinClient†build number to a value lower than your installed Windows 7 Build. For example, change 7233 to 7000 if you have Windows 7 Beta Build installed.
[HostBuild]
MinClient=7000.0
MinServer=7100.0
4. Save the updated file to the same location and then run setup.exe to start Windows 7 RC upgrade process.
That’s it, Now follow on Screen instructions and choose Upgrade option.
From keznews......
[HostBuild]
MinClient=7000.0
MinServer=7100.0
