Keyboard issue
Hi all some suggestions please.
On one account only when you type the @ key on the keyboard it actually produces a " symbol and vice versa. Any ideas how this can be rectified?
zvit
Honorable Member
You have set the keyboard layout incorrectly. Go to control panel, regional options and set the keyboard layout to match your keyboard.
Also, check the system tray for the language bar. If you see some two letters there like EN or FR try clicking it and choosing another language.
zvit, Thanks very much for your advice - it now works perfectly. Thanks again very much appreciated.
