I'm having problems with the screen.
I don't know what's been pressed but the screen has gone on it's side, can someone tell me how to rectify this please?
MikeHawthorne
Hi
If you mean that the screen has flipped sideways.
Right click on the desk top and see if you have an option called Screen Resolution.
Find the box that is labeled Orientation.
Change it to Landscape.
If you don't have that option...
Right click on the desktop and select Personalize.
Then Click Display.
Next Click Change Display Settings.
Holding you mouse sideways may make this easier.
Alternately you may have a link to your video card software on the right click drop down from the desktop.
Mine is Catalyst Control Center, if I go there I can change the Orientation as well.
Mike
Thanks for that.
