HP Officejet 8500
While I can print with this new HP printer not all of the functions (for example, imaging) are available within windows 7, 64 bit. Does anyone know of a updated driver?
I am in the same boat with the same printer. I have been searching all over the place trying to find a solution. I sure hope HP releases the update soon or I will have to revert back to Vista as I NEED reply on the HP Software on a daily basis!
vbman
HP OfficeJet 8500 Install on Windows 7
For this to work correctly, you need to follow the following instructions:
IT Design Concepts: Forums / Printers / HP OfficeJet 8500 Install on Windows 7
There is an installation issue with security and all functions won't work if the install instructions aren't followed. It never gives you any warnings of install issues either, so you don't have a clue if it installed correctly or not. :(
