IRQL_GT_ZERO_AT_SYSTEM_SERVICE
Gil80
Hi all,
I got this BSOD out of the blue
Didn't install any new hardware or software.
BSOD error image attached and log files attached.
Thanks
jcgriff2
Microsoft MVP
Hi -
Bit Defender appears to be a likely culprit at this time.
FAILURE_BUCKET_ID:  X64_RAISED_IRQL_FAULT_vsserv.exe_nt!KiSystemServiceExit+245
Remove - http://kb.eset.com/esetkb/index?page=content&id=SOLN146&locale=en_US
Reboot upon completion.
Install MSE - http://windows.microsoft.com/en-us/windows/security-essentials-download
Regards. . .
jcgriff2
**************************Sun Sep 22 17:39:35.098 2013 (UTC - 4:00)**************************
Opened log file 'C:\Users\PALMDE~1\AppData\Local\Temp\SysnativeBSODApps\1071\dmps\outkdOutput1.txt'
Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64
Loading Dump File [C:\Users\PalmDesert\SysnativeBSODApps\092313-7706-01.dmp]
Symbol search path is: a:/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: 7601.18229.amd64fre.win7sp1_gdr.130801-1533
Machine Name:
Kernel base = 0xfffff800`03a13000 PsLoadedModuleList = 0xfffff800`03c566d0
Debug session time: Sun Sep 22 17:39:35.098 2013 (UTC - 4:00)
System Uptime: 0 days 0:43:13.895
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
ERROR: FindPlugIns 8007007b
ERROR: Some plugins may not be available [8007007b]
*  Bugcheck Analysis  *
BugCheck 4A, {77c3132a, 2, 0, fffff880068eeb60}
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )
Followup: MachineOwner
7: kd> !analyze -v; !sysinfo cpuspeed; !sysinfo SMBIOS; lmtsmn; q
IRQL_GT_ZERO_AT_SYSTEM_SERVICE (4a)
Returning to usermode from a system call at an IRQL > PASSIVE_LEVEL.
Arguments:
Arg1: 0000000077c3132a, Address of system function (system call routine)
Arg2: 0000000000000002, Current IRQL
Arg3: 0000000000000000, 0
Arg4: fffff880068eeb60, 0
Debugging Details:
PROCESS_NAME:  vsserv.exe
BUGCHECK_STR:  RAISED_IRQL_FAULT
FAULTING_IP:
+0
00000000`77c3132a c3  ret
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80003a88129 to fffff80003a88b80
STACK_TEXT:
fffff880`068ee928 fffff800`03a88129 : 00000000`0000004a 00000000`77c3132a 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`068ee930 fffff800`03a88060 : 00000000`000009f0 fffff880`068eeb60 00000000`00000000 fffff800`03d73cb3 : nt!KiBugCheckDispatch+0x69
fffff880`068eea70 00000000`77c3132a : 000007fe`fda96d26 00000000`00000000 00000000`22b94688 00000000`28282fa0 : nt!KiSystemServiceExit+0x245
00000000`2253fcc8 000007fe`fda96d26 : 00000000`00000000 00000000`22b94688 00000000`28282fa0 000007fe`fda710dc : 0x77c3132a
00000000`2253fcd0 00000000`00000000 : 00000000`22b94688 00000000`28282fa0 000007fe`fda710dc 00000000`21d31eb0 : 0x000007fe`fda96d26
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`03a88060 4883ec50  sub  rsp,50h
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiSystemServiceExit+245
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  51fb06cd
vsserv.exe
CPUID:  "Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz"
MaxSpeed:  3500
CurrentSpeed: 3500
[SMBIOS Data Tables v2.7]
[DMI Version - 39]
[2.0 Calling Convention - No]
[Table Size - 4032 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
  Vendor  American Megatrends Inc.
  BIOS Version  2003
  BIOS Starting Address Segment f000
  BIOS Release Date  05/09/2013
  BIOS ROM Size  800000
  BIOS Characteristics
  07: - PCI Supported
  11: - Upgradeable FLASH BIOS
  12: - BIOS Shadowing Supported
  15: - CD-Boot Supported
  16: - Selectable Boot Supported
  17: - BIOS ROM Socketed
  19: - EDD Supported
  23: - 1.2MB Floppy Supported
  24: - 720KB Floppy Supported
  25: - 2.88MB Floppy Supported
  26: - Print Screen Device Supported
  27: - Keyboard Services Supported
  28: - Serial Services Supported
  29: - Printer Services Supported
  32: - BIOS Vendor Reserved
  BIOS Characteristic Extensions
  00: - ACPI Supported
  01: - USB Legacy Supported
  08: - BIOS Boot Specification Supported
  10: - Specification Reserved
  11: - Specification Reserved
  BIOS Major Revision  4
  BIOS Minor Revision  6
  EC Firmware Major Revision  255
  EC Firmware Minor Revision  255
[System Information (Type 1) - Length 27 - Handle 0001h]
  Manufacturer  System manufacturer
  Product Name  System Product Name
  Version  System Version
  Serial Number
  UUID  00000000-0000-0000-0000-000000000000
  Wakeup Type  Power Switch
  SKUNumber  SKU
  Family  To be filled by O.E.M.
[BaseBoard Information (Type 2) - Length 15 - Handle 0002h]
  Manufacturer  ASUSTeK COMPUTER INC.
  Product  P8Z77-V DELUXE
  Version  Rev 1.xx
  Serial Number
  Asset Tag
  Feature Flags  09h
  -249881120: - (null)
  -249881072: - (null)
  Location  To be filled by O.E.M.
  Chassis Handle  0003h
  Board Type  0ah - Processor/Memory Module
  Number of Child Handles  0
[System Enclosure (Type 3) - Length 22 - Handle 0003h]
  Manufacturer  Chassis Manufacture
  Chassis Type  Desktop
  Version  Chassis Version
  Serial Number
  Asset Tag Number
  Bootup State  Safe
  Power Supply State  Safe
  Thermal State  Safe
  Security Status  None
  OEM Defined  0
  Height  0U
  Number of Power Cords  1
  Number of Contained Elements  0
  Contained Element Size  0
[Processor Information (Type 4) - Length 42 - Handle 0004h]
  Socket Designation  LGA1155
  Processor Type  Central Processor
  Processor Family  bfh - Specification Reserved
  Processor Manufacturer  Intel
  Processor ID  a9060300fffbebbf
  Processor Version  Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
  Processor Voltage  8ah - 1.0V
  External Clock  100MHz
  Max Speed  3800MHz
  Current Speed  3512MHz
  Status  Enabled Populated
  Processor Upgrade  Other
  L1 Cache Handle  0005h
  L2 Cache Handle  0006h
  L3 Cache Handle  0007h
  Serial Number
  Asset Tag Number
  Part Number  To Be Filled By O.E.M.
[Cache Information (Type 7) - Length 19 - Handle 0005h]
  Socket Designation  L1-Cache
  Cache Configuration  0180h - WB Enabled Int NonSocketed L1
  Maximum Cache Size  0100h - 256K
  Installed Size  0100h - 256K
  Supported SRAM Type  0001h - Other
  Current SRAM Type  0001h - Other
  Cache Speed  0ns
  Error Correction Type  None
  System Cache Type  Unified
  Associativity  8-way Set-Associative
[Cache Information (Type 7) - Length 19 - Handle 0006h]
  Socket Designation  L2-Cache
  Cache Configuration  0281h - Varies Enabled Int NonSocketed L2
  Maximum Cache Size  0400h - 1024K
  Installed Size  0400h - 1024K
  Cache Speed  0ns
[Cache Information (Type 7) - Length 19 - Handle 0007h]
  Socket Designation  L3-Cache
  Cache Configuration  0302h - Unknown Disabled Int NonSocketed L3
  Maximum Cache Size  2000h - 8192K
  Installed Size  2000h - 8192K
  Cache Speed  0ns
  Associativity  16-way Set-Associative
[Onboard Devices Information (Type 10) - Length 6 - Handle 0029h]
  Number of Devices  1
  01: Type  Ethernet [enabled]
  01: Description  Onboard Ethernet
[OEM Strings (Type 11) - Length 5 - Handle 002ah]
  Number of Strings  4
  1  To Be Filled By O.E.M.
  2  To Be Filled By O.E.M.
  3  To Be Filled By O.E.M.
  4  To Be Filled By O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 002bh]
[Memory Device (Type 17) - Length 34 - Handle 005fh]
  Physical Memory Array Handle  0060h
  Memory Error Info Handle  0064h
  Total Width  64 bits
  Data Width  64 bits
  Size  4096MB
  Form Factor  09h - DIMM
  Device Set  [None]
  Device Locator  ChannelA-DIMM0
  Bank Locator  BANK 0
  Memory Type  18h - Specification Reserved
  Type Detail  0080h - Synchronous
  Speed  1600MHz
  Manufacturer  029E
  Serial Number
  Asset Tag Number
  Part Number  CML16GX3M4A1600C9
[Physical Memory Array (Type 16) - Length 23 - Handle 0060h]
  Location  03h - SystemBoard/Motherboard
  Use  03h - System Memory
  Memory Error Correction  03h - None
  Maximum Capacity  33554432KB
  Memory Error Inf Handle  0061h
  Number of Memory Devices  4
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0061h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0062h]
  Starting Address  00000000h
  Ending Address  003fffffh
  Memory Device Handle  005fh
  Mem Array Mapped Adr Handle  006ch
  Partition Row Position  [Unknown]
  Interleave Position  01
  Interleave Data Depth  02
[Memory Device (Type 17) - Length 34 - Handle 0063h]
  Memory Error Info Handle  [No Errors]
  Total Width  64 bits
  Data Width  64 bits
  Size  4096MB
  Device Set  [None]
  Device Locator  ChannelA-DIMM1
  Bank Locator  BANK 1
  Speed  1600MHz
  Manufacturer  029E
  Serial Number
  Asset Tag Number
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0064h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0065h]
  Starting Address  00800000h
  Ending Address  00bfffffh
  Memory Device Handle  0063h
[Memory Device (Type 17) - Length 34 - Handle 0066h]
  Memory Error Info Handle  0067h
  Total Width  64 bits
  Data Width  64 bits
  Size  4096MB
  Device Set  [None]
  Device Locator  ChannelB-DIMM0
  Bank Locator  BANK 2
  Speed  1600MHz
  Manufacturer  029E
  Serial Number
  Asset Tag Number
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 0067h]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0068h]
  Starting Address  00400000h
  Ending Address  007fffffh
  Memory Device Handle  0066h
  Interleave Position  02
[Memory Device (Type 17) - Length 34 - Handle 0069h]
  Total Width  64 bits
  Data Width  64 bits
  Size  4096MB
  Device Set  [None]
  Device Locator  ChannelB-DIMM1
  Bank Locator  BANK 3
  Speed  1600MHz
  Manufacturer  029E
  Serial Number
  Asset Tag Number
[32Bit Memory Error Information (Type 18) - Length 23 - Handle 006ah]
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 006bh]
  Starting Address  00c00000h
  Ending Address  00ffffffh
  Memory Device Handle  0069h
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 006ch]
  Partition Width  04
start  end  module name
fffff880`00f08000 fffff880`00f5f000  ACPI  ACPI.sys  Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`03072000 fffff880`030fb000  afd  afd.sys  Tue Dec 27 22:59:20 2011 (4EFA9418)
fffff880`05090000 fffff880`050a6000  AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0f46a000 fffff880`0f46bf80  AiChargerPlus AiChargerPlus.sys Wed Apr 18 21:17:35 2012 (4F8F67AF)
fffff880`010e9000 fffff880`010f4000  amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`010da000 fffff880`010e9000  asahci64 asahci64.sys Thu Jan 05 00:08:19 2012 (4F053043)
fffff880`040fd000 fffff880`04103000  AsIO  AsIO.sys  Wed Aug 22 05:54:47 2012 (5034AC67)
fffff880`06568000 fffff880`0658c000  asmthub3 asmthub3.sys Tue Feb 21 03:54:06 2012 (4F435BAE)
fffff880`04ec3000 fffff880`04f28000  asmtxhci asmtxhci.sys Tue Feb 21 03:53:58 2012 (4F435BA6)
fffff880`040f6000 fffff880`040fd000  AsUpIO  AsUpIO.sys  Mon Aug 02 22:47:59 2010 (4C57835F)
fffff880`06ff6000 fffff880`06fff000  ASUScr  ASUScr.sys  Thu Sep 15 12:24:17 2011 (4E7226B1)
fffff880`0653f000 fffff880`0654d000  ASUSFILTER ASUSFILTER.sys Tue Sep 20 11:46:33 2011 (4E78B559)
fffff880`065ed000 fffff880`065f7000  ASUSstpt ASUSstpt.sys Thu Sep 15 12:24:31 2011 (4E7226BF)
fffff880`065c7000 fffff880`065ed000  ASUSumsc ASUSumsc.sys Thu Sep 15 12:24:24 2011 (4E7226B8)
fffff880`06c0e000 fffff880`06c17000  ASUSwh  ASUSwh.sys  Thu Sep 15 12:24:13 2011 (4E7226AD)
fffff880`08852000 fffff880`0885d000  asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`015dd000 fffff880`015e6000  atapi  atapi.sys  Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01200000 fffff880`0122a000  ataport  ataport.SYS  Sun Aug 04 21:02:45 2013 (51FEF9B5)
fffff880`053cf000 fffff880`053eb000  AtihdW76 AtihdW76.sys Fri Jul 05 14:10:37 2013 (51D70C1D)
fffff880`0f489000 fffff880`10102000  atikmdag atikmdag.sys Tue Jul 23 20:03:16 2013 (51EF19C4)
fffff880`04129000 fffff880`041c7000  atikmpag atikmpag.sys Tue Jul 23 19:10:26 2013 (51EF0D62)
fffff960`00830000 fffff960`00891000  ATMFD  ATMFD.DLL  Sun Dec 16 09:45:03 2012 (50CDDE6F)
fffff880`01617000 fffff880`016cc000  avc3  avc3.sys  Fri Jul 19 09:38:03 2013 (51E9413B)
fffff880`052f1000 fffff880`05335000  avchv  avchv.sys  Wed Oct 31 13:05:22 2012 (50915A52)
fffff880`02f47000 fffff880`02fdc000  avckf  avckf.sys  Fri Jul 19 09:41:15 2013 (51E941FB)
fffff880`00dd3000 fffff880`00dff000  bdfndisf6 bdfndisf6.sys Fri Feb 22 11:41:39 2013 (51279FC3)
fffff880`00c00000 fffff880`00c28000  bdfwfpf  bdfwfpf.sys  Mon Nov 14 12:16:17 2011 (4EC14CE1)
fffff880`040e0000 fffff880`040f6000  bdvedisk bdvedisk.sys Tue Apr 17 07:34:26 2012 (4F8D5542)
fffff880`049ec000 fffff880`049f3000  Beep  Beep.SYS  Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040cf000 fffff880`040e0000  blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06b9a000 fffff880`06bb8000  bowser  bowser.sys  Tue Feb 22 23:55:04 2011 (4D649328)
fffff960`007d0000 fffff960`007f7000  cdd  cdd.dll  Thu Feb 03 06:25:25 2011 (4D4A90A5)
fffff880`049b9000 fffff880`049e3000  cdrom  cdrom.sys  Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00d13000 fffff880`00dd3000  CI  CI.dll  Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`00e00000 fffff880`00e30000  CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00cb5000 fffff880`00d13000  CLFS  CLFS.SYS  Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0175c000 fffff880`017ce000  cng  cng.sys  Fri Aug 24 11:47:16 2012 (5037A204)
fffff880`04e16000 fffff880`04e26000  CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`06598000 fffff880`065a6000  crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0402e000 fffff880`040b1000  csc  csc.sys  Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`040b1000 fffff880`040cf000  dfsc  dfsc.sys  Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`031cf000 fffff880`031de000  discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`017ce000 fffff880`017e4000  disk  disk.sys  Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0523d000 fffff880`0525f000  drmk  drmk.sys  Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04e26000 fffff880`04e33000  dsNcAdpt dsNcAdpt.sys Mon Mar 30 22:33:33 2009 (49D180FD)
fffff880`065b4000 fffff880`065c7000  dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04600000 fffff880`049a4000  dump_iaStor dump_iaStor.sys Wed Feb 01 19:15:24 2012 (4F29D59C)
fffff880`0658c000 fffff880`06598000  Dxapi  Dxapi.sys  Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`10102000 fffff880`101f6000  dxgkrnl  dxgkrnl.sys  Tue Apr 09 23:28:09 2013 (5164DC49)
fffff880`0f400000 fffff880`0f446000  dxgmms1  dxgmms1.sys  Tue Apr 09 23:27:15 2013 (5164DC13)
fffff880`04d54000 fffff880`04dcd000  e1c62x64 e1c62x64.sys Fri Aug 10 18:44:15 2012 (50258EBF)
fffff880`031c3000 fffff880`031cf000  ElbyCDIO ElbyCDIO.sys Thu Dec 16 17:58:13 2010 (4D0A9985)
fffff880`01140000 fffff880`01154000  fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010f4000 fffff880`01140000  fltmgr  fltmgr.sys  Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0182c000 fffff880`01836000  Fs_Rec  Fs_Rec.sys  Wed Feb 29 22:41:06 2012 (4F4EEFD2)
fffff880`01000000 fffff880`0103a000  fvevol  fvevol.sys  Wed Jan 23 22:11:24 2013 (5100A65C)
fffff880`01a2b000 fffff880`01a74000  fwpkclnt fwpkclnt.sys Wed Jan 02 22:06:48 2013 (50E4F5C8)
fffff880`04fdc000 fffff880`04fe2c00  GEARAspiWDM GEARAspiWDM.sys Thu May 03 15:56:17 2012 (4FA2E2E1)
fffff880`016cc000 fffff880`016fe000  gzflt  gzflt.sys  Thu Oct 04 07:30:19 2012 (506D734B)
fffff800`03ff9000 fffff800`04042000  hal  hal.dll  Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`0f446000 fffff880`0f46a000  HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`04d41000 fffff880`04d54000  HECIx64  HECIx64.sys  Mon Jul 02 18:14:58 2012 (4FF21D62)
fffff880`04e36000 fffff880`04e4f000  HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`04e4f000 fffff880`04e57080  HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06400000 fffff880`0640e000  hidusb  hidusb.sys  Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`06ad1000 fffff880`06b9a000  HTTP  HTTP.sys  Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01a8c000 fffff880`01a95000  hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`01239000 fffff880`015dd000  iaStor  iaStor.sys  Wed Feb 01 19:15:24 2012 (4F29D59C)
fffff880`04fd0000 fffff880`04fdc000  ICCWDT  ICCWDT.sys  Wed Aug 18 04:27:45 2010 (4C6B9981)
fffff880`04e00000 fffff880`04e16000  intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00fb2000 fffff880`00fbc000  iusb3hcs iusb3hcs.sys Mon May 21 03:23:42 2012 (4FB9ED7E)
fffff880`064e2000 fffff880`0653f000  iusb3hub iusb3hub.sys Mon May 21 03:21:36 2012 (4FB9ED00)
fffff880`04c7a000 fffff880`04d3f000  iusb3xhc iusb3xhc.sys Mon May 21 03:21:40 2012 (4FB9ED04)
fffff880`05171000 fffff880`05180000  kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06c00000 fffff880`06c0e000  kbdhid  kbdhid.sys  Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00ba1000 fffff800`00bab000  kdcom  kdcom.dll  Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff880`052aa000 fffff880`052ed000  ks  ks.sys  Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`01800000 fffff880`0181b000  ksecdd  ksecdd.sys  Fri Jun 01 22:50:23 2012 (4FC97F6F)
fffff880`01a00000 fffff880`01a2b000  ksecpkg  ksecpkg.sys  Fri Aug 24 11:48:29 2012 (5037A24D)
fffff880`0525f000 fffff880`05264200  ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`052ed000 fffff880`052f0d80  LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`0642b000 fffff880`06440000  LGSHidFilt LGSHidFilt.Sys Tue Feb 07 08:12:39 2012 (4F312347)
fffff880`08866000 fffff880`08868480  LGVirHid LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`02fdc000 fffff880`02ff1000  lltdio  lltdio.sys  Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02f24000 fffff880`02f47000  luafv  luafv.sys  Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`02ed0000 fffff880`02f24000  lvrs64  lvrs64.sys  Fri Sep 21 15:02:17 2012 (505CB9B9)
fffff880`02a2b000 fffff880`02eb4300  lvuvc64  lvuvc64.sys  Fri Sep 21 15:03:12 2012 (505CB9F0)
fffff880`00c52000 fffff880`00ca1000  mcupdate mcupdate.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`065a6000 fffff880`065b4000  monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05180000 fffff880`0518f000  mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`053a1000 fffff880`053ae000  mouhid  mouhid.sys  Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`010c0000 fffff880`010da000  mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`06bb8000 fffff880`06bd0000  mpsdrv  mpsdrv.sys  Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06bd0000 fffff880`06bfd000  mrxsmb  mrxsmb.sys  Tue Apr 26 22:40:38 2011 (4DB78226)
fffff880`06a00000 fffff880`06a4e000  mrxsmb10 mrxsmb10.sys Fri Jul 08 22:46:28 2011 (4E17C104)
fffff880`06a4e000 fffff880`06a72000  mrxsmb20 mrxsmb20.sys Tue Apr 26 22:39:37 2011 (4DB781E9)
fffff880`0122a000 fffff880`01235000  msahci  msahci.sys  Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`01609000 fffff880`01614000  Msfs  Msfs.SYS  Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f68000 fffff880`00f72000  msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`04e58000 fffff880`04e9f000  msiscsi  msiscsi.sys  Sat Nov 20 05:35:14 2010 (4CE7A462)
fffff880`0886b000 fffff880`0886cc00  MSPCLOCK MSPCLOCK.sys Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`08869000 fffff880`0886aa80  MSPQM  MSPQM.sys  Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`016fe000 fffff880`0175c000  msrpc  msrpc.sys  Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0305d000 fffff880`03068000  mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01836000 fffff880`01848000  mup  mup.sys  Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`010b5000 fffff880`010c0000  mv91cons mv91cons.sys Thu Jan 19 01:55:35 2012 (4F17BE67)
fffff880`01a9d000 fffff880`01b8f000  ndis  ndis.sys  Wed Aug 22 11:11:46 2012 (5034F6B2)
fffff880`050ca000 fffff880`050d6000  ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0590e000 fffff880`05921000  ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`050d6000 fffff880`05105000  ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`053b6000 fffff880`053cb000  NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`03185000 fffff880`03194000  netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`030fb000 fffff880`03140000  netbt  netbt.sys  Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01b8f000 fffff880`01bef000  NETIO  NETIO.SYS  Wed Aug 22 11:11:28 2012 (5034F6A0)
fffff880`0103a000 fffff880`0104b000  Npfs  Npfs.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03051000 fffff880`0305d000  nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03a13000 fffff800`03ff9000  nt  ntkrnlmp.exe Thu Aug 01 21:09:33 2013 (51FB06CD)
fffff880`0184b000 fffff880`019ed000  Ntfs  Ntfs.sys  Fri Apr 12 07:54:36 2013 (5167F5FC)
fffff880`049e3000 fffff880`049ec000  Null  Null.SYS  Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`058bb000 fffff880`0590e000  nwifi  nwifi.sys  Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03149000 fffff880`0316f000  pacer  pacer.sys  Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00fbc000 fffff880`00fd1000  partmgr  partmgr.sys  Sat Mar 17 01:06:09 2012 (4F641BC1)
fffff880`0885d000 fffff880`08866000  pbfilter pbfilter.sys Sat Nov 06 22:23:54 2010 (4CD60DBA)
fffff880`00f72000 fffff880`00fa5000  pci  pci.sys  Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`015e6000 fffff880`015f6000  PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0181b000 fffff880`0182c000  pcw  pcw.sys  Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`05939000 fffff880`059df000  peauth  peauth.sys  Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05200000 fffff880`0523d000  portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ca1000 fffff880`00cb5000  PSHED  PSHED.dll  Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`050a6000 fffff880`050ca000  rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`05105000 fffff880`05120000  raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05120000 fffff880`05141000  raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`05141000 fffff880`0515b000  rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03000000 fffff880`03051000  rdbss  rdbss.sys  Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`05166000 fffff880`05171000  rdpbus  rdpbus.sys  Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`049f3000 fffff880`049fc000  RDPCDD  RDPCDD.sys  Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`08982000 fffff880`089b0000  rdpdr  rdpdr.sys  Sat Nov 20 06:06:41 2010 (4CE7ABC1)
fffff880`017f4000 fffff880`017fd000  rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01600000 fffff880`01609000  rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`08800000 fffff880`08839000  RDPWD  RDPWD.SYS  Fri Apr 27 23:55:20 2012 (4F9B6A28)
fffff880`011a0000 fffff880`011da000  rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`05921000 fffff880`05939000  rspndr  rspndr.sys  Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04f28000 fffff880`04fd0000  Rt64win7 Rt64win7.sys Fri Feb 03 08:00:02 2012 (4F2BDA52)
fffff880`06c18000 fffff880`06ff5b00  RTKVHD64 RTKVHD64.sys Tue Jun 12 06:02:32 2012 (4FD713B8)
fffff880`06440000 fffff880`0644e000  rzendpt  rzendpt.sys  Tue Aug 20 04:38:16 2013 (52132AF8)
fffff880`0644e000 fffff880`06474000  rzudd  rzudd.sys  Wed Aug 21 03:15:53 2013 (52146929)
fffff880`0515b000 fffff880`05165980  SaiBus  SaiBus.sys  Thu Jul 29 07:17:53 2010 (4C516361)
fffff880`053cb000 fffff880`053cef00  SaiMini  SaiMini.sys  Thu Jul 29 07:17:53 2010 (4C516361)
fffff880`0519e000 fffff880`051cd000  SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`06a72000 fffff880`06a7d000  secdrv  secdrv.SYS  Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01a84000 fffff880`01a8c000  spldr  spldr.sys  Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08879000 fffff880`08911000  srv  srv.sys  Thu Apr 28 23:06:06 2011 (4DBA2B1E)
fffff880`05800000 fffff880`05869000  srv2  srv2.sys  Thu Apr 28 23:05:46 2011 (4DBA2B0A)
fffff880`06a7d000 fffff880`06aae000  srvnet  srvnet.sys  Thu Apr 28 23:05:35 2011 (4DBA2AFF)
fffff880`0502d000 fffff880`05090000  storport storport.sys Thu Mar 10 23:30:23 2011 (4D79A55F)
fffff880`051cd000 fffff880`051ce480  swenum  swenum.sys  Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01c00000 fffff880`01e00000  tcpip  tcpip.sys  Fri Jul 05 23:12:44 2013 (51D78B2C)
fffff880`06aae000 fffff880`06ac0000  tcpipreg tcpipreg.sys Wed Oct 03 12:07:26 2012 (506C62BE)
fffff880`0104b000 fffff880`01058000  TDI  TDI.SYS  Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`089e6000 fffff880`089f1000  tdtcp  tdtcp.sys  Thu Feb 16 23:57:32 2012 (4F3DDE3C)
fffff880`00c28000 fffff880`00c4a000  tdx  tdx.sys  Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`031af000 fffff880`031c3000  termdd  termdd.sys  Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff880`06474000 fffff880`064dc000  trufos  trufos.sys  Wed Mar 06 06:47:58 2013 (51372CEE)
fffff960`00550000 fffff960`0055a000  TSDDD  TSDDD.dll  Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`089f1000 fffff880`08a00000  tssecsrv tssecsrv.sys Sat Jun 15 00:32:15 2013 (51BBEE4F)
fffff880`04103000 fffff880`04129000  tunnel  tunnel.sys  Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05335000 fffff880`05347000  umbus  umbus.sys  Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`02eb5000 fffff880`02ecfc80  usbaudio usbaudio.sys Sat Nov 20 05:43:52 2010 (4CE7A668)
fffff880`0640e000 fffff880`0642b000  usbccgp  usbccgp.sys  Thu Mar 24 23:29:14 2011 (4D8C0C0A)
fffff880`04d3f000 fffff880`04d40f00  USBD  USBD.SYS  Thu Mar 24 23:28:59 2011 (4D8C0BFB)
fffff880`04dcd000 fffff880`04dde000  usbehci  usbehci.sys  Thu Mar 24 23:29:04 2011 (4D8C0C00)
fffff880`05347000 fffff880`053a1000  usbhub  usbhub.sys  Thu Mar 24 23:29:25 2011 (4D8C0C15)
fffff880`04c00000 fffff880`04c56000  USBPORT  USBPORT.SYS  Thu Mar 24 23:29:12 2011 (4D8C0C08)
fffff880`0654d000 fffff880`06568000  USBSTOR  USBSTOR.SYS  Thu Mar 10 23:37:16 2011 (4D79A6FC)
fffff880`0518f000 fffff880`0519e000  VClone  VClone.sys  Sat Jan 15 11:21:04 2011 (4D31C970)
fffff880`00fa5000 fffff880`00fb2000  vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019ed000 fffff880`019fb000  vga  vga.sys  Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`011da000 fffff880`011ff000  VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01a74000 fffff880`01a84000  vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00fd1000 fffff880`00fe6000  volmgr  volmgr.sys  Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`01059000 fffff880`010b5000  volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01154000 fffff880`011a0000  volsnap  volsnap.sys  Thu Feb 24 22:38:18 2011 (4D67242A)
fffff880`0316f000 fffff880`03185000  vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`053ae000 fffff880`053b6000  wacommousefilter wacommousefilter.sys Fri Feb 16 13:12:17 2007 (45D5F401)
fffff880`04e33000 fffff880`04e35a00  wacomvhid wacomvhid.sys Mon Sep 21 19:29:14 2009 (4AB80C4A)
fffff880`03194000 fffff880`031af000  wanarp  wanarp.sys  Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`017e4000 fffff880`017f4000  watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e36000 fffff880`00ef8000  Wdf01000 Wdf01000.sys Wed Jul 25 22:25:13 2012 (5010AA89)
fffff880`00ef8000 fffff880`00f08000  WDFLDR  WDFLDR.SYS  Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`03140000 fffff880`03149000  wfplwf  wfplwf.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00317000  win32k  win32k.sys  Wed Aug 07 21:20:19 2013 (5202F253)
fffff880`04fe3000 fffff880`04fec000  wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f5f000 fffff880`00f68000  WMILIB  WMILIB.SYS  Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`08839000 fffff880`08852000  WudfPf  WudfPf.sys  Wed Jul 25 22:26:45 2012 (5010AAE5)
fffff880`089b0000 fffff880`089e6000  WUDFRd  WUDFRd.sys  Wed Jul 25 22:26:06 2012 (5010AABE)
Unloaded modules:
fffff880`08911000 fffff880`08982000  spsys.sys
  Checksum:  00000000
  ImageSize:  00071000
fffff880`089b0000 fffff880`089e6000  WUDFRd.sys
  Checksum:  00000000
  ImageSize:  00036000
fffff880`01bef000 fffff880`01bfd000  crashdmp.sys
  Checksum:  00000000
  ImageSize:  0000E000
fffff880`04602000 fffff880`049a6000  dump_iaStor.
  Checksum:  00000000
  ImageSize:  003A4000
fffff880`049a6000 fffff880`049b9000  dump_dumpfve
  Checksum:  00000000
  ImageSize:  00013000
quit:
  --- E O J ---  2013 Oct 08 04:17:18 AM  dmps  Copyright 2013 Mikael Pryor
