Installed programs are missing and ReadyBoost isn't available!
Discussion in 'Windows 7 Help and Support' started by DemonParia, Feb 15, 2010.
  1. DemonParia
    DemonParia New Member
    Feb 15, 2010
    12
    0
    Okay, I'm stumped.
    When I go under "Uninstall a Program", most of my programs aren't even there. At all. It shows 25 of them, when I have much, much more. I can still use all of my programs (I'm pretty sure!), so what's up with THAT?
    Secondly, I can't use ReadyBoost on my flash drive anymore. Funny thing is, the cache file thing is still on the drive and I can't delete it, so I can't use the drive. When I try to eject or format it, it just won't let me. (Says that the system is using it, which makes me think that ReadyBoost is WORKING, it just can't be modified.)
    ReadyBoost isn't under the properties tab, and I already tried the 'fix' with seeing if some service was running. It was. I have no idea why these two problems are happening.
    I've had this computer for two months, and it's really high quality. Alienware PC.
    Help would be EXTREMELY appreciated.
  2. kemical
    kemical Windows Forum Admin
    Staff Member Premium Supporter Microsoft MVP
    Aug 28, 2007
    32,374
    1,642
    Have you tried 'system restore'?
  3. DemonParia
    Feb 15, 2010
    12
    0
    Yeah, funny thing about that. It only had the most recent system restore from that same day, even when I checked show more system restores.
    Yeah...
  4. kemical
    Aug 28, 2007
    32,374
    1,642
    Have you tried pressing F8 when booting and then choosing from the on screen menu 'Last good known cofiguration'?
  5. DemonParia
    Feb 15, 2010
    12
    0
    Yes, actually. Didn't work.
  6. kemical
    Aug 28, 2007
    32,374
    1,642
    Hmm... you could try running the system file checker?
    If you unsure of the procedure I'll repeat it here. Right-click on command prompt and run as admin'. Then type:
    sfc /scannow
    Then enter. The file checker will run and if anything amiss is found it will attempt to repair.
  7. tblount
    tblount New Member
    Sep 27, 2009
    3,537
    64
    Turn off readyboost. It probably slows down your system anyway. Testing shows that hard drivers are many times faster than USB.
  8. DemonParia
    Feb 15, 2010
    12
    0
    ...Did you even read it completely? The point is: I CAN'T TURN IT OFF OR ON. The option has disappeared.
  9. kemical
    Aug 28, 2007
    32,374
    1,642
    Did you try the file checker?
  10. tblount
    tblount New Member
    Sep 27, 2009
    3,537
    64
    sysmain.dll part of Superfetch Service Host must be messed up. any chance you have a virus?
    1739 kb file date 7/13/09
  11. Mitchell_A
    Mitchell_A Excellent Member
    Feb 7, 2009
    5,068
    240
    Could you try formatting the USB drive on another computer? You should be able to do so there.
    After that, you can re-enable the device as a ReadyBoost cache device on your PC.
    As for your programs, you should make sure they are certified for Windows 7.
    Navigating to the program directory in the start menu may give you uninstall options for some of them.
  12. DemonParia
    Feb 15, 2010
    12
    0
    Probably not. I have Kaspersky Internet Security and scan regularly.
    Any chance you could give me the sysmain.dll, or is it different for each person? o_O
    I have no idea.
    EDIT: And I'm trying that scan thing right now, and will post the results next time I'm online.
  13. DemonParia
    Feb 15, 2010
    12
    0
    No. See, you misunderstand. I press properties, and the option JUST ISN'T THERE FOR READYBOOST.
    I have another flash drive that I don't use for ReadyBoost, and when I went into properties I couldn't configure ReadyBoost options because the tab wasn't there.
Share This Page
Loading...
