Increasingly frequent BSOD (and knock-on issues) - Can anyone help?
I've had my computer since September. It was a custom build but the guy who did it knows his stuff.
Started off ok, but I soon started getting occasional BSOD. These became increasingly frequent and now it's so bad I'm lucky if I can go 5 minutes without a crash.
Some blue-screens restart the computer on their own, others require me to manually restart.
The computer also behaves erratically after some crashes (mouse responding strangely) and requires a restart.
I know next to nothing about the workings of Computers in terms of hardware or software beyond the basics, so I'm at an utter loss over this. I have thoroughly virus and malware checked and can find nothing.
Here's the CPU-Z images...
(The motherboard seems to require the RAM sticks to be alligned this way, in the outermost slots first, thus 2 and 3 are empty)
...and here's a .rar of todays minidumps
View attachment 110307.rar
If anyone can help I'd be really, REALLY grateful!
EDIT: Here's an overview of my system in case any of this info's helpful:
EDIT: Here's an overview of my system in case it's any help:
Increasingly frequent BSOD (and knock-on issues) - Can anyone help? (Sorry for double post - crashed during edit and seems to have wiped previous attempt)
Re: Increasingly frequent BSOD (and knock-on issues) - Can anyone help? (Sorry for double post - crashed during edit and seems to have wiped previous attempt)
1. The memory is set right, thank you for attaching the screenshots.
2. The culprit of your crashes is Atheros Wireless USB Network Adapter driver, update it:
athrxusb.sys Mon Jan 29 07:57:10 2007
3. Update other drivers too:
Intel GMA
igdkmd64.sys Fri Nov 06 18:52:47 2009
Magic ISO
mcdbus.sys Tue Feb 24 05:34:07 2009
Research In Motion BlackBerry Device
RimUsb_AMD64.sys Wed Apr 16 10:49:32 2008
4. If bsod's persist, replace Avast with MSE:
avast! Uninstall Utility
https://www.microsoft.com/security_essentials/
ENJOY. : - )
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\030711-16161-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02e07000 PsLoadedModuleList = 0xfffff800`03044e50
Debug session time: Mon Mar  7 14:28:25.841 2011 (UTC - 5:00)
System Uptime: 0 days 0:02:55.511
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {0, 0, 0, 0}
Unable to load image \SystemRoot\system32\DRIVERS\athrxusb.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athrxusb.sys
*** ERROR: Module load completed but symbols could not be loaded for athrxusb.sys
Probably caused by : nwifi.sys ( nwifi!Pt6RepackRecvNBL+fa )
Followup: MachineOwner
0: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) - The operation completed successfully.
FAULTING_IP:
+3935326461656565
00000000`00000000 ??              ???
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
ERROR_CODE: (NTSTATUS) 0 - STATUS_WAIT_0
BUGCHECK_STR:  0x1E_0
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff800043e7488 -- (.exr 0xfffff800043e7488)
ExceptionAddress: fffff8800643575e (nwifi!Pt6RepackRecvNBL+0x00000000000000fa)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff800043e7530 -- (.trap 0xfffff800043e7530)
rax=fffffa8005ced9d0 rbx=0000000000000000 rcx=fffff8800646d6e0
rdx=0ebceddb4a387945 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800643575e rsp=fffff800043e76c0 rbp=0000000000000000
 r8=0000000000000000  r9=0000000094f891fa r10=fffff8800646b110
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
nwifi!Pt6RepackRecvNBL+0xfa:
fffff880`0643575e 4c034a18        add     r9,qword ptr [rdx+18h] ds:ff08:0ebceddb`4a38795d=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002e70c2e to fffff80002e78ed0
STACK_TEXT:
fffff800`043e6568 fffff800`02e70c2e : 00000000`00000000 fffff800`043e6778 fffff800`043e6ce0 fffff800`02ea5e28 : nt!KeBugCheck
fffff800`043e6570 fffff800`02e9ebed : fffff800`03085c24 fffff800`02fbea3c fffff800`02e07000 fffff800`043e7488 : nt!KiKernelCalloutExceptionHandler+0xe
fffff800`043e65a0 fffff800`02ea6250 : fffff800`02fc6b5c fffff800`043e6618 fffff800`043e7488 fffff800`02e07000 : nt!RtlpExecuteHandlerForException+0xd
fffff800`043e65d0 fffff800`02eb31b5 : fffff800`043e7488 fffff800`043e6ce0 fffff800`00000000 fffffa80`05cf0e50 : nt!RtlDispatchException+0x410
fffff800`043e6cb0 fffff800`02e78542 : fffff800`043e7488 00000000`00000000 fffff800`043e7530 fffffa80`061f6010 : nt!KiDispatchException+0x135
fffff800`043e7350 fffff800`02e76e4a : fffffa80`0578485b fffff880`06799f47 fffffa80`0636888e fffff880`067be516 : nt!KiExceptionDispatch+0xc2
fffff800`043e7530 fffff880`0643575e : 00000000`00000000 00000000`00000000 fffffa80`061f6010 fffff880`067994e6 : nt!KiGeneralProtectionFault+0x10a
fffff800`043e76c0 fffff880`064366c8 : fffffa80`0578485b fffff880`067bccc8 fffffa80`05ca9030 fffffa80`061f6010 : nwifi!Pt6RepackRecvNBL+0xfa
fffff800`043e77c0 fffff880`014fe2b7 : fffffa80`058631a0 fffffa80`05cf0e50 00000000`00000001 0000000f`0586e000 : nwifi!Pt6Receive+0x170
fffff800`043e7820 fffff880`0677abd0 : fffffa80`0578485b 00000000`00000000 00000000`00000000 fffffa80`04ec2a00 : ndis! ?? ::FNODOBFM::`string'+0xccef
fffff800`043e7870 fffffa80`0578485b : 00000000`00000000 00000000`00000000 fffffa80`04ec2a00 fffffa80`00000001 : athrxusb+0xebd0
fffff800`043e7878 00000000`00000000 : 00000000`00000000 fffffa80`04ec2a00 fffffa80`00000001 00000000`00000000 : 0xfffffa80`0578485b
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  nwifi!Pt6RepackRecvNBL+fa
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nwifi
IMAGE_NAME:  nwifi.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bcc3b
FAILURE_BUCKET_ID:  X64_0x1E_0_nwifi!Pt6RepackRecvNBL+fa
Loading Dump File [F:\a\Minidump\D M P\DMP\030711-18205-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02e5a000 PsLoadedModuleList = 0xfffff800`03097e50
Debug session time: Mon Mar  7 14:30:56.393 2011 (UTC - 5:00)
System Uptime: 0 days 0:01:54.063
Probably caused by : nwifi.sys ( nwifi!Pt6RepackRecvNBL+103 )
1: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
+3264353832643034
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff88002f226f8 -- (.exr 0xfffff88002f226f8)
ExceptionAddress: fffff88006608767 (nwifi!Pt6RepackRecvNBL+0x0000000000000103)
NumberParameters: 2
TRAP_FRAME:  fffff88002f227a0 -- (.trap 0xfffff88002f227a0)
rax=fffffa8005dddf50 rbx=0000000000000000 rcx=fffff880066406e0
rdx=fffffa8005ddca00 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88006608767 rsp=fffff88002f22930 rbp=0000000000000000
 r8=0000000000000000  r9=33ea818724b2082b r10=fffff8800663e110
r11=0000000000000001 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
nwifi!Pt6RepackRecvNBL+0x103:
fffff880`06608767 450fb701        movzx   r8d,word ptr [r9] ds:f318:33ea8187`24b2082b=????
LAST_CONTROL_TRANSFER:  from fffff80002ec3c2e to fffff80002ecbed0
STACK_TEXT:
fffff880`02f217d8 fffff800`02ec3c2e : 00000000`00000000 00000000`00000000 fffff880`02f21f50 fffff800`02ef8e28 : nt!KeBugCheck
fffff880`02f217e0 fffff800`02ef1bed : fffff800`030d8c24 fffff800`03011a3c fffff800`02e5a000 fffff880`02f226f8 : nt!KiKernelCalloutExceptionHandler+0xe
fffff880`02f21810 fffff800`02ef9250 : fffff800`03019a88 fffff880`02f21888 fffff880`02f226f8 fffff800`02e5a000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`02f21840 fffff800`02f061b5 : fffff880`02f226f8 fffff880`02f21f50 fffff880`00000000 fffffa80`05de1df0 : nt!RtlDispatchException+0x410
fffff880`02f21f20 fffff800`02ecb542 : fffff880`02f226f8 00000000`00000000 fffff880`02f227a0 fffffa80`0614d010 : nt!KiDispatchException+0x135
fffff880`02f225c0 fffff800`02ec9e4a : fffffa80`06606e5b fffff880`02093f47 fffffa80`06379cae fffff880`020b8516 : nt!KiExceptionDispatch+0xc2
fffff880`02f227a0 fffff880`06608767 : 00000000`00000000 00000000`00000000 fffffa80`0614d010 fffff880`020934e6 : nt!KiGeneralProtectionFault+0x10a
fffff880`02f22930 fffff880`066096c8 : fffffa80`06606e5b fffff880`020b6cc8 fffffa80`05d85030 fffffa80`0614d010 : nwifi!Pt6RepackRecvNBL+0x103
fffff880`02f22a30 fffff880`014aa2b7 : fffffa80`05ced1a0 fffffa80`05de1df0 00000000`00000001 0000000f`055dd4f8 : nwifi!Pt6Receive+0x170
fffff880`02f22a90 fffff880`02074bd0 : fffffa80`06606e5b 00000000`00000000 00000000`00000000 fffffa80`05606300 : ndis! ?? ::FNODOBFM::`string'+0xccef
fffff880`02f22ae0 fffffa80`06606e5b : 00000000`00000000 00000000`00000000 fffffa80`05606300 fffffa80`00000001 : athrxusb+0xebd0
fffff880`02f22ae8 00000000`00000000 : 00000000`00000000 fffffa80`05606300 fffffa80`00000001 00000000`00000000 : 0xfffffa80`06606e5b
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_NAME:  nwifi!Pt6RepackRecvNBL+103
MODULE_NAME: nwifi
FAILURE_BUCKET_ID:  X64_0x1E_0_nwifi!Pt6RepackRecvNBL+103
Drivers:
fffff880`043c2000 fffff880`04400000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f66000 fffff880`00fbd000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c96000 fffff880`02d20000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03a00000 fffff880`03a16000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00ea5000 fffff880`00eb0000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`02046000 fffff880`0204f000   aswFsBlk aswFsBlk.SYS Thu Jan 13 03:37:10 2011 (4D2EB9B6)
fffff880`0699a000 fffff880`069d4000   aswMonFlt aswMonFlt.sys Thu Jan 13 03:37:21 2011 (4D2EB9C1)
fffff880`02d20000 fffff880`02d2a000   aswRdr   aswRdr.SYS   Thu Jan 13 03:37:32 2011 (4D2EB9CC)
fffff880`03b6a000 fffff880`03bb3000   aswSP    aswSP.SYS    Thu Jan 13 03:41:42 2011 (4D2EBAC6)
fffff880`01897000 fffff880`018a7000   aswTdi   aswTdi.SYS   Thu Jan 13 03:40:19 2011 (4D2EBA73)
fffff880`00e9c000 fffff880`00ea5000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fd0000 fffff880`00ffa000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`02066000 fffff880`020f8000   athrxusb athrxusb.sys Mon Jan 29 07:57:10 2007 (45BDEF26)
fffff960`00850000 fffff960`008b1000   ATMFD    ATMFD.DLL    Mon Jul 13 19:38:13 2009 (4A5BC565)
fffff880`019de000 fffff880`019e5000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03b59000 fffff880`03b6a000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03599000 fffff880`035b7000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`021e3000 fffff880`021f3000   BthEnum  BthEnum.sys  Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`02020000 fffff880`02037000   bthmodem bthmodem.sys Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`02000000 fffff880`02020000   bthpan   bthpan.sys   Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`02110000 fffff880`0219c000   bthport  bthport.sys  Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`020f8000 fffff880`02110000   BTHUSB   BTHUSB.sys   Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff960`007c0000 fffff960`007e7000   cdd      cdd.dll      unavailable (00000000)
fffff880`0688e000 fffff880`068ab000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`019ab000 fffff880`019d5000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ce4000 fffff880`00da4000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01945000 fffff880`01975000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c86000 fffff880`00ce4000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0116e000 fffff880`011e1000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03bef000 fffff880`03bff000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`068ab000 fffff880`068b9000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03ab8000 fffff880`03b3b000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03b3b000 fffff880`03b59000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c68000 fffff880`02c77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0192f000 fffff880`01945000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04dd0000 fffff880`04df2000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`068c5000 fffff880`068ce000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`068b9000 fffff880`068c5000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`068ce000 fffff880`068e1000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06900000 fffff880`0690c000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`044e5000 fffff880`045d9000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 19:38:56 2009 (4A5BC590)
fffff880`04400000 fffff880`04446000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`04c2b000 fffff880`04c61000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`045d9000 fffff880`045e6000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`010ef000 fffff880`01103000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`04d4c000 fffff880`04d57000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`010a3000 fffff880`010ef000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01200000 fffff880`0120a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018f5000 fffff880`0192f000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`0142b000 fffff880`01475000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`071c4000 fffff880`071cd000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff800`02e11000 fffff800`02e5a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04446000 fffff880`0446a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06955000 fffff880`0696e000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0696e000 fffff880`06976080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06947000 fffff880`06955000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0693c000 fffff880`06946d00   HMuKstOr HMuKstOr.sys Mon May 03 05:05:18 2010 (4BDE91CE)
fffff880`034d1000 fffff880`03599000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015f4000 fffff880`015fd000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03c58000 fffff880`043c1ea0   igdkmd64 igdkmd64.sys Fri Nov 06 18:52:47 2009 (4AF4B6CF)
fffff880`04d6c000 fffff880`04d93000   IntcHdmi IntcHdmi.sys Fri Jul 10 09:45:10 2009 (4A5745E6)
fffff880`00e6a000 fffff880`00e72000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03bd9000 fffff880`03bef000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`03aa5000 fffff880`03ab4000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`021a9000 fffff880`021b7000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb5000 fffff800`00bbf000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04c9d000 fffff880`04ce0000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`013cc000 fffff880`013e6000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:50:34 2009 (4A5BC84A)
fffff880`04df2000 fffff880`04df7200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0204f000 fffff880`02064000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06977000 fffff880`0699a000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`018b6000 fffff880`018f2880   mcdbus   mcdbus.sys   Tue Feb 24 05:34:07 2009 (49A3CD1F)
fffff880`00c2e000 fffff880`00c72000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`02037000 fffff880`02046000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`0692e000 fffff880`0693c000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`018a7000 fffff880`018b6000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0219c000 fffff880`021a9000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e82000 fffff880`00e9c000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`035b7000 fffff880`035cf000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`035cf000 fffff880`035fb000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:23:59 2009 (4A5BC20F)
fffff880`03400000 fffff880`0344d000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:24:08 2009 (4A5BC218)
fffff880`0344d000 fffff880`03470000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:24:05 2009 (4A5BC215)
fffff880`01850000 fffff880`0185b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fc6000 fffff880`00fd0000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01110000 fffff880`0116e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02c5d000 fffff880`02c68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015e2000 fffff880`015f4000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01488000 fffff880`0157a000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045f2000 fffff880`045fe000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04c00000 fffff880`04c13000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`03a3a000 fffff880`03a69000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04d57000 fffff880`04d6c000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d9e000 fffff880`02dad000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d2a000 fffff880`02d6f000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0157a000 fffff880`015da000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0185b000 fffff880`0186c000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c51000 fffff880`02c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e5a000 fffff800`03437000   nt       ntkrnlmp.exe Mon Jul 13 19:40:48 2009 (4A5BC600)
fffff880`01229000 fffff880`013cc000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019d5000 fffff880`019de000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06600000 fffff880`06653000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d78000 fffff880`02d9e000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e72000 fffff880`00e82000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013e6000 fffff880`013f7000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06275000 fffff880`0631b000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04d93000 fffff880`04dd0000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c72000 fffff880`00c86000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`01103000 fffff880`0110f040   PxHlpa64 PxHlpa64.sys Tue Oct 20 14:08:42 2009 (4ADDFCAA)
fffff880`03a16000 fffff880`03a3a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03a69000 fffff880`03a84000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`03a84000 fffff880`03aa5000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`02c77000 fffff880`02c91000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c00000 fffff880`02c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`044da000 fffff880`044e5000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01835000 fffff880`0183e000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`07144000 fffff880`07172000   rdpdr    rdpdr.sys    Mon Jul 13 20:18:02 2009 (4A5BCEBA)
fffff880`0183e000 fffff880`01847000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01847000 fffff880`01850000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0718c000 fffff880`071c4000   RDPWD    RDPWD.SYS    Mon Jul 13 20:16:47 2009 (4A5BCE6F)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`021b7000 fffff880`021e3000   rfcomm   rfcomm.sys   Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0690c000 fffff880`06912f00   RimUsb_AMD64 RimUsb_AMD64.sys Wed Apr 16 10:49:32 2008 (480611FC)
fffff880`04c13000 fffff880`04c2b000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0446a000 fffff880`044bc000   Rt64win7 Rt64win7.sys Mon Feb 08 22:42:09 2010 (4B70D991)
fffff880`06663000 fffff880`0688d100   RTKVHD64 RTKVHD64.sys Thu Feb 25 04:14:31 2010 (4B863F77)
fffff880`04c6c000 fffff880`04c9b000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`0631b000 fffff880`06326000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`045e6000 fffff880`045f2000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02dad000 fffff880`02dca000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015da000 fffff880`015e2000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06353000 fffff880`063c4000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`070ac000 fffff880`07144000   srv      srv.sys      Mon Jul 13 19:25:11 2009 (4A5BC257)
fffff880`06200000 fffff880`06269000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`06326000 fffff880`06353000   srvnet   srvnet.sys   Mon Jul 13 19:24:58 2009 (4A5BC24A)
fffff880`04c9b000 fffff880`04c9c480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`063c4000 fffff880`063d6000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0188a000 fffff880`01897000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`07172000 fffff880`0717d000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`0186c000 fffff880`0188a000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02de5000 fffff880`02df9000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00550000 fffff960`0055a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0717d000 fffff880`0718c000   tssecsrv tssecsrv.sys Mon Jul 13 20:16:41 2009 (4A5BCE69)
fffff880`03bb3000 fffff880`03bd9000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04ce0000 fffff880`04cf2000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`068e1000 fffff880`068fe000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`068fe000 fffff880`068fff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`044c9000 fffff880`044da000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04cf2000 fffff880`04d4c000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03c00000 fffff880`03c56000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06913000 fffff880`0692e000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`044bc000 fffff880`044c9000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019e5000 fffff880`019f3000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01800000 fffff880`01825000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01475000 fffff880`01485000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00da4000 fffff880`00e00000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02dca000 fffff880`02de5000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01825000 fffff880`01835000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eb3000 fffff880`00f57000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f57000 fffff880`00f66000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d6f000 fffff880`02d78000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`0037f000   win32k   win32k.sys   Mon Jul 13 19:40:16 2009 (4A5BC5E0)
fffff880`00fbd000 fffff880`00fc6000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`069d4000 fffff880`069f5000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`071cd000 fffff880`071fe000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`01975000 fffff880`01983000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01983000 fffff880`0198f000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0198f000 fffff880`01998000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01998000 fffff880`019ab000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Excellent! Thank you so much!
I'll have a go at sorting this out and let you know how it works out.
Thanks again!
You are welcome. :)
#7
Just a quick update. I was unable to find more recent drivers for my wireless adapter, but it was pretty old anyway so I bought a new one.
Since installing I've had no crashes at all! Thanks so much for your help!
Fil
#8
So far sounds good, Fil, thanks for keeping this updated. As for the Atheros driver, here it should be partner.atheros.com/Drivers.aspx.
