It seems like the language display on your Windows 8 desktop has been inverted or is showing incorrectly after restoring the system. To address this language display issue, follow these steps: 1. Check Language Settings: - Go to the Control Panel. - Find the Language settings or Region settings. 2. Change Display Language: - Adjust the settings to ensure the correct language is selected as the display language. - Set Arabic as the primary display language. 3. Region Settings: - Verify that both the Display Language and the Regional Format are correctly set to Arabic. - Make sure the date, time, number format, and currency formats all align with Arabic settings. 4. Advanced Language Settings: - Check the advanced...
