Windows Vista I promise you cannot solve my wireless problem!
cs19
I'm sorry for the long post, but as the title promises, I'm betting no one out there can solve my problem (and re-installing vista is not a "solution" by my definition). I wanted to give you every little detail so you can understand and appreciate the extent of my situation.
I purchased a Latitude D620 with the Dell WLAN 1390 mini-card. It shipped about a year ago with XP Pro (and has the "Windows Vista Capable" sticker).
I then upgraded to Vista Business. This was a clean install - from the disc with a complete repartitioning of the hard drive. All my drivers are 100% up to date.
The Problem
I started losing my wireless randomly, getting the red X over the wireless icon in the system tray. This happens at different wifi locations - it is not unique to one location. I'll just be surfing the net and suddenly things cannot load, and I see the wireless has a red X in the system tray. I may also leave my computer (with working wireless) just sitting there for 5-10 minutes doing nothing, then come back to find the wireless gone and the red X in the system tray. What is interesting is that when this happens, i can single-left-click and choose the "connect to a network" option. It pulls up the window and says "Windows cannot find any networks." This is strange because in many of the places this happens (like at home), there are easily 10+ different networks available. So it's not dropping just my one connection, it is saying it cannot find ANY network. This also happens at school where there are access points galore and the ten people next to me on their laptop's wifi have no problem. If I leave the Red X and try to run diagnostics or check the driver in the device manager - everything always comes back that it is working properly even though it cannot find any of the 10+networks in range.
My unacceptable workaround:
There is the hard switch on the left of the D620 to kill power to the wifi card. Turning this off then on does nothing. It turns off the Wifi LED on the D620 above the keyboard, and then turns it back on. The system tray red X does not change. Only three things resolve this problem: a restart, going into standby and coming back out, or disabling then enabling the network card via the device manager.
I then upgraded to Vista Ultimate. This was just an upgrade, no re-install or re-partitioning. Exact same problem. Sometimes I go two or three days without the problem, sometimes I have it happen 3 times in 5 minutes. it is VERY annoying. I'll just be surfing the web and click a link and get "page cannot be displayed." I look down at the system tray and suddenly notice the red X popped up.
Failed Fix #1
On the first three calls to Dell they have connected to my computer and tweaked various wireless settings. They always make sure drivers are up to date (and they are). I have tried using my laptop with Dell Quickset installed, and with Dell Quickset UNinstalled - doesn't change a thing. Have even tried uninstalling the "correct" dell driver and letting Vista handle the wireless card by itself - doesn't change a thing. I have tweaked my power settings to about every possible combination (and this happens both on battery and when plugged in). Nothing worked.
Failed Fix #2
After a third service call I was sent a NEW 1390 WLAN mini-card. Even that did not change a thing.
Failed Fix #3
After the fourth call my laptop was sent in to have both the wireless card replaced as well as the antenna. Again, this did not solve the problem.
Failed Fix #4
After calling Dell again to say the antenna fix didn't change a thing, I was given some vague comment about maybe having problems with WLAN 1390 and vista (which I think is not true). So... they 'upgrade' me for free and send a Dell WLAN 1490 card in the mail. I pop that guy in... problem still persists.
Blame Vista:
So, of course, Dell now says that it must be a Vista problem, as they have replaced all the hardware related to the wireless card. Their solution: do a clean re-installation of vista. I could do this, but it is a total pain to have to back everything up and then re-tweak all the various windows and program settings all over again. I'm in school, finals are coming up, then I have some trips (where I need my laptop working). I don't have a full day to spend backing everything up and then re-installing vista and then re-personalizing everything... not to mention downloading every program I use like Firefox and re-installing every program I use like Microsoft Office.
Some Final Thoughts:
So this problem is across Vista Business, and Vista Ultimate. The card has been replaced and upgraded. The antenna has been replaced. The software/driver/power combinations have been changed around to every possible combination. Absolutely nothing has resolved this. As such, I have been unable to isolate the problem.
The other problem is that I have not found a way to automatically replicate the problem. I have been dealing with this at an annoying rate for months because i'll try something (like changing some software or a driver or the card) and I have to wait to see if the problem will reappear. I can't just change something and then immediately check to see if it solved the problem. the problem may show itself later that day, or maybe not for 2 or 3 days... only at that point can I determine that the fix didn't work.
I am more knowledgeable about computers than your average joe and can assure you that I have made sure there are no viruses, etc. causing this problem. I might also add that this happens on both secure and unsecured networks.
I am at a total loss at this point and have no idea what to do. Anyone have ideas? Anyone think this is or is not Vista?
if the wireless worked fine in xp, then its obvious that vista is the culprit.
vista is written in a diff code. i've found that pure vista machines can't handle xp if downgraded.
like wise, there are issues with upgrades to vista, moreso, to vista.
if you really need to get down to business, i'd get the dell restore disk out, and go back to xp.
vista will be replaced soon by a new os, in 2009.
vista has been considered the 'millenium' of xp upgrades, just a candy coat.
kj
computer corrections
cookson, ok
p.s.
i sure wish i had the lapper here. i have a 100% fix success over the last 10 yeard. it would be fun
Hmmm. Well my only thought in response is that just a month or two ago, before the D630 came out, I was able to go on the Dell website and do a custom configuration of a D620 that was part-for-part the same as my computer. Unless they changed out the motherboard, it seems there is no difference between a "pure vista" machine sold by Dell in early 2007, and my "Windows Vista Capable" machine sold in September 2006.
Unless I get a solution on this forum, it looks like I'm in for a clean reinstallation of vista on some coming weekend. I just hope that solves the problem. Otherwise, I'm going to have quite a fight when I call up Dell and tell them they need to replace my entire notebook.
Well i would reinstall the windows xp again to see if you get back your normall connect that u where getting before but to me it sounds like your wireless cards is dying on you and you should get it repair before your 1 year is up with dell :D it can happen hardware is meant to last 2 to 3 years but u know yourself hardware can just die
did you ever end up fixing problem? I have same issue on my dell
Same laptop, same issue, but in XP... Never tried Vista.
I get random disconnects & trouble reconnecting which is annoying to say the least. I compared to an IBM Thinkpad (XP), and a desktop (XP) with a wireless PCI card - both of which had no trouble with the same network...
Well I might as well say upfront that I don't care much for Vista but I must admit that I've never had trouble with my wireless connection and that I use wireless 100% of the time.
I'm using Intel Pro wireless abg&n. I've noticed on this forum and on another (photography) forum that many people with wireless Vista problems are using Dell laptops.
Could there be a Vista comptability problem with the brand of card they are using? Or maybe the antenna Dell is putting in their laptops?
I got the same problem on Dell D630 running Vista Ultimate. So annoying!!!
Has anyone switched out the motherboard? I did not see that step in the OP message. The slot for the WLAN card could be damaged or underpowered due to a fault on the MOBO. I have seen a case recently where a starved MOBO has funky issues like USB dying and peripherals dying due to the power supply being inadequate.
Since people have had issues in both XP and Vista, I'm inclined to think the culprit is something in the laptop itself.
IT WAS THE MOTHERBOARD!!!
So after all that above (and some more) Dell finally sent me from the wireless support to hardware support to replace the entire motherboard. That was about 6 weeks ago and I have not had the problem reoccur a single time.
I ran in to this problem as well when I was beta testing Vista and then when it was officially release. I called Microsoft and after 4hrs on the phone we came up with a fix. You have to edit the registry, so go to regedit.
HKey_Local_Machine\System\CurrentControlSet\Services\Tcpip
Highlight the Parameters folder and add a new Key.
The key has to be DWORD, name the Key ARPRetryCount, and set the value to 0.
That should get the machine connected to the domain and allow you to add all domain assets to your local security listings.
Greg
I have a similar problem as the OP. Everex laptop running Vista Home Premium. In the last couple of months, whenever IE7 decides it doesn't like a webpage (certain ebay pages for instance), IE7 may or may not crash, but in either case I lose my wireless network and I can't reconnect ("windows cannot find any wireless network"). I have to reboot the computer to get my wireless network back. If IE7 doesn't encounter a problem webpage, I can stay connected all day. (IE6 on my XP machine has no problem with the same webpages BTW).
So... as far as I can tell, there's some BUG in Vista re: IE7 and wireless networking.
I kind of have a similar issue too with the Dell laptop I just bought. I don't have a problem with disconnecting so much as if I intentionally disconnect I can't re-connect to anything. No networks show up in the list and when I goto the device manager it says my wireless card has no drivers installed. Heh. A simple reboot and everything works again? I'm using the Intel 4965AGN.
Edit: Never mind... I just tried disconnecting it a bunch and re-connecting and it is working fine. I guess it was just the BT interfering.
You could have ran ipconfig /flushdns from the command prompt, garunatee that would have worked.
keep it in mind in furture
regards
I had a Dell D820 which did the same, and to solve the issue the wireless card was replaced as it was found that the wireless card was not compatable with vista and now I beleive the card in question is no longer used.
It could have been a bios issue... an older bios isn't programmed for certain functions... I had an Acer, and when my I updated my laptop... they had the wrong updates on the page for my Acer and I actually downgraded and lost function to my wireless card, the switch, the buttons on the front and 2 usb ports... ugh..!!! Now I'm gripin'... I called them, and they let me know I was using my one free support call, and there was no one there that could help me, it wasn't their fault I didn't get an OS reinstall disk with my laptop, and my next call would cost me 39 dolla!!! Bastards... anyways... have you checked the bios? ahem... lol.. back to subject.
With Dell Laptops and wireless problems in vista the route cause has in general been form my experience with the wireless card not being completly compatible with vista and as intel are the main suppliers of wireless cards to a vast majority of of computer manufacturers it is intel and co and this includes microsoft to get their act together before launching new operating systems. If I remember when NT first appeared there were similar problems with compatability in the early days, so be patient and all will come out in the wash.
Well now there's a fix! Thanks to a regular Vista user on Microsoft's TechNet forums, a fix has been found!
Here ya go:
>>Right click "Computer"
>>Click "Manage"
>>Under the "System Tools" section, Double click "Local Users and Groups"
>>Click "Groups"
>>Right click "Administrators"
>>Click "Add to group..."
>>Click "Add"
>>Click "Advanced"
>>Click "Find Now"
>>Double click "Local Service"
>>Click "Ok"
>>"NT Authority\Local Service" should show up in the list now
>>Click "Ok"
>>Close Computer Management and reboot.
Remember, all credit goes to BlueShot @ Microsoft TechNet Forums!
Here ya go:
>>1. Right click "Computer"
>>2. Click "Manage"
>>3. Under the "System Tools" section, Double click "Local Users and Groups"
>>Click "Groups"
>>Click "Add"
>>Click "Advanced"
>>Click "Find Now"
>>Click "Ok"
>>"NT AuthorityLocal Service" should show up in the list now
>>Click "Ok"
>>Close Computer Management and reboot....
There's kind of a huge problem with these instructions...
when I get to step 3, there is no "Local Users and Groups" in the System Tools" section.
Vista Home Premium. Maybe the instructions are for a different version; what are the instructions for me?
