Windows 7 Intel wifi link 5100 agn problems
Dynasty
I have an Asus g50vt-x2 and installed 7000.
From the end of the installation Windows recognizes the networks nearby. However, I can not connect to my home network. It tells me to reset my router or just my adaptor.
I have downloaded the vista drivers from Intel and tried those, but same luck. I would love to be able to connect. It is odd, first time I have ever seen a wifi driver issue where it sees networks, just won't let you connect.
Oh, sometimes it asks me to retype the passkey, even though it is correct. Sometimes not.
Thanks.
iGerm
Windows 7 WiFi troubles
Change your chanel in AP lower than 11 and it will be working. :)
nbkp
i have wifi with windows 7 aswell. it is a pain to connect to wireless networks
Top Bottom
