IRQL_NOT EQUAL_OR_LESS BSOD
Hi guys , this is my first topic here , so i salute you all and here's my problem :
Lately i've been getting blue screens with the title IRQL_NOT EQUAL_OR_LESS . I don't know what to do about it . I've tried reinstalling my graphic driver - didn't fixed . The strange part is whenever a BSOD is about to happen my computer starts acting weird and won't open programs and gives me various error messages . Thanks in advance . Here's the dmp file : http://www.mediafire.com/?razde1dzaak21af
Elmer
Hi Stoch and Welcome to The Forum.
We really need to see the DMP file as it contains the only record of the sequence of events leading up to the crash, what drivers were loaded, and what was responsible.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
The .dmp files are located at C:\Windows\Minidump. Until a .dmp file is generated, the Minidump folder may not exist.
Go to your C:\Windows\Minidump folder. Copy the .dmp files to a new folder on your desktop. Zip up that folder and attach to a post.
Please see: How to ask for help with a BSOD problem Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Download and run CPU-Z. Take screenshots**/snips of the Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
Also see: http://windows7forums.com/blue-scre...lp-us-help-you-filling-your-system-specs.html
Elmer
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL
Usual causes:
Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility.
Your latest dump file lists ndis.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
dtsoftbus01.sys Wed Jul 27 15:03:27 2011 The dtsoftbus01.sys driver has been known to cause problems on some Windows 7 systems. This belongs to Daemon Tools Light. I suggest uninstalling DT Light until your blue screens are resolved. But do not replace with Daemon Tools!!
sptd.sys Sun Feb 27 19:28:51 2011 The sptd.sys driver is notorious for causing BSOD's with Windows 7. It's a driver used and installed along with Daemon Tools and Alcohol 120 which you'll also have to uninstall.
Then use the correct (32bit or 64bit) download from Duplex Secure - Downloads to uninstall the SPTD.SYS driver.
Make sure to select the uninstall button! DO NOT SELECT INSTALL!!
Drivers that pre-date Windows 7. Update:
WibuKey.sys Wed Nov 22 12:10:51 2006 WIBU-KEY Software Protection System
PPJoyBus.sys Sun Oct 24 07:11:00 2004
PPortJoy.sys Sun Oct 24 07:11:00 2004 Parallel Port Joystick
lirsgt.sys Sat Mar 07 15:17:27 2009
atksgt.sys Fri Sep 15 11:17:58
2006 Copy Protection platform, Tages SA.
giveio.sys Thu Apr 04 03:33:25 1996 Disable / Remove this driver.
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
Drivers with Updates:
Rt86win7.sys Mon Oct 25 10:32:33 2010 Realtek PCIe GBE Family Controller v7.049 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
Bugcheck Analysis:
BugCheck A, {0, 2, 1, e30817f3}
Probably caused by : ndis.sys ( ndis!NdisMIndicateReceiveNetBufferLists+52 )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000000, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, bitfield :
Arg4: e30817f3, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from e31b1848
Unable to read MiSystemVaType memory at e3190e20
 00000000
CURRENT_IRQL:  2
FAULTING_IP:
nt!memcpy+33
e30817f3 f3a5            rep movs dword ptr es:[edi],dword ptr [esi]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  d25ec994 -- (.trap 0xffffffffd25ec994)
ErrCode = 00000002
eax=c44c9b4c ebx=c399c0e0 ecx=00000173 edx=00000000 esi=c44c9580 edi=00000000
eip=e30817f3 esp=d25eca08 ebp=d25eca10 iopl=0         nv up ei pl nz ac po nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010212
nt!memcpy+0x33:
Resetting default scope
LAST_CONTROL_TRANSFER:  from e30817f3 to e30895fb
STACK_TEXT:
d25ec994 e30817f3 badb0d00 00000000 0000005d nt!KiTrap0E+0x2cf
d25eca10 c3e97ab7 00000000 c44c9580 000005cc nt!memcpy+0x33
WARNING: Frame IP not in any known module. Following frames may be wrong.
d25ecb14 ca403c78 ca4584f1 c4cabe00 c399c0e0 0xc3e97ab7
d25ecb24 c3e3aa90 00000000 00000001 00000001 ndis!NdisMIndicateReceiveNetBufferLists+0x52
d25ecb3c 00000000 d25ecc3c d9c413fa c399c0e0 0xc3e3aa90
STACK_COMMAND:  kb
FOLLOWUP_IP:
ca403c78 f6432804        test    byte ptr [ebx+28h],4
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  ndis!NdisMIndicateReceiveNetBufferLists+52
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: ndis
IMAGE_NAME:  ndis.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce78937
FAILURE_BUCKET_ID:  0xA_ndis!NdisMIndicateReceiveNetBufferLists+52
Drivers:
eabb7000 eabdf000   000      000.fcl      Fri Nov 19 00:53:14 2010 (4CE5CA7A)
c9fb7000 c9fff000   ACPI     ACPI.sys     Sat Nov 20 08:37:52 2010 (4CE788E0)
d3e1f000 d3e79000   afd      afd.sys      Mon Apr 25 03:18:00 2011 (4DB4D9D8)
da0bf000 da0d1000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
da180000 da18f000   AmdLLD   AmdLLD.sys   Fri Jun 29 20:47:32 2007 (468561D4)
ca101000 ca10a000   amdxata  amdxata.sys  Fri Mar 19 16:19:01 2010 (4BA3A3F5)
c5ad4000 c5add000   asyncmac asyncmac.sys Tue Jul 14 00:54:46 2009 (4A5BC946)
ca0d5000 ca0de000   atapi    atapi.sys    Tue Jul 14 00:11:15 2009 (4A5BBF13)
ca0de000 ca101000   ataport  ataport.SYS  Sat Nov 20 08:38:00 2010 (4CE788E8)
eaa04000 eaa46400   atksgt   atksgt.sys   Fri Sep 15 11:17:58 2006 (450A7DD6)
db620000 db66d000   ATMFD    ATMFD.DLL    unavailable (00000000)
ca3ec000 ca3f3000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
d149d000 d14ab000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
c9ca6000 c9cae000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
e5d16000 e5d2f000   bowser   bowser.sys   Wed Feb 23 04:47:32 2011 (4D649164)
db600000 db61e000   cdd      cdd.dll      unavailable (00000000)
ca18c000 ca1ab000   cdrom    cdrom.sys    Sat Nov 20 08:38:09 2010 (4CE788F1)
c9cf0000 c9d9b000   CI       CI.dll       Sat Nov 20 12:05:17 2010 (4CE7B97D)
ca5bd000 ca5e2000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
c9cae000 c9cf0000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
ca371000 ca3ce000   cng      cng.sys      Tue Jul 14 00:32:55 2009 (4A5BC427)
da0ae000 da0bb000   CompositeBus CompositeBus.sys Sat Nov 20 09:50:21 2010 (4CE799DD)
db56d000 db57a000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
d1421000 d1485000   csc      csc.sys      Sat Nov 20 08:44:32 2010 (4CE78A70)
e5dba000 e5dbaec0   cvintdrv cvintdrv.SYS Fri Jun 25 22:57:43 1999 (3773FB57)
d1485000 d149d000   dfsc     dfsc.sys     Sat Nov 20 08:42:32 2010 (4CE789F8)
d3f97000 d3fa3000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
ca609000 ca61a000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
d9dd9000 d9df2000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
ca14f000 ca18c000   dtsoftbus01 dtsoftbus01.sys Wed Jul 27 15:03:27 2011 (4E301AAF)
db585000 db58e000   dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
db57a000 db585000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
db58e000 db59f000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
db563000 db56d000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
d14de000 d1595000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:08:14 2010 (4CE78FFE)
d1595000 d15ce000   dxgmms1  dxgmms1.sys  Thu Feb 03 03:45:05 2011 (4D4A24C1)
c5add000 c5b07000   fastfat  fastfat.SYS  Tue Jul 14 00:14:01 2009 (4A5BBFB9)
da049000 da054000   fdc      fdc.sys      Tue Jul 14 00:45:45 2009 (4A5BC729)
ca13e000 ca14f000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
da1e1000 da1eb000   flpydisk flpydisk.sys Tue Jul 14 00:45:45 2009 (4A5BC729)
ca10a000 ca13e000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
ca3dc000 ca3e5000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:11:14 2009 (4A5BBF12)
ca58b000 ca5bd000   fvevol   fvevol.sys   Sat Nov 20 08:40:22 2010 (4CE78976)
ca765000 ca796000   fwpkclnt fwpkclnt.sys Sat Nov 20 08:39:08 2010 (4CE7892C)
da0a8000 da0ad280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:16:53 2009 (4A1151B5)
ca608000 ca608680   giveio   giveio.sys   Thu Apr 04 03:33:25 1996 (316334F5)
e3011000 e3048000   hal      halmacpi.dll Sat Nov 20 08:37:38 2010 (4CE788D2)
da15c000 da160880   hamachi  hamachi.sys  Thu Aug 16 00:05:00 2007 (46C3869C)
d15dd000 d15fc000   HDAudBus HDAudBus.sys Sat Nov 20 09:59:28 2010 (4CE79C00)
da000000 da013000   HIDCLASS HIDCLASS.SYS Sat Nov 20 09:59:37 2010 (4CE79C09)
da1f3000 da1f9480   HIDPARSE HIDPARSE.SYS Tue Jul 14 00:50:59 2009 (4A5BC863)
db5cc000 db5d7000   hidusb   hidusb.sys   Sat Nov 20 09:59:38 2010 (4CE79C0A)
e5c91000 e5d16000   HTTP     HTTP.sys     Sat Nov 20 08:40:17 2010 (4CE78971)
ca600000 ca608000   hwpolicy hwpolicy.sys Sat Nov 20 08:37:35 2010 (4CE788CF)
da076000 da08e000   i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
d14cc000 d14de000   intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
da09b000 da0a8000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
e0ba4000 e0bac000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
da015000 da049000   ks       ks.sys       Sat Nov 20 09:50:17 2010 (4CE799D9)
ca35e000 ca371000   ksecdd   ksecdd.sys   Sat Nov 20 08:38:54 2010 (4CE7891E)
ca4f7000 ca51c000   ksecpkg  ksecpkg.sys  Tue Jul 14 00:34:00 2009 (4A5BC468)
eaa47000 eaa4b880   lirsgt   lirsgt.sys   Sat Mar 07 15:17:27 2009 (49B29007)
e5c6e000 e5c7e000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
db5d7000 db5f2000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
c5b07000 c5b0f000   mbamswissarmy mbamswissarmy.sys Mon Sep 26 13:56:25 2011 (4E807679)
c9c10000 c9c95000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 12:00:54 2010 (4CE7B876)
c5ac9000 c5ad4000   monitor  monitor.sys  Tue Jul 14 00:25:58 2009 (4A5BC286)
da08e000 da09b000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
ca083000 ca099000   mountmgr mountmgr.sys Sat Nov 20 08:38:09 2010 (4CE788F1)
e5d2f000 e5d41000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
e5d41000 e5d64000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:17:20 2011 (4DB77CB0)
e5d64000 e5d9f000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:29:57 2011 (4E17BD25)
e5d9f000 e5dba000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:17:26 2011 (4DB77CB6)
ca1f1000 ca1fc000   Msfs     Msfs.SYS     Tue Jul 14 00:11:26 2009 (4A5BBF1E)
c9e09000 c9e11000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
ca333000 ca35e000   msrpc    msrpc.sys    Tue Jul 14 00:11:59 2009 (4A5BBF3F)
d3f8d000 d3f97000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
ca7ef000 ca7ff000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
ca402000 ca4b9000   ndis     ndis.sys     Sat Nov 20 08:39:19 2010 (4CE78937)
da0e9000 da0f4000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
da0f4000 da116000   ndiswan  ndiswan.sys  Sat Nov 20 10:07:48 2010 (4CE79DF4)
d1400000 d1411000   NDProxy  NDProxy.SYS  Sat Nov 20 10:07:39 2010 (4CE79DEB)
d3eda000 d3ee8000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
d3e79000 d3eab000   netbt    netbt.sys    Sat Nov 20 08:39:22 2010 (4CE7893A)
ca4b9000 ca4f7000   NETIO    NETIO.SYS    Sat Nov 20 08:40:03 2010 (4CE78963)
ca000000 ca00e000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
d3f83000 d3f8d000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
e3048000 e345a000   nt       ntkrpamp.exe Wed Oct 26 03:21:40 2011 (4EA76EB4)
ca204000 ca333000   Ntfs     Ntfs.sys     Fri Mar 11 03:21:11 2011 (4D799527)
eaa4c000 eaa6c000   ntk_PowerDVD ntk_PowerDVD.sys Tue Aug 03 10:04:35 2010 (4C57DBA3)
ca3e5000 ca3ec000   Null     Null.SYS     Tue Jul 14 00:11:12 2009 (4A5BBF10)
d4800000 d4804000   nvBridge nvBridge.kmd Sat May 21 04:57:55 2011 (4DD73843)
d4810000 d51ff000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:34:27 2011 (4E992973)
da178000 da17fb00   nvoclock nvoclock.sys Tue Sep 15 22:59:22 2009 (4AB00E3A)
d9c81000 d9dd9000   P17      P17.sys      Tue Apr 21 06:58:05 2009 (49ED606D)
d3ebb000 d3eda000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
da05e000 da076000   parport  parport.sys  Tue Jul 14 00:45:34 2009 (4A5BC71E)
c9dc5000 c9dd6000   partmgr  partmgr.sys  Sat Nov 20 08:38:14 2010 (4CE788F6)
e5dbb000 e5dc2000   parvdm   parvdm.sys   Tue Jul 14 00:45:29 2009 (4A5BC719)
c9d9b000 c9dc5000   pci      pci.sys      Sat Nov 20 08:37:57 2010 (4CE788E5)
ca06e000 ca075000   pciide   pciide.sys   Tue Jul 14 00:11:19 2009 (4A5BBF17)
ca075000 ca083000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:11:15 2009 (4A5BBF13)
ca3ce000 ca3dc000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
eaa6c000 eab03000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
d9c00000 d9c2f000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
da0bb000 da0be680   PPJoyBus PPJoyBus.sys Sun Oct 24 07:11:00 2004 (417B4774)
da1eb000 da1f2080   PPortJoy PPortJoy.sys Sun Oct 24 07:11:00 2004 (417B4774)
c9c95000 c9ca6000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
da0d1000 da0e9000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
da116000 da12e000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
da12e000 da145000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
da145000 da15c000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
d3f34000 d3f75000   rdbss    rdbss.sys    Sat Nov 20 08:42:44 2010 (4CE78A04)
da16c000 da176000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
ca1d9000 ca1e1000   RDPCDD   RDPCDD.sys   Sat Nov 20 10:22:19 2010 (4CE7A15B)
ca1e1000 ca1e9000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
ca1e9000 ca1f1000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
ca51c000 ca549000   rdyboost rdyboost.sys Sat Nov 20 09:00:07 2010 (4CE78E17)
e5c3d000 e5c6e000   RMCAST   RMCAST.sys   Sat Nov 20 10:06:36 2010 (4CE79DAC)
e5c7e000 e5c91000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
d9c31000 d9c81000   Rt86win7 Rt86win7.sys Mon Oct 25 10:32:33 2010 (4CC54EB1)
db202000 db5623c0   RTKVHDA  RTKVHDA.sys  Tue Oct 18 12:43:47 2011 (4E9D6673)
d3f26000 d3f33a60   SCDEmu   SCDEmu.SYS   Mon Apr 12 09:44:34 2010 (4BC2DD72)
ca549000 ca56f000   SCSIPORT SCSIPORT.SYS Sat Nov 20 09:50:55 2010 (4CE799FF)
eab03000 eab0d000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
da054000 da05e000   serenum  serenum.sys  Tue Jul 14 00:45:27 2009 (4A5BC717)
d3ee8000 d3f02000   serial   serial.sys   Tue Jul 14 00:45:33 2009 (4A5BC71D)
ca7e6000 ca7ea100   speedfan speedfan.sys Fri Mar 18 16:08:45 2011 (4D83838D)
ca7de000 ca7e6000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
c9ea1000 c9fb7000   sptd     sptd.sys     Sun Feb 27 19:28:51 2011 (4D6AA5F3)
c5a77000 c5ac9000   srv      srv.sys      Fri Apr 29 03:46:30 2011 (4DBA2686)
c5a27000 c5a77000   srv2     srv2.sys     Fri Apr 29 03:46:13 2011 (4DBA2675)
eab0d000 eab2e000   srvnet   srvnet.sys   Fri Apr 29 03:46:08 2011 (4DBA2670)
da176000 da177380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
da161000 da16c000   tap0901t tap0901t.sys Wed Sep 16 07:02:40 2009 (4AB07F80)
ca61b000 ca765000   tcpip    tcpip.sys    Thu Sep 29 04:22:11 2011 (4E83E463)
eab98000 eaba5000   tcpipreg tcpipreg.sys Sat Nov 20 10:07:13 2010 (4CE79DD1)
ca00e000 ca01a000   TDI      TDI.SYS      Sat Nov 20 08:39:18 2010 (4CE78936)
c9de6000 c9dfd000   tdx      tdx.sys      Sat Nov 20 08:39:17 2010 (4CE78935)
d3f15000 d3f26000   termdd   termdd.sys   Sat Nov 20 10:21:10 2010 (4CE7A116)
db9d0000 db9d9000   TSDDD    TSDDD.dll    unavailable (00000000)
d14ab000 d14cc000   tunnel   tunnel.sys   Sat Nov 20 10:06:40 2010 (4CE79DB0)
da18f000 da19d000   umbus    umbus.sys    Sat Nov 20 10:00:23 2010 (4CE79C37)
db5b8000 db5cbb80   usbaudio usbaudio.sys Sat Nov 20 09:59:43 2010 (4CE79C0F)
db59f000 db5b6000   usbccgp  usbccgp.sys  Fri Mar 25 02:58:06 2011 (4D8C04BE)
db5b6000 db5b7700   USBD     USBD.SYS     Fri Mar 25 02:57:53 2011 (4D8C04B1)
d15ce000 d15dd000   usbehci  usbehci.sys  Fri Mar 25 02:57:58 2011 (4D8C04B6)
da19d000 da1e1000   usbhub   usbhub.sys   Fri Mar 25 02:58:34 2011 (4D8C04DA)
d3fa3000 d3fee000   USBPORT  USBPORT.SYS  Fri Mar 25 02:58:05 2011 (4D8C04BD)
d4804000 d480f000   usbuhci  usbuhci.sys  Fri Mar 25 02:57:56 2011 (4D8C04B4)
c9e11000 c9e1c000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
ca3f3000 ca3ff000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
ca1ab000 ca1cc000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
ca099000 ca0c2180   vmbus    vmbus.sys    Sat Nov 20 09:14:58 2010 (4CE79192)
ca796000 ca79e380   vmstorfl vmstorfl.sys Sat Nov 20 09:14:37 2010 (4CE7917D)
c9dd6000 c9de6000   volmgr   volmgr.sys   Sat Nov 20 08:38:06 2010 (4CE788EE)
ca023000 ca06e000   volmgrx  volmgrx.sys  unavailable (00000000)
ca79f000 ca7de000   volsnap  volsnap.sys  Sat Nov 20 08:38:13 2010 (4CE788F5)
d3f02000 d3f15000   wanarp   wanarp.sys   Sat Nov 20 10:07:45 2010 (4CE79DF1)
ca1cc000 ca1d9000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
c9e22000 c9e93000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
c9e93000 c9ea1000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
d3eb4000 d3ebb000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
eaba5000 eabb6c00   WibuKey  WibuKey.sys  Wed Nov 22 12:10:51 2006 (45643E4B)
db770000 db9c0000   win32k   win32k.sys   unavailable (00000000)
ca0c3000 ca0d5000   winhv    winhv.sys    Sat Nov 20 08:38:15 2010 (4CE788F7)
c9e00000 c9e09000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
d3eab000 d3eb4000   ws2ifsl  ws2ifsl.sys  Tue Jul 14 00:55:01 2009 (4A5BC955)
d3e00000 d3e1a000   WudfPf   WudfPf.sys   Sat Nov 20 09:58:55 2010 (4CE79BDF)
Unloaded modules:
eab2e000 eab98000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
ca5e2000 ca5ef000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
ca5ef000 ca5fa000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
ca56f000 ca578000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
ca578000 ca589000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
d3f75000 d3f83000   prodrv06.sys
    Checksum:  00000000
    ImageSize:  0000E000
ca56f000 ca58b000   prohlp02.sys
    Checksum:  00000000
    ImageSize:  0001C000
ca7ed000 ca7ef000   prosync1.sys
    Checksum:  00000000
    ImageSize:  00002000
ca7eb000 ca7ed000   sfhlp01.sys
    Checksum:  00000000
    ImageSize:  00002000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Elmer
The problem still persists . Here's the newer dmp file :
011812-52650-01.rar
This is the same dmp file as uploaded to MediaFire. Follow instructions in my previous post.
The latest dmp file 011812-39171-01.rar gives exactly the same as the previous one (as above).
There have been a couple of updates to your April 2007 bios.
Also you have ram of mixed / sizes and timings. Try running wit the 1 stick of 2gb ram for stability.
AmdLLD64.sys AMD Low Level Device Driver (not compatible with Win7 AFAIK) Disable
You can disable drivers through the Device Manager or by renaming them.
Renaming drivers:
Create a System Restore Point. GoTo C:\Windows\System32\Drivers, locate the driver files and rename them from .sys to say, .bak.
This will break the driver and prevent it from running after the next reboot. Once you've established that having that driver in a none running state hasn't caused any adverse side effects, it will then be safe to delete it.
Sorry about it . That dmp file was a wrong one . This is the latest one :
011912-61261-01.rar
#8
Sorry about it , that was the wrong one . Here is the correct one :
http://www.mediafire.com/?04veig27uyv95mn
By the way , you said that my bios driver is old . Should i update it ?
Elmer
#9
Usual causes:
flpydisk.sys Tue Jul 14 00:45:45 2009 If you don't have a floppy disk drive installed, then disable this through Device Manager.
What is StarForce Protection System?
As a Priority:
AmdLLD.sys Fri Jun 29 20:47:32 2007 AMD Low Level Device Driver (not compatible with Win7 AFAIK) Disable
hamachi.sys Thu Aug 16 00:05:00 2007 LogMeIn Hamachi Virtual Network Driver. Has known issues with Windows 7. Update or Uninstall.
P17.sys Tue Apr 21 06:58:05 2009 Creative SB Audigy LS Updateor Uninstall.
WibuKey.sys Wed Nov 22 12:10:51 2006 WIBU-KEY Software Protection System Updateor Uninstall.
cvintdrv.SYS Fri Jun 25 22:57:43 1994 National Instruments Lab. Updateor Uninstall.
Rt86win7.sys Fri Jun 10 07:31:55 2011 Realtek PCIe GBE Family Controller v7.049 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
Bugcheck Analysis:
Loading Dump File [D:\DOWNLOADS\ DUMPS\Stoch\[B][COLOR=#0000ff]011912-61261-01.dmp[/COLOR][/B]]
Symbol search path is: SRV*C:\Windows\WinDbgSym*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x86 compatible
Built by: 7601.17713.x86fre.win7sp1_gdr.111025-1505
Machine Name:
Kernel base = 0xe301f000 PsLoadedModuleList = 0xe31684d0
Debug session time: Thu Jan 19 08:08:26.822 2012 (UTC + 0:00)
System Uptime: 0 days 1:48:15.820
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {0, 2, 1, e30587f3}
Drivers:
d0e00000 d0e28000   000      000.fcl      Fri Nov 19 00:53:14 2010 (4CE5CA7A)
c9e94000 c9edc000   ACPI     ACPI.sys     Sat Nov 20 08:37:52 2010 (4CE788E0)
d0ecf000 d0f29000   afd      afd.sys      Mon Apr 25 03:18:00 2011 (4DB4D9D8)
d1185000 d1197000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
d1022000 d1031000   AmdLLD   AmdLLD.sys   Fri Jun 29 20:47:32 2007 (468561D4)
c9e00000 c9e09000   amdxata  amdxata.sys  Fri Mar 19 16:19:01 2010 (4BA3A3F5)
f16a2000 f16ab000   asyncmac asyncmac.sys Tue Jul 14 00:54:46 2009 (4A5BC946)
c9ff5000 c9ffe000   atapi    atapi.sys    Tue Jul 14 00:11:15 2009 (4A5BBF13)
c9d92000 c9db5000   ataport  ataport.SYS  Sat Nov 20 08:38:00 2010 (4CE788E8)
dbd30000 dbd7d000   ATMFD    ATMFD.DLL    Sat Feb 19 04:34:53 2011 (4D5F486D)
d0e3a000 d0e41000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
d1112000 d1120000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
c9c9d000 c9ca5000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
da597000 da5b0000   bowser   bowser.sys   Wed Feb 23 04:47:32 2011 (4D649164)
dbd10000 dbd2e000   cdd      cdd.dll      Sat Nov 20 11:56:35 2010 (4CE7B773)
c9ce7000 c9d92000   CI       CI.dll       Sat Nov 20 12:05:17 2010 (4CE7B97D)
ca3cc000 ca3f1000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
c9ca5000 c9ce7000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
ca17b000 ca1d8000   cng      cng.sys      Tue Jul 14 00:32:55 2009 (4A5BC427)
d1178000 d1185000   CompositeBus CompositeBus.sys Sat Nov 20 09:50:21 2010 (4CE799DD)
e6c66000 e6c6f000   cpuz135_x32 cpuz135_x32.sys Wed Sep 21 09:24:20 2011 (4E799F34)
db772000 db77f000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
d1096000 d10fa000   csc      csc.sys      Sat Nov 20 08:44:32 2010 (4CE78A70)
e6c5e000 e6c5eec0   cvintdrv cvintdrv.SYS Fri Jun 25 22:57:43 1999 (3773FB57)
d10fa000 d1112000   dfsc     dfsc.sys     Sat Nov 20 08:42:32 2010 (4CE789F8)
d108a000 d1096000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
ca400000 ca411000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
d9b8c000 d9ba5000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
db78a000 db793000   dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
db77f000 db78a000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
db793000 db7a4000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
db768000 db772000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
d9c08000 d9cbf000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:08:14 2010 (4CE78FFE)
d9cbf000 d9cf8000   dxgmms1  dxgmms1.sys  Thu Feb 03 03:45:05 2011 (4D4A24C1)
f16ab000 f16d5000   fastfat  fastfat.SYS  Tue Jul 14 00:14:01 2009 (4A5BBFB9)
d9bd9000 d9be4000   fdc      fdc.sys      Tue Jul 14 00:45:45 2009 (4A5BC729)
c9de9000 c9dfa000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
da44f000 da459000   flpydisk flpydisk.sys Tue Jul 14 00:45:45 2009 (4A5BC729)
c9db5000 c9de9000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
ca1e6000 ca1ef000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:11:14 2009 (4A5BBF12)
ca39a000 ca3cc000   fvevol   fvevol.sys   Sat Nov 20 08:40:22 2010 (4CE78976)
ca562000 ca593000   fwpkclnt fwpkclnt.sys Sat Nov 20 08:39:08 2010 (4CE7892C)
e3431000 e3468000   hal      halmacpi.dll Sat Nov 20 08:37:38 2010 (4CE788D2)
d9bfb000 d9bff880   hamachi  hamachi.sys  Thu Aug 16 00:05:00 2007 (46C3869C)
d9d5d000 d9d7c000   HDAudBus HDAudBus.sys Sat Nov 20 09:59:28 2010 (4CE79C00)
db7e7000 db7fa000   HIDCLASS HIDCLASS.SYS Sat Nov 20 09:59:37 2010 (4CE79C09)
db400000 db406480   HIDPARSE HIDPARSE.SYS Tue Jul 14 00:50:59 2009 (4A5BC863)
db7dc000 db7e7000   hidusb   hidusb.sys   Sat Nov 20 09:59:38 2010 (4CE79C0A)
da512000 da597000   HTTP     HTTP.sys     Sat Nov 20 08:40:17 2010 (4CE78971)
ca5f7000 ca5ff000   hwpolicy hwpolicy.sys Sat Nov 20 08:37:35 2010 (4CE788CF)
d1153000 d116b000   i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
d1141000 d1153000   intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
d116b000 d1178000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
e0bb5000 e0bbd000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
d9ba5000 d9bd9000   ks       ks.sys       Sat Nov 20 09:50:17 2010 (4CE799D9)
ca168000 ca17b000   ksecdd   ksecdd.sys   Sat Nov 20 08:38:54 2010 (4CE7891E)
ca306000 ca32b000   ksecpkg  ksecpkg.sys  Tue Jul 14 00:34:00 2009 (4A5BC468)
da4ef000 da4ff000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
da489000 da4a4000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
c9c07000 c9c8c000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 12:00:54 2010 (4CE7B876)
db7a4000 db7af000   monitor  monitor.sys  Tue Jul 14 00:25:58 2009 (4A5BC286)
d9bee000 d9bfb000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
c9fa3000 c9fb9000   mountmgr mountmgr.sys Sat Nov 20 08:38:09 2010 (4CE788F1)
da5b0000 da5c2000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
da5c2000 da5e5000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:17:20 2011 (4DB77CB0)
e6c08000 e6c43000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:29:57 2011 (4E17BD25)
e6c43000 e6c5e000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:17:26 2011 (4DB77CB6)
d0e93000 d0e9e000   Msfs     Msfs.SYS     Tue Jul 14 00:11:26 2009 (4A5BBF1E)
c9ee5000 c9eed000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
ca13d000 ca168000   msrpc    msrpc.sys    Tue Jul 14 00:11:59 2009 (4A5BBF3F)
d1080000 d108a000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
ca5e7000 ca5f7000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
ca211000 ca2c8000   ndis     ndis.sys     Sat Nov 20 08:39:19 2010 (4CE78937)
d3804000 d380f000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
d11af000 d11d1000   ndiswan  ndiswan.sys  Sat Nov 20 10:07:48 2010 (4CE79DF4)
da459000 da46a000   NDProxy  NDProxy.SYS  Sat Nov 20 10:07:39 2010 (4CE79DEB)
d0f8a000 d0f98000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
d0f29000 d0f5b000   netbt    netbt.sys    Sat Nov 20 08:39:22 2010 (4CE7893A)
ca2c8000 ca306000   NETIO    NETIO.SYS    Sat Nov 20 08:40:03 2010 (4CE78963)
d0e9e000 d0eac000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
d1076000 d1080000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
e301f000 e3431000   nt       ntkrpamp.exe Wed Oct 26 03:21:40 2011 (4EA76EB4)
ca00e000 ca13d000   Ntfs     Ntfs.sys     Fri Mar 11 03:21:11 2011 (4D799527)
e6c6f000 e6c8f000   ntk_PowerDVD ntk_PowerDVD.sys Tue Aug 03 10:04:35 2010 (4C57DBA3)
d0e33000 d0e3a000   Null     Null.SYS     Tue Jul 14 00:11:12 2009 (4A5BBF10)
d3800000 d3804000   nvBridge nvBridge.kmd Sat May 21 04:57:55 2011 (4DD73843)
d3810000 d41ff000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:34:27 2011 (4E992973)
d9c00000 d9c07b00   nvoclock nvoclock.sys Tue Sep 15 22:59:22 2009 (4AB00E3A)
d9a05000 d9b5d000   P17      P17.sys      Tue Apr 21 06:58:05 2009 (49ED606D)
d0f6b000 d0f8a000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
d9dde000 d9df6000   parport  parport.sys  Tue Jul 14 00:45:34 2009 (4A5BC71E)
c9f22000 c9f33000   partmgr  partmgr.sys  Sat Nov 20 08:38:14 2010 (4CE788F6)
e6c5f000 e6c66000   parvdm   parvdm.sys   Tue Jul 14 00:45:29 2009 (4A5BC719)
c9ef8000 c9f22000   pci      pci.sys      Sat Nov 20 08:37:57 2010 (4CE788E5)
c9f8e000 c9f95000   pciide   pciide.sys   Tue Jul 14 00:11:19 2009 (4A5BBF17)
c9f95000 c9fa3000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:11:15 2009 (4A5BBF13)
ca1d8000 ca1e6000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
e6c8f000 e6d26000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
d9b5d000 d9b8c000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
c9c8c000 c9c9d000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
d1197000 d11af000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
d11d1000 d11e9000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
d11e9000 d1200000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
d1000000 d1017000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
d1035000 d1076000   rdbss    rdbss.sys    Sat Nov 20 08:42:44 2010 (4CE78A04)
d9df6000 d9e00000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
d0e7b000 d0e83000   RDPCDD   RDPCDD.sys   Sat Nov 20 10:22:19 2010 (4CE7A15B)
d0e83000 d0e8b000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
d0e8b000 d0e93000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
ca32b000 ca358000   rdyboost rdyboost.sys Sat Nov 20 09:00:07 2010 (4CE78E17)
da4be000 da4ef000   RMCAST   RMCAST.sys   Sat Nov 20 10:06:36 2010 (4CE79DAC)
da4ff000 da512000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
d9d7c000 d9dde000   Rt86win7 Rt86win7.sys Fri Jun 10 07:31:55 2011 (4DF1BA5B)
db407000 db7673c0   RTKVHDA  RTKVHDA.sys  Tue Oct 18 12:43:47 2011 (4E9D6673)
d0fd6000 d0fe3a60   SCDEmu   SCDEmu.SYS   Mon Apr 12 09:44:34 2010 (4BC2DD72)
ca358000 ca37e000   SCSIPORT SCSIPORT.SYS Sat Nov 20 09:50:55 2010 (4CE799FF)
e6d26000 e6d30000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
d9be4000 d9bee000   serenum  serenum.sys  Tue Jul 14 00:45:27 2009 (4A5BC717)
d0f98000 d0fb2000   serial   serial.sys   Tue Jul 14 00:45:33 2009 (4A5BC71D)
ca5db000 ca5e3000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
f1650000 f16a2000   srv      srv.sys      Fri Apr 29 03:46:30 2011 (4DBA2686)
f1600000 f1650000   srv2     srv2.sys     Fri Apr 29 03:46:13 2011 (4DBA2675)
e6d30000 e6d51000   srvnet   srvnet.sys   Fri Apr 29 03:46:08 2011 (4DBA2670)
d9a00000 d9a01380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
d1017000 d1022000   tap0901t tap0901t.sys Wed Sep 16 07:02:40 2009 (4AB07F80)
ca418000 ca562000   tcpip    tcpip.sys    Thu Sep 29 04:22:11 2011 (4E83E463)
e6d51000 e6d5e000   tcpipreg tcpipreg.sys Sat Nov 20 10:07:13 2010 (4CE79DD1)
d0ec3000 d0ecf000   TDI      TDI.SYS      Sat Nov 20 08:39:18 2010 (4CE78936)
d0eac000 d0ec3000   tdx      tdx.sys      Sat Nov 20 08:39:17 2010 (4CE78935)
d0fc5000 d0fd6000   termdd   termdd.sys   Sat Nov 20 10:21:10 2010 (4CE7A116)
dbce0000 dbce9000   TSDDD    TSDDD.dll    unavailable (00000000)
d1120000 d1141000   tunnel   tunnel.sys   Sat Nov 20 10:06:40 2010 (4CE79DB0)
d0fe4000 d0ff2000   umbus    umbus.sys    Sat Nov 20 10:00:23 2010 (4CE79C37)
db7c8000 db7dbb80   usbaudio usbaudio.sys Sat Nov 20 09:59:43 2010 (4CE79C0F)
db7af000 db7c6000   usbccgp  usbccgp.sys  Fri Mar 25 02:58:06 2011 (4D8C04BE)
db7c6000 db7c7700   USBD     USBD.SYS     Fri Mar 25 02:57:53 2011 (4D8C04B1)
d9d4e000 d9d5d000   usbehci  usbehci.sys  Fri Mar 25 02:57:58 2011 (4D8C04B6)
da40b000 da44f000   usbhub   usbhub.sys   Fri Mar 25 02:58:34 2011 (4D8C04DA)
d9d03000 d9d4e000   USBPORT  USBPORT.SYS  Fri Mar 25 02:58:05 2011 (4D8C04BD)
d9cf8000 d9d03000   usbuhci  usbuhci.sys  Fri Mar 25 02:57:56 2011 (4D8C04B4)
c9eed000 c9ef8000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
d0e41000 d0e4d000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
d0e4d000 d0e6e000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
c9fb9000 c9fe2180   vmbus    vmbus.sys    Sat Nov 20 09:14:58 2010 (4CE79192)
ca593000 ca59b380   vmstorfl vmstorfl.sys Sat Nov 20 09:14:37 2010 (4CE7917D)
c9f33000 c9f43000   volmgr   volmgr.sys   Sat Nov 20 08:38:06 2010 (4CE788EE)
c9f43000 c9f8e000   volmgrx  volmgrx.sys  Tue Jul 14 00:11:41 2009 (4A5BBF2D)
ca59c000 ca5db000   volsnap  volsnap.sys  Sat Nov 20 08:38:13 2010 (4CE788F5)
d0fb2000 d0fc5000   wanarp   wanarp.sys   Sat Nov 20 10:07:45 2010 (4CE79DF1)
d0e6e000 d0e7b000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
c9e15000 c9e86000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
c9e86000 c9e94000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
d0f64000 d0f6b000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
e6dc8000 e6dd9c00   WibuKey  WibuKey.sys  Wed Nov 22 12:10:51 2006 (45643E4B)
dba80000 dbcd0000   win32k   win32k.sys   Thu Nov 24 04:25:06 2011 (4ECDC722)
c9fe3000 c9ff5000   winhv    winhv.sys    Sat Nov 20 08:38:15 2010 (4CE788F7)
c9edc000 c9ee5000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
d0f5b000 d0f64000   ws2ifsl  ws2ifsl.sys  Tue Jul 14 00:55:01 2009 (4A5BC955)
da4a4000 da4be000   WudfPf   WudfPf.sys   Sat Nov 20 09:58:55 2010 (4CE79BDF)
Unloaded modules:
e6d5e000 e6dc8000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
da46a000 da489000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0001F000
ca3f1000 ca3fe000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
ca200000 ca20b000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
ca37e000 ca387000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
ca387000 ca398000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
d0e14000 d0e33000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0001F000
ca37e000 ca39a000   prohlp02.sys
    Checksum:  00000000
    ImageSize:  0001C000
ca5e5000 ca5e7000   prosync1.sys
    Checksum:  00000000
    ImageSize:  00002000
ca5e3000 ca5e5000   sfhlp01.sys
    Checksum:  00000000
    ImageSize:  00002000
Elmer
#10
BTW stoch, There is no need to duplicate your uploaded dmp files with links to MediaFire.
Just attach them to a post here.
HTH.
#11
I've just done a complete format too all my hdd's . The problem seems to be gone . Thanks for your effort mate :) Really appreciated .
Elmer
#12
No Prob. Some times you have to just bite the bullet etc etc..
