If you are on Windows XP and planning to UPGRADE...
YOU MUST DO A CLEAN INSTALL.
There is no upgrade path. There are user migration tools you can use, but you will need to backup your files and do a clean install.
I have seen several threads about this and just want to clarify. The upgrade from Windows Vista is a valid upgrade path, but Windows XP to Windows 7 is not
