k mode exception not handled
Here is a BSOD I received it AM while sleeping, by my little bit of research on Google I think it is Video card related, though I am not sure, any and all help appreciated View attachment 070710-41277-01.zip
Hey. Still having intelppm.sys problems but it's also showing it's a hardware error. If there is any overclocking going on in the cpu/ram/vram/gpu, I'd be inclined to look at this as being a possible cause first. Two other things I can suggest are to make sure the chipset drivers and any motherboard utilities installed are updated to latest.
And also, the last part of this post still applies about removing DRVEDDM.sys:
Yes that is why I think it is video card a GTX 260 I set it from Stock 576 clock to 650 using Riva Tuner so I dialed it back to 625, I will see what happens. I went 3 days with out a problem until I played with Riva Tuner, so I can pretty well establish this was caused by Overclocking Video card
I thnk you for your quick reply
