Tend to these drivers
[TABLE="width: 206"]
[TR]
[TD]SiWinAcc.sys[/TD]
[TD="align: right"]6/14/2007[/TD]
[/TR]
[TR]
[TD]SiRemFil.sys[/TD]
[TD="align: right"]6/20/2007[/TD]
[/TR]
[TR]
[TD]SI3132.sys[/TD]
[TD="align: right"]10/3/2007
[/TD]
[/TR]
[/TABLE]
Silicon Image Product, you may be able to find updates here
Silicon Image - Support update, uninstall or rename
and
[TR]
[TD="width: 95"]nvm62x64.sys[/TD]
[TD="class: xl65, width: 111, align: right"]10/17/2008[/TD]
[/TR]
[/TABLE]
Nvidia network adapter you can check here
Drivers - Download NVIDIA Drivers update, uninstall or rename
and
[TR]
[TD="width: 95"]ADIHdAud.sys[/TD]
[TD="class: xl65, width: 111, align: right"]5/21/2009[/TD]
[/TR]
[/TABLE]
SoundMax Audio ... good luck with that one. Update, uninstall or rename
and
[TR]
[TD]LHidFilt.Sys[/TD]
[TD="align: right"]6/17/2009[/TD]
[/TR]
[TR]
[TD]LMouFilt.Sys[/TD]
[/TR]
[/TABLE]
Logitech product, check here
Logitech - Support & Software Downloads update, uninstall or rename.
If Blue Screens persist, then;
Download Memtest86+
from this location here. Burn the ISO to a CD and boot the computer from the CD from a cold boot after leaving it off for an hour or more.
Ideally let it run for at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test. Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Perform the test RAM sticks individually as well as all possible combinations. When you find a good one then test it in all slots. Post back with the results.
See
this Guide to using Memtest 86+
Good luck
Randy
