IE* problem.
Is there a way to set IE8 back to it's default status or to re-install it?
The browser is freezing on me so much that I can't use it.
I've not added anything recently yet this morning it was shot.
Thanks.
jst42daytoo
sn0wy82
IE8 problem
Head to the Control Panel, then Internet Options, select the last tab (Advanced) at the bottom of this tab there is an option to 'reset' IE8. All plugins will be disabled aswell, so you may need to enable the ones you use afterwards.
That did it.
Thanks for your help.
J
