Windows 7 IRQL_NOT_LESS_OR_EQUAL
Only 117 Windows Updates installed. Most systems have 130-140 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
2 problem devices:
Broadcom 802.11g Network Adapter PCI\VEN_14E4&DEV_4318&SUBSYS_100F1043&REV_02\4&2B4059EA&0&38A4 This device cannot find enough free resources that it can use.
AODDriver4.2 ROOT\LEGACY_AODDRIVER4.2\0000 This device is not present, is not working properly, or does not have all its drivers installed.
Uninstall the drivers/software for the wireless Broadcom device - then install a fresh set of Win7 compatible drivers and see if the device is able to function.
As for the AODDriver4.2, please do this:
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
LHidFilt.Sys Wed Jun 17 12:49:39 2009 (4A391EA3)
Logitech SetPoint HID Filter Driver
http://www.carrona.org/drivers/driver.php?id=LHidFilt.Sys
LMouFilt.Sys Wed Jun 17 12:49:43 2009 (4A391EA7)
http://www.carrona.org/drivers/driver.php?id=LMouFilt.Sys
LUsbFilt.Sys Wed Jun 17 12:49:46 2009 (4A391EAA)
Logitech SetPoint USB Filter
http://www.carrona.org/drivers/driver.php?id=LUsbFilt.Sys
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics: Hardware Diagnostics. Let us know the results and we can move on from there.
Also, If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Wed Feb  6 18:44:35.125 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020613-38828-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 8:37:51.296[/B]
Probably caused by :[B]memory_corruption ( nt!MiFindNodeOrParent+0 )[/B]
BugCheck [B]A, {28, 2, 0, fffff80002b180f0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000000A"]IRQL_NOT_LESS_OR_EQUAL (a)[/URL]
Arguments:
Arg1: 0000000000000028, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002b180f0, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiFindNodeOrParent+0[/B]
  BIOS Version                  V17.7
  BIOS Release Date             09/09/2010
  Manufacturer                  MSI
  Product Name                  MS-7599
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]LHidFilt.Sys                Wed Jun 17 12:49:39 2009 (4A391EA3)[/B][/COLOR]
[COLOR=RED][B]LMouFilt.Sys                Wed Jun 17 12:49:43 2009 (4A391EA7)[/B][/COLOR]
[COLOR=RED][B]LUsbFilt.Sys                Wed Jun 17 12:49:46 2009 (4A391EAA)[/B][/COLOR]
[COLOR=RED][B]bcmwl664.sys                Tue Jul  7 20:45:04 2009 (4A53EC10)[/B][/COLOR]
AtiPcie64.sys               Wed Mar 10 09:33:45 2010 (4B97ADC9)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
usbfilter.sys               Mon Nov 29 04:50:21 2010 (4CF3775D)
nusb3hub.sys                Thu Feb 10 00:52:32 2011 (4D537D20)
nusb3xhc.sys                Thu Feb 10 00:52:33 2011 (4D537D21)
Rt64win7.sys                Thu Feb 16 00:39:50 2012 (4F3C96A6)
[COLOR=RED][B]AODDriver2.sys              Thu Apr  5 05:23:37 2012 (4F7D6499)[/B][/COLOR]
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
MpFilter.sys                Thu Aug 23 19:03:14 2012 (5036B6B2)
AtihdW76.sys                Tue Nov  6 16:41:51 2012 (5099841F)
atikmpag.sys                Wed Dec 19 14:32:55 2012 (50D21667)
atikmdag.sys                Wed Dec 19 15:38:55 2012 (50D225DF)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=bcmwl664.sys
http://www.carrona.org/drivers/driver.php?id=AtiPcie64.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
Seeing as how I didn't use the Wireless Receiver, I simply removed it from my machine. Can I remove the driver without the receiver plugged in?
I uninstalled all AMD/ATI stuff and reinstalled just the driver with your instructions. I also updated the Logitech Setpoint software with new drivers. I will reply again if another BSOD happens.
Sidenote: How would I know if my chipset drivers need to be reinstalled after uninstalling all the AMD/ATI stuff?
You can uninstall the wireless receiver's programs from Control Panel...Programs and Features...Uninstall a program.
If your chipset drivers are a problem, you'll see errors in Device Manager (devmgmt.msc)
Alternatively, you can run MSINFO32.exe and check the Components...Problem Devices category
Just FYI - your chipset is: AMD® 770 and SB710 Chipset
Downloads are available here: AMD Chipset Drivers
It won't hurt if you update them, but hold off until we see if the BSOD's recur.
I thought the problem was solved, but I have had 3 BSOD in quite quick succession. The first was last night a DRIVER_IRQL_NOT_LESS_OR_EQUAL 0x000000d1. I shut the pc down for the night, then when I turned it on it had another with PFN_LIST_CORRUPT 0x0000004e, and after it rebooted from that a KMODE_EXCEPTION_NOT_HANDLED 0x0000001e. The only thing they had in common was I was browsing the internet in Chrome at the time. I have attached all the files again.
View attachment W7F_paralydsedbeaver 2.zip
Out of 6 memory dumps there were 5 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
Have you removed the AMD Overdrive as I suggested in my previous post? If not, please do so. If you have, then please try these additional steps:
If AODDriver2.sys is still present and the software/device isn't present and the driver isn't needed - then please do this (thanks to jcgriff2):
Bring up elevated Admin cmd prompt -
START | type cmd.exe | RIGHT-click on cmd.exe | "Run as Administrator" | type/ paste the following -
where /r c:\ /f /t AODDrive*.* > 0 & start notepad 0
It may take a few minutes.
A Notepad will open wth the results. That will state the location of all OverDrive drivers.
Please post the results in your next post.
Then:
- create a System Restore point.
- create a System Repair disc and ensure that it works. To do this, go to Start...All Programs...Maintenance...Create a System Repair Disc
- un-install all ATI video stuff using Control Panel...Programs...Un-install a program (this may make the next 3 steps unnecessary - if so, just continue on).
- check in services.msc to see if there is an AOD service. If there is, set it to "Disabled" for the startup type.
- then disable any startups that name AODDriver2.sys using Autoruns (free from here: Autoruns for Windows )
- rename AODDriver2.sys to AODDriver2.BAD (it's probably in C:\Windows\System32\drivers)
----------01 June 2012 - Owner found AOD in C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64
- reboot and see if that fixes the problem(s). Check in C:\Windows\System32\drivers (or the other folder) to be sure that it stays renamed.
- install fresh video drivers using the procedure here: ATI video cards - DRIVER ONLY installation procedure
DO NOT install the full Catalyst Control Center package!!!
Broadcom 802.11g Network Adapter - Dell Wireless 1390 WLAN Mini-Card
Analysis:
[FONT=lucida console]**************************Sat Feb  9 12:41:12.252 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020913-23821-01.dmp]
System Uptime:[B]0 days 0:05:12.423[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObpLookupObjectName+21e )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff80002fda06e, 0, 90}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001E"]KMODE_EXCEPTION_NOT_HANDLED (1e)[/URL]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002fda06e, The address that the exception occurred at
Arg4: 0000000000000090, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!ObpLookupObjectName+21e[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Sat Feb  9 12:35:26.599 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020913-21808-01.dmp]
System Uptime:[B]0 days 0:15:36.770[/B]
Probably caused by :[B]memory_corruption ( nt!MiBadShareCount+4c )[/B]
BugCheck [B]4E, {99, 114aa5, 2, 124ba4}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000004E"]PFN_LIST_CORRUPT (4e)[/URL]
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000114aa5, page frame number
Arg3: 0000000000000002, current page state
Arg4: 0000000000124ba4, 0
BUGCHECK_STR:  0x4E_99
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]X64_0x4E_99_nt!MiBadShareCount+4c[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Sat Feb  9 01:55:09.806 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020913-26956-01.dmp]
System Uptime:[B]0 days 13:54:40.976[/B]
*** WARNING: Unable to verify timestamp for Rt64win7.sys
*** ERROR: Module load completed but symbols could not be loaded for Rt64win7.sys
Probably caused by :[B]Rt64win7.sys ( Rt64win7+17dd1 )[/B]
BugCheck [B]D1, {13, 2, 1, fffff88004497dd1}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000000013, memory referenced
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88004497dd1, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0xD1_Rt64win7+17dd1[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Thu Feb  7 15:30:28.789 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020713-25677-01.dmp]
System Uptime:[B]0 days 0:01:05.335[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObLogSecurityDescriptor+c2 )[/B]
BugCheck [B]3B, {c0000005, fffff80002fca4c1, fffff88009011cc0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000003B"]SYSTEM_SERVICE_EXCEPTION (3b)[/URL]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002fca4c1, Address of the instruction which caused the bugcheck
Arg3: fffff88009011cc0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  SearchIndexer.
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!ObLogSecurityDescriptor+c2[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Thu Feb  7 00:06:58.453 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020713-27768-01.dmp]
System Uptime:[B]0 days 2:58:53.999[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+275 )[/B]
BugCheck [B]C2, {7, 109b, 0, fffffa8003e12420}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000C2"]BAD_POOL_CALLER (c2)[/URL]
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 000000000000109b, (reserved)
Arg3: 0000000000000000, Memory contents of the pool block
Arg4: fffffa8003e12420, Address of the block of pool being deallocated
BUGCHECK_STR:  0xc2_7_KPXY
PROCESS_NAME:  Borderlands2.e
FAILURE_BUCKET_ID: [B]X64_0xc2_7_KPXY_dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+275[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Wed Feb  6 21:07:27.704 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020713-22526-01.dmp]
System Uptime:[B]0 days 2:21:51.249[/B]
BugCheck [B]4E, {99, 120175, 0, 22a75}[/B]
Arguments:
Arg2: 0000000000120175, page frame number
Arg3: 0000000000000000, current page state
Arg4: 0000000000022a75, 0
  BIOS Version                  V17.7
  Manufacturer                  MSI
[/FONT]
3rd Party Drivers:
LGBusEnum.sys               Mon Nov 23 20:36:48 2009 (4B0B38B0)
LGVirHid.sys                Mon Nov 23 20:36:48 2009 (4B0B38B0)
AtihdW76.sys                Thu Feb 23 07:30:12 2012 (4F463154)
LGSUsbFilt.Sys              Wed Aug 22 18:26:33 2012 (50355C99)
LGSHidFilt.Sys              Wed Aug 22 18:27:24 2012 (50355CCC)
cpuz136_x64.sys             Sat Oct 27 13:24:41 2012 (508C18D9)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys
http://www.carrona.org/drivers/driver.php?id=LGVirHid.sys
LGSUsbFilt.Sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=LGSHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=cpuz136_x64.sys
     57472   09/04/2012      09:13:58  "c:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\aoddriver2.sys"
I did all the stuff that you quoted. I followed the guide the last time on installing the video drivers only. There is no AMD or ATI stuff in my Uninstall Programs panel, yet I have the control center.
I uninstalled all the Logitech software. The mouse (Logitech MX™518) is now just running on the drivers that appear when it's plugged in. But the 3 Logitech drivers you quoted are still floating around in the system32/drivers folder.
The Broadcom 802.11g Network Adapter - Dell Wireless 1390 WLAN Mini-Card is now working properly. I removed it from the system after your last reply as it was giving me a code 12 (not enough resources). I reinstalled it in the hopes I could uninstall the driver, but nothing appears in the Uninstall Programs panel for it, and it seems to be working fine.
Now do this to ensure you can safely get rid of the problem AODDriver2.sys driver:
- rename AODDriver2.sys to AODDriver2.BAD (it's in: c:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\aoddriver2.sys )
- reboot and see if that fixes the problem(s). Check in C:\Program Files\ATI Technologies\ATI.ACE\Fule\amd64 to be sure that it stays renamed.
If the system is unable to boot, boot from the System Repair Disc to the Command Prompt option.
- Rename AODDriver2.BAD to AODDriver2.sys
ren c:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\aoddriver2.BAD c:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\aoddriver2.sys
- Then reboot from the System Repair Disc again - this time into the System Restore option.
Reset the system to the System Restore point that you set previously.
System restore point created. System Repair disc created. No ATI or AMD stuff in Un-install a program menu. No AOD services in services.msc. Two entries found using Autoruns using AODDriver2.sys (AODDriver4.1 and AODDriver4.2). Both disabled. AODDriver.sys renamed to AODDriver.BAD. System rebooted fine.
Should I reinstall the fresh video drivers if I had already followed that advice from your first post?
Leave well enough alone for now.
The primary concern is that the AODDriver2.sys file isn't loading.
Please run Driver Verifier according to these instructions: Driver Verifier Settings
Please run the free video tests at this link: Additional Hardware Diagnostics
Please update your wireless drivers also.
Analysis:
[font=lucida console]**************************Tue Feb 12 19:05:13.936 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021313-21216-01.dmp]
System Uptime:[B]0 days 1:58:10.481[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_PROCESS_HEAP::UnmapViewOfAllocation+78 )[/B]
BugCheck [B]A, {28, 2, 0, fffff80002cc60f0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg4: fffff80002cc60f0, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_dxgmms1!VIDMM_PROCESS_HEAP::UnmapViewOfAllocation+78[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
[/font]
3rd Party Drivers:
mbam.sys                    Mon Aug 20 12:49:41 2012 (50326AA5)
[/font]
http://www.carrona.org/drivers/driver.php?id=mbam.sys
To add on:
Noticing you have several dumps pointing to svchost.exe:
Svchost.exe manages your services - whichever service needs to access a server/internet, svchost controls that.
Try this:
in start menu's search bar - search "msconfig".
Under the "startup" tab - uncheck ALL of the services (except any that are crucial - examples of crucial ones: antivirus, firewall///examples of unnecessary ones: Adobe Update, Google Update)
Restart computer and see if the problem still repeats
A few others point to Chrome:
Most obvious - reinstalling chrome.
If you use a modem, reset it:
--- Few ways to do this:
--------First one:
Find a button on the back of the modem, press it down for 10 seconds.
--------Second one:
Go to Internet Explorer (or Chrome, Firefox, whatever) and type in on the address bar - "192.168.2.1" (this is the default home IP for many computers [in my experience anyway], not sure about yours but give it a shot). There you should be able to see an interface with various options. Search for a button/link named "Reset Network Router" or "Reset <modem, internet, something along those lines>". Click it, wait, and retest.
It hasn't exactly BSOD'ed yet, but it keeps crashing. Usually the screen would go like this: http://i.imgur.com/NDL3hA5.jpg (the colours underneath are just what was on the screen at the time of the crash) and then proceed to the BSOD screen. Now it just freezes on that screen and doesn't do anything.
The blue screens have become less frequent. I uninstalled everything AMD/ATI with the help of Revo uninstaller, and then cleaned it up in safe mode with driver sweeper. The next one that occurs, I will run the diagnostic tool again.
Just FYI- I will be traveling tomorrow, so I probably won't be able to answer until Friday.
Please un-install MSI Afterburner. If unable to locate it, then un-install MSI Live Update 5. The NTIOLib_X64.sys driver is known to cause BSOD's in some Windows systems.
Please update this older driver to the latest Win8 compatible version. Links are included to assist in looking up the source of the drivers. If unable to find an update, please remove (un-install) the program responsible for that driver. DO NOT manually delete/rename the driver as it may make the system unbootable! :
If the BSOD's continue after these things, please run these free hardware diagnostics: Hardware Diagnostics
Analysis:
[font=lucida console]**************************Wed Feb 20 21:29:13.913 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022113-17097-01.dmp]
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 0:03:29.084[/B]
Probably caused by :[B]Rt64win7.sys ( Rt64win7+18612 )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff8800a1c9940, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001E]KMODE_EXCEPTION_NOT_HANDLED (1e)[/url]
Arguments:
Arg2: fffff8800a1c9940, The address that the exception occurred at
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_Rt64win7+18612[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Wed Feb 20 21:25:11.502 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022113-17752-01.dmp]
System Uptime:[B]0 days 0:05:17.047[/B]
BugCheck [B]3B, {c0000005, fffff8000316ab51, fffff88009cd1c80, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg2: fffff8000316ab51, Address of the instruction which caused the bugcheck
Arg3: fffff88009cd1c80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  WMIADAP.exe
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Wed Feb 20 21:19:21.444 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022113-19890-01.dmp]
System Uptime:[B]0 days 0:01:36.989[/B]
BugCheck [B]4E, {99, 116632, 0, 116732}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000004E]PFN_LIST_CORRUPT (4e)[/url]
Arguments:
Arg2: 0000000000116632, page frame number
Arg4: 0000000000116732, 0
PROCESS_NAME:  mbamservice.ex
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Wed Feb 20 21:17:07.121 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022113-19437-01.dmp]
System Uptime:[B]0 days 1:37:45.666[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+48de1 )[/B]
BugCheck [B]18, {0, fffffa8003fa2e90, 2, ffffffffffffffff}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000018]REFERENCE_BY_POINTER (18)[/url]
Arguments:
Arg1: 0000000000000000, Object type of the object whose reference count is being lowered
Arg2: fffffa8003fa2e90, Object whose reference count is being lowered
Arg3: 0000000000000002, Reserved
Arg4: ffffffffffffffff, Reserved
    The reference count of an object is illegal for the current state of the object.
    Each time a driver uses a pointer to an object the driver calls a kernel routine
    to increment the reference count of the object. When the driver is done with the
    pointer the driver calls another kernel routine to decrement the reference count.
    Drivers must match calls to the increment and decrement routines. This bugcheck
    can occur because an object's reference count goes to zero while there are still
    open handles to the object, in which case the fourth parameter indicates the number
    of opened handles. It may also occur when the object?s reference count drops below zero
    whether or not there are open handles to the object, and in that case the fourth parameter
    contains the actual value of the pointer references count.
BUGCHECK_STR:  0x18
PROCESS_NAME:  vlc.exe
FAILURE_BUCKET_ID: [B]X64_0x18_OVER_DEREFERENCE_nt!_??_::FNODOBFM::_string_+48de1[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
**************************Wed Feb 20 19:38:46.495 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\022113-21637-01.dmp]
System Uptime:[B]0 days 5:27:18.666[/B]
*** ERROR: Module load completed but symbols could not be loaded for cdd.dll
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_PROCESS_HEAP::Free+a2 )[/B]
BugCheck [B]1A, {403, fffff6800002a6a8, e52000001ddff847, fffff680000226a8}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001A]MEMORY_MANAGEMENT (1a)[/url]
Arguments:
Arg1: 0000000000000403, The subtype of the bugcheck.
Arg2: fffff6800002a6a8
Arg3: e52000001ddff847
Arg4: fffff680000226a8
BUGCHECK_STR:  0x1a_403
PROCESS_NAME:  csrss.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_403_dxgmms1!VIDMM_PROCESS_HEAP::Free+a2[/B]
  BIOS Version                  V17.7
  Manufacturer                  MSI
[/font]
3rd Party Drivers:
[COLOR=RED][B]NTIOLib_X64.sys             Wed Oct 20 02:45:49 2010 (4CBE901D)[/B][/COLOR]
AtihdW76.sys                Fri May 11 04:25:40 2012 (4FACCD04)
Rt64win7.sys                Tue Jun 12 10:00:29 2012 (4FD74B7D)
MpFilter.sys                Wed Oct 31 18:43:06 2012 (5091A97A)
RTKVHD64.sys                Tue Dec  4 08:28:37 2012 (50BDFA85)
[/font]
http://www.carrona.org/drivers/driver.php?id=NTIOLib_X64.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
I can't find an updated driver for the Broadcom 802.11g Network Adapter - Dell Wireless 1390 WLAN Mini-Card. It's also not in uninstall a program, so I can't remove it from there. Since I don't use the wireless, could I simply remove the card from my system and then delete that driver?
