The thread focused on how EPC contractors can centralize end-to-end workflows (engineering/BOQ changes, procurement and subcontracting, site execution, and billing/costing) using Dynamics 365 Finance & Operations, Business Central, or related Microsoft tools. The main guidance was that Business Central can work for lighter EPC needs, but a “true EPC” setup typically fits better with the broader Dynamics 365 Finance + Supply Chain Management + Project Operations stack, using SharePoint/engineering systems for document control and Engineering Change Management to govern BOM/BOQ revisions into procurement and operations; RA bills, progress measurement, and change-order/commercial workflows were flagged as areas often requiring ISVs or targeted Power Platform/customizations. Overall sentiment was pragmatic and optimistic about Microsoft’s capabilities, with an emphasis that success depends more on data/process governance (source of truth for revisions, WBS/package structures, and progress) than on the software alone.
Hi everyone,
I’m researching how EPC (Engineering, Procurement & Construction) companies can streamline their entire project lifecycle—starting from design and BOQ creation to procurement, subcontractor management, site execution, billing, and project costing. Traditionally, EPC teams work in silos using separate systems for engineering, procurement, finance, and site operations, which often leads to rework, timeline slips, material delays, and significant budget variation.
I’m curious to learn from anyone who has tried to centralize these workflows using Dynamics 365 Finance & Operations, Business Central, or any related Microsoft stack tools.
Specifically, I’d like to know:
1. How do you integrate engineering data (drawings, revisions, BOM/BOQ changes) into D365/BC workflows?
2. Are there recommended ISV solutions or customizations that support EPC-specific needs like change order management, subcontractor billing, RA bills, or progress measurement?
3. How well does Dynamics handle complex procurement cycles involving multiple vendors, long lead times, and material tracking across multiple sites?
I’d appreciate any firsthand experiences, architecture suggestions, or practical recommendations from consultants, partners, or users who have worked with EPC project scenarios in the Microsoft ecosystem.
Thanks in advance for sharing your insights!
Hi Allen,
For true EPC scenarios, my practical recommendation is usually:
Short answer​
  • Dynamics 365 Finance + Supply Chain Management + Project Operations is the better Microsoft-core stack for EPC than Business Central when you need engineering change control, complex procurement, subcontracting, progress billing, and multi-site material control. Microsoft’s native stack already covers engineering change management, product/BOM governance, subcontract purchase orders, vendor invoicing, milestone/progress billing, and Finance integration.
  • Business Central can work for smaller contractors or lighter project-accounting use cases, but once you have heavy BOQ revisions, long-lead procurement, subcontractor...
Hi Allen,
Short answer​
  • Business Central can work for smaller contractors or lighter project-accounting use cases, but once you have heavy BOQ revisions, long-lead procurement, subcontractor billing, and site-level controls, it usually becomes an architecture/customization exercise rather than a clean fit.
  • The winning pattern is usually engineering system + Microsoft 365/SharePoint + Dataverse + D365 SCM/Finance/Project Ops, not “put all engineering authoring inside ERP.” Product/engineering data can be distributed through Dataverse and linked into downstream apps, while document control stays in Microsoft 365/SharePoint.
1) How to integrate engineering data into D365 / BC workflows​
The cleanest pattern is:
  • Keep design authoring in the engineering tool
  • CAD, drawings, model files, and detailed revision packages usually stay in PLM/CAD/document-control tooling.
  • Use SharePoint / Microsoft 365 for controlled document storage, versioning, approvals, and distribution to project teams.
  • Push the ERP-relevant engineering objects into D365 SCM
  • In D365 Supply Chain Management, Engineering Change Management is designed for engineering product versions, BOM changes, engineering attributes, workflows, impact analysis, and release of product structures to operational companies. It supports engineering change requests/orders, product versioning, BOM changes, and impact checks on open transactions and inventory.
  • Engineering attributes let you classify and search products by technical characteristics, which is useful for spec-driven EPC materials and equipment.
  • Use released product / BOM / category data as the BOQ-to-procurement bridge
  • Product Information Management in SCM is the anchor for item master, product structures, and distribution of product definitions to other business apps through Dataverse.
  • In practice, your BOQ becomes either:
  • project-related procurement demand, or
  • item/service structures tied to project WBS and procurement categories.
  • Treat revisions as controlled business events
  • Engineering changes should not directly overwrite live procurement/project data.
  • Use engineering change workflows so revised BOM/BOQ structures are reviewed, impact-assessed, then released to operational entities in a governed way. That is exactly what Microsoft’s engineering change model is meant to handle.
Practical architecture​
A common Microsoft-centric EPC architecture looks like this:
  • Engineering/CAD/PLM for drawings and authoring
  • SharePoint for revision-controlled documents, transmittals, and approvals
  • Dataverse / integrations for business object synchronization
  • D365 SCM for item master, engineering product versions, procurement, inventory, logistics
  • D365 Project Operations + Finance for subcontracts, costs, project actuals, milestone/progress billing, and financial posting
  • Power BI for project controls dashboards
  • Power Apps / Field tools for site progress capture, inspections, quantity confirmation, and issue logging
2) ISV solutions or customizations for EPC-specific needs​
This is where I’d be careful and realistic:
What Microsoft handles natively reasonably well​
  • Subcontract purchase orders in Project Operations integrated with Finance.
  • Vendor invoicing for subcontracted services/materials with project cost posting.
  • Invoice schedules / milestones / progress billing constructs in Project Operations and Finance.
  • Field-to-project-to-finance actuals flow when Field Service is part of the operating model. Microsoft documents a continuous pipeline from work order/material usage to project actuals to pro forma invoice to Finance posting.
What usually needs ISV or controlled customization​
For EPC-specific processes, native Microsoft often needs help in these areas:
  • BOQ import, version comparison, and revision lineage
  • Change order management tied to commercial variation orders
  • RA bills / running account bills
  • Subcontractor measurement sheets and certification workflows
  • Physical progress measurement by activity/area/discipline
  • Client billing formats dictated by local contracting practice
  • Material issue/return/wastage tracking at site package level
My practical recommendation​
  • Use native D365 capabilities first for:
  • procurement
  • subcontract POs
  • vendor invoicing
  • milestone/progress billing
  • project costing
  • Add targeted ISV or Power Platform layers only for the EPC-specific gaps above.
  • For RA bills and progress measurement, I would expect either:
  • a strong vertical ISV, or
  • a partner-built Power App / custom extension tied into Project Operations and Finance.
I’m deliberately not naming a specific ISV shortlist here because I don’t have a reliable, current, official Microsoft-sourced EPC AppSource ranking in front of me. In real projects, this is one of the most partner-dependent decisions, and I’d evaluate AppSource plus partner references by country and contracting model.
3) How well Dynamics handles complex procurement, long lead times, and multi-site material tracking​
Strengths​
Dynamics is quite strong when you use the right modules:
  • Procurement and sourcing depth
  • D365 SCM is built for procurement processes, product information, and inventory/logistics at enterprise scale.
  • Engineering-aware procurement
  • Engineering changes can assess business impact on open transactions and inventory before release. That matters when a revised BOM hits items already on order or in stock.
  • Subcontract and project procurement
  • Project Operations with Finance supports subcontract purchase orders and vendor invoice flows tied back to projects.
  • Milestone/progress billing
  • Project Operations and Finance support invoice schedules and project billing schedule scenarios that map reasonably well to milestone-based EPC billing.
Limitations​
Where EPC teams usually struggle is not basic PO creation; it is the control model:
  • multiple vendors for the same package
  • package-level revision changes after award
  • expediting long-lead items
  • site-wise allocation and transfer visibility
  • material reconciliation against measured progress
  • subcontractor-certified quantities vs. planned quantities
  • localized billing/commercial rules
Those are solvable, but usually through a combination of:
  • D365 SCM + Project Ops core
  • a disciplined data model
  • package/WBS structure
  • Power Platform apps for field capture
  • selective ISV or custom logic
What I would implement in practice​
If I were designing a Microsoft-stack EPC solution, I’d structure it like this:
  • Engineering control
  • SharePoint for document revisions and approvals
  • SCM Engineering Change Management for ERP-impacting revisions
  • item/BOM release rules so only approved revisions affect procurement and operations
  • Commercial/project structure
  • Project Operations for WBS, contracts, subcontracts, actuals, milestones, billing
  • Finance for accounting, cost recognition, vendor/customer invoicing
  • Procurement and logistics
  • SCM for item master, procurement, inventory, inter-site movement, warehouse controls
  • package/vendor/lead-time dashboards in Power BI
  • Site execution
  • Power Apps or Field Service-based capture for:
  • daily progress
  • installed quantities
  • material consumption
  • subcontractor measurement sheets
  • NCR / issue logging
  • Reporting
  • Power BI for:
  • planned vs actual cost
  • procurement aging
  • long-lead material status
  • subcontract billing vs progress
  • quantity earned vs quantity billed
My candid view: F&O stack vs Business Central​
  • Choose D365 Finance + SCM + Project Operations if you are a serious EPC firm with:
  • engineering revisions
  • multi-site material movement
  • subcontract-heavy delivery
  • client milestone/progress billing
  • governance and audit needs
  • Choose Business Central only if your EPC process is lighter, your entity count is smaller, and you’re comfortable relying more heavily on partner extensions/customization.
Biggest lesson learned in these scenarios​
The hardest part is usually not software screens. It is the data ownership model:
  • Who owns item master?
  • Who owns BOQ revisions?
  • What is the contract/package/WBS structure?
  • What is the source of truth for progress?
  • When does an engineering revision become a procurement change?
  • How are client variations and subcontract variations linked?
If you get that governance model right, Microsoft’s stack is workable.
If you do not, even a very capable ERP will just make the silos faster.
If you want, I can next give you one of these:
  • a reference architecture for EPC on the Microsoft stack,
  • a module-by-module fit of Business Central vs Finance/SCM/Project Operations, or
  • a gap list showing which EPC processes are likely native vs ISV vs custom.
The most useful next step would probably be #2: BC vs F&O/Project Ops fit for EPC.
Mark Mckinney
Active Member
Hi everyone,
Dynamics 365 can support end-to-end EPC (Engineering, Procurement & Construction) project management quite well, but the level of capability depends on which Dynamics applications are deployed. For mid-sized EPC firms, Dynamics 365 Business Central often provides a strong foundation, while larger and more complex EPC organizations typically benefit from a combination of Dynamics 365 Finance, Supply Chain Management, and Project Operations.
Engineering Integration
Engineering data such as BOMs, BOQs, drawings, revisions, and design documents can be integrated into Dynamics workflows through Microsoft tools like SharePoint, Power Platform, and third-party engineering systems. This enables teams to maintain a controlled process for managing design changes and ensuring that engineering updates flow into procurement and project execution activities.
Procurement Management
Dynamics 365 offers robust procurement capabilities including purchase requisitions, vendor management, approval workflows, contract management, material tracking, and inventory control. EPC organizations can automate procurement cycles, manage long lead-time items, monitor supplier performance, and track materials across multiple project sites. This helps reduce delays and improve supply chain visibility.
Project Execution and Cost Control
Business Central supports project accounting, budgeting, resource planning, job costing, milestone billing, and profitability analysis. Real-time dashboards help project managers monitor budgets versus actual costs, resource utilization, project progress, and financial performance. For more advanced project-centric operations, Dynamics 365 Project Operations adds comprehensive project planning, forecasting, and execution management capabilities.
Change Orders and EPC-Specific Requirements
A common challenge in EPC projects is managing change orders, subcontractors, progress billing, and running account (RA) bills. While Dynamics provides core workflow and financial controls, many EPC companies enhance the platform with industry-specific solutions or Power Platform customizations to address these specialized requirements.
The Role of Alletec
For EPC organizations looking for a ready-to-deploy industry solution, Alletec's EPC 365 extends Microsoft Dynamics capabilities specifically for the engineering and construction sector. The solution connects finance, engineering, procurement, construction, and project management processes on a unified platform. Key features include BOQ-driven procurement, budget-aligned purchasing, project risk governance, cost tracking, resource planning, supply chain optimization, and real-time project visibility
