RAMMon v1.0 Build: 1002 built with SysInfo v1.0 Build: 1006 body { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; margin-left: 10px;} p, td { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: 22px} table, tr { border: solid #AAAADD 1px; margin: 10px; } td.header { background-color: #CCCCCC; font-weight: bold; text-align: left;} td.maxhvalue { background-color: #FFFF00; font-weight: bold; text-align: left;} td.title { background-color: #EEEEEE; width: 9; font-weight: bold; } td.value { background-color: #EEEEEE; text-align: left;} td.altvalue { background-color: #DDDDFF; text-align: left;} td.valuelognote { background-color: #FFFFFF; text-align: left;} td.valueinformation { background-color: #FAFF93; text-align: left;} td.valuewarning { background-color: #E0E941; text-align: left;} td.valueserious { background-color: #FF8040; text-align: left;} td.valuecritical { background-color: #FF0000; text-align: left;} td.maxvalue { background-color: #99FF99; text-align: left;} h1 { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 14px; font-style: normal; color: #000000; font-weight: bold;} a { font-family: Verdana, Arial, Helvetica, sans-serif; font-weight: bold; text-decoration: underline; color: #637F90} a:hover { font-family: Verdana, Arial, Helvetica, sans-serif; font-style: normal; font-weight: bold; color: #0000CC;} .navbar { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12px; font-style: normal; font-weight: bold; color: #FFFFFF;} a.navbar, a.navbar:visited { font-family: Verdana, Arial, Helvetica, sans-serif; font-weight: bold; text-decoration: none; color: #FFFFFF; } a.navbar:hover { font-family: Verdana, Arial, Helvetica, sans-serif; font-weight: bold; text-decoration: none; color: #0000CC; } small { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 10px; font-style: normal; line-height: 15px;} .sysinfo { border: solid #AAAADD 1px; margin-left: 10px; width: 40; padding: 10px; line-height: 22px;} small { font-size: 12pt; } .footer { font-size: 10px; border-top: solid #AAAADD 1px; margin-top: 10px;}
PassMark (R) Software - www.passmark.com Memory Summary For MATIJA-PC
Number of Memory Devices: 3 Total Physical Memory: 4094 MB (4096 MB)
Total Available Physical Memory: 2440 MB
Memory Load: 40%
ItemSlot #1Slot #2Slot #3Slot #4 Ram Type Not Populated DDR2 DDR2 DDR2 Standard Name
DDR2-800 DDR2-800 DDR2-800 Module Name
PC2-6400 PC2-6400 PC2-6400 Memory Capacity (MB)
1024 2048 1024 Bus Clockspeed (Mhz)
400.00 400.00 400.00 Jedec Manufacture Name
Kingmax Semiconductor Kingmax Semiconductor Kingmax Semiconductor Search Amazon.com
Search! Search! Search! SPD Revision
1.2 1.2 1.2 Registered
No No No ECC
No No No DIMM Slot #
2 3 4 Manufactured
Year 2000 Year 2000 Year 2000 Module Part #
KLDD48F-A8KB5 KLDE88F-B8NU5 KLDD48F-A8KB5 Module Revision
0x0 0x0 0x0 Module Serial #
0x0 0x0 0x0 Module Manufacturing Location
65 65 65 # of Row Addressing Bits
14 14 14 # of Column Addressing Bits
10 10 10 # of Banks
4 8 4 # of Ranks
2 2 2 Device Width in Bits
8 8 8 Bus Width in Bits
64 64 64 Module Voltage
SSTL 1.8V SSTL 1.8V SSTL 1.8V CAS Latencies Supported
3 4 5 3 4 5 3 4 5 Timings @ Max Frequency
5-5-5-18 5-5-5-18 5-5-5-18 Minimum Clock Cycle Time, tCK (ns)
2.500 2.500 2.500 Minimum CAS Latency Time, tAA (ns)
12.500 12.500 12.500 Minimum RAS to CAS Delay, tRCD (ns)
12.500 12.500 12.500 Minimum Row Precharge Time, tRP (ns)
12.500 12.500 12.500 Minimum Active to Precharge Time, tRAS (ns)
45.000 45.000 45.000 Minimum Row Active to Row Active Delay, tRRD (ns)
7.500 7.500 7.500 Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns)
57.000 57.000 57.000 Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns)
105.000 127.000 105.000
DDR2 Specific SPD Attributes
Data Access Time from Clock, tAC (ns)
0.400 0.400 0.400 Clock Cycle Time at Medium CAS Latency (ns)
3.750 3.750 3.750 Data Access Time at Medium CAS Latency (ns)
0.500 0.500 0.500 Clock Cycle Time at Short CAS Latency (ns)
5.000 5.000 5.000 Data Access Time at Short CAS Latency (ns)
0.600 0.600 0.600 Maximum Clock Cycle Time (ns)
8.000 8.000 8.000 Write Recover Time, tWR (ns)
15.000 15.000 15.000 Internal Write to Read Command Delay, tWTR (ns)
7.500 7.500 7.500 Internal Read to Precharge Command Delay, tRTP (ns)
7.500 7.500 7.500 Address/Command Setup Time Before Clock, tIS (ns)
0.170 0.170 0.170 Address/Command Hold Time After Clock, tIH (ns)
0.250 0.250 0.250 Data Input Setup Time Before Strobe, tDS (ns)
0.050 0.050 0.050 Data Input Hold Time After Strobe, tDH (ns)
0.120 0.120 0.120 Maximum Skew Between DQS and DQ Signals (ns)
0.200 0.200 0.200 Maximum Read Data hold Skew Factor (ns)
0.240 0.240 0.240 PLL Relock Time (ns)
0.000 0.000 0.000 DRAM Package Type
Planar Planar Planar Burst Lengths Supported
4 8 4 8 4 8 Refresh Rate
Reduced (7.8us) Reduced (7.8us) Reduced (7.8us) # of PLLS on DIMM
0 0 0 FET Switch External Enable
No No No Analysis Probe Installed
No No No Weak Driver Supported
Yes Yes Yes 50 Ohm ODT Supported
Yes Yes Yes Partial Array Self Refresh Supported
No No No Module Type
UDIMM UDIMM UDIMM Module Height (mm)
30.0 30.0 30.0
