laptop bsod problem
Hello everyone,
I have problem with laptop. It worked well before it happened suddenly.
It craches and shows bsod (attached image)
When I restart laptop vertical discontinued lines are shown during bios hardware check. Then if I choose normal Windows mod bsod pops out, if I choose safe mode, somtimes it works on laptop screen (very rare) but it always works with external monitor plugged in VGA port on laptop.
After successuful reinstallation of Win7x64 it started to happen again. During installation and restarting everyting was fine but few minutes later even before I installed any drivers bsod popped out, and I forgot to say, laptop screen worked during installation.
BlueScreenView.exe (attached image)
fujitsu siemens amilo pi2550
graphic card ati HD2400
another attachment, .dmp file
kaos
Hi and welcome
* Bugcheck Analysis *
THREAD_STUCK_IN_DEVICE_DRIVER_M (100000ea)
The device driver is spinning in an infinite loop, most likely waiting for
hardware to become idle. This usually indicates problem with the hardware
itself or with the device driver programming the hardware incorrectly.
If the kernel debugger is connected and running when watchdog detects a
timeout condition then DbgBreakPoint() will be called instead of KeBugCheckEx()
and detailed message including bugcheck arguments will be printed to the
debugger. This way we can identify an offending thread, set breakpoints in it,
and hit go to return to the spinning code to debug it further. Because
KeBugCheckEx() is not called the .bugcheck directive will not return bugcheck
information in this case. The arguments are already printed out to the kernel
debugger. You can also retrieve them from a global variable via
"dd watchdog!g_WdBugCheckData l5" (use dq on NT64).
On MP machines it is possible to hit a timeout when the spinning thread is
interrupted by hardware interrupt and ISR or DPC routine is running at the time
of the bugcheck (this is because the timeout's work item can be delivered and
handled on the second CPU and the same time). If this is the case you will have
to look deeper at the offending thread's stack (e.g. using dds) to determine
spinning code which caused the timeout to occur.
Arguments:
Arg1: fffffa8004aa1620, Pointer to a stuck thread object. Do .thread then kb on it to find
the hung location.
Arg2: 0000000000000000, Pointer to a DEFERRED_WATCHDOG object.
Arg3: 0000000000000000, Pointer to offending driver name.
Arg4: 0000000000000000, Number of times "intercepted" bugcheck 0xEA was hit (see notes).
Debugging Details:
FAULTING_THREAD: fffffa8004aa1620
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xEA
PROCESS_NAME: System
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff88003af1f63 to fffff8000288bf00
STACK_TEXT:
fffff880`02e06578 fffff880`03af1f63 : 00000000`000000ea fffffa80`04aa1620 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff880`02e06580 fffff880`03af2112 : fffff880`02e06650 fffff880`042eba2b fffff880`02e06650 00000000`80000200 : dxgkrnl!TdrTimedOperationBugcheckOnTimeout+0x37
fffff880`02e065f0 fffff880`04102f72 : 00000000`00000000 fffff880`042eba10 fffff880`02e06770 00000000`01c9c380 : dxgkrnl!TdrTimedOperationDelay+0xbe
fffff880`02e06630 00000000`00000000 : fffff880`042eba10 fffff880`02e06770 00000000`01c9c380 00000000`01c90028 : atikmdag+0x2bf72
STACK_COMMAND: .thread 0xfffffa8004aa1620 ; kb
FOLLOWUP_IP:
dxgkrnl!TdrTimedOperationBugcheckOnTimeout+37
fffff880`03af1f63 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: dxgkrnl!TdrTimedOperationBugcheckOnTimeout+37
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dxgkrnl
IMAGE_NAME: dxgkrnl.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc590
FAILURE_BUCKET_ID: X64_0xEA_IMAGE_dxgkrnl.sys
Followup: MachineOwner
DRIVERS
start end module name
fffff800`00bc4000 fffff800`00bce000 kdcom kdcom.dll Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff800`0281a000 fffff800`02df7000 nt ntkrnlmp.exe Tue Jul 14 00:40:48 2009 (4A5BC600)
fffff800`02df7000 fffff800`02e40000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c43000 ks ks.sys Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`00c51000 fffff880`00c95000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`00c95000 fffff880`00ca9000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00ca9000 fffff880`00d07000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d07000 fffff880`00dc7000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`00dc7000 fffff880`00de8000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`00e00000 fffff880`00e1e000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`00e1e000 fffff880`00e4d000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`00e57000 fffff880`00efb000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00efb000 fffff880`00f0a000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00f0a000 fffff880`00f61000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`00f61000 fffff880`00f6a000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f6a000 fffff880`00f74000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00f74000 fffff880`00fa7000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fa7000 fffff880`00fb4000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00fb4000 fffff880`00fc9000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00fc9000 fffff880`00fd2000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fd2000 fffff880`00fde000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`00fde000 fffff880`00ff3000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`0105e000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`0105e000 fffff880`01083000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01083000 fffff880`0108c000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0108c000 fffff880`01097000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01097000 fffff880`010a8000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`010b0000 fffff880`0110c000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`0110c000 fffff880`01114000 intelide intelide.sys Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01114000 fffff880`01124000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01124000 fffff880`0113e000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0113e000 fffff880`01147000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01147000 fffff880`01171000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`01171000 fffff880`0117c000 msahci msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0117c000 fffff880`01187000 amdxata amdxata.sys Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`01187000 fffff880`011d3000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`011d3000 fffff880`011e7000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`011e7000 fffff880`011f4000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01200000 fffff880`0122a000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0122a000 fffff880`01233000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01236000 fffff880`013d9000 Ntfs Ntfs.sys Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`013d9000 fffff880`013f3000 ksecdd ksecdd.sys Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`013f3000 fffff880`013fc000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01400000 fffff880`0143a000 fvevol fvevol.sys Tue Jul 14 00:22:15 2009 (4A5BC1A7)
fffff880`0143a000 fffff880`01450000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01450000 fffff880`01480000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`014b8000 fffff880`014c1000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`014c5000 fffff880`01538000 cng cng.sys Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`01538000 fffff880`01549000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`01549000 fffff880`01553000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01553000 fffff880`0159f000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`0159f000 fffff880`015d9000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`015d9000 fffff880`015e0000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`015e0000 fffff880`015ee000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`015ee000 fffff880`015fe000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`01600000 fffff880`0162b000 ksecpkg ksecpkg.sys Tue Jul 14 00:50:34 2009 (4A5BC84A)
fffff880`0162b000 fffff880`01675000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`01675000 fffff880`01685000 vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`0168b000 fffff880`0177d000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`0177d000 fffff880`017dd000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`017dd000 fffff880`017e5000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`017e5000 fffff880`017f7000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`017f7000 fffff880`01800000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`01800000 fffff880`019fd000 tcpip tcpip.sys Tue Jul 14 00:25:34 2009 (4A5BC26E)
fffff880`02c00000 fffff880`02c12000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`02c19000 fffff880`02ca3000 afd afd.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`02ca3000 fffff880`02ce8000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`02ce8000 fffff880`02cf1000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02cf1000 fffff880`02d17000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`02d17000 fffff880`02d26000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02d26000 fffff880`02d41000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`02d41000 fffff880`02d55000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff880`02d55000 fffff880`02da6000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`02da6000 fffff880`02db2000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`02db2000 fffff880`02dbd000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`02dbd000 fffff880`02dcc000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`02dcc000 fffff880`02df0000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`02df0000 fffff880`02df9000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`03a00000 fffff880`03a1a000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03a1e000 fffff880`03aa1000 csc csc.sys Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`03aa1000 fffff880`03abf000 dfsc dfsc.sys Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`03abf000 fffff880`03ad0000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`03ad0000 fffff880`03ae6000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`03ae6000 fffff880`03aea500 CmBatt CmBatt.sys Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`03aeb000 fffff880`03bdf000 dxgkrnl dxgkrnl.sys Tue Jul 14 00:38:56 2009 (4A5BC590)
fffff880`03bdf000 fffff880`03bfa000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`03e26000 fffff880`03e82000 HdAudio HdAudio.sys Tue Jul 14 01:06:59 2009 (4A5BCC23)
fffff880`03e82000 fffff880`03ebf000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`03ebf000 fffff880`03ee1000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`03ee1000 fffff880`03ee6200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`03ee7000 fffff880`03ef5000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03ef5000 fffff880`03f01000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`03f01000 fffff880`03f0c000 dump_msahci dump_msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03f0c000 fffff880`03f1f000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`03f1f000 fffff880`03f2b000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`03f2b000 fffff880`03f39000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03f39000 fffff880`03f5c000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`03f5c000 fffff880`03f71000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03f71000 fffff880`03fc4000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03fc4000 fffff880`03fd7000 ndisuio ndisuio.sys Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`03fd7000 fffff880`03fef000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04000000 fffff880`04046000 dxgmms1 dxgmms1.sys Tue Jul 14 00:38:32 2009 (4A5BC578)
fffff880`04046000 fffff880`04053000 usbuhci usbuhci.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`04053000 fffff880`040a9000 USBPORT USBPORT.SYS Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`040a9000 fffff880`040ba000 usbehci usbehci.sys Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`040ba000 fffff880`040c6000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`040c6000 fffff880`040d1000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`040d7000 fffff880`045f9000 atikmdag atikmdag.sys Fri Apr 24 11:51:57 2009 (49F199CD)
fffff880`04600000 fffff880`0464d000 mrxsmb10 mrxsmb10.sys Tue Jul 14 00:24:08 2009 (4A5BC218)
fffff880`0464d000 fffff880`04670000 mrxsmb20 mrxsmb20.sys Tue Jul 14 00:24:05 2009 (4A5BC215)
fffff880`04670000 fffff880`04696000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`046a0000 fffff880`04768000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`04768000 fffff880`04786000 bowser bowser.sys Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff880`04786000 fffff880`0479e000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0479e000 fffff880`047ca000 mrxsmb mrxsmb.sys Tue Jul 14 00:23:59 2009 (4A5BC20F)
fffff880`04800000 fffff880`0481e000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0481e000 fffff880`0482d000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0482d000 fffff880`0483c000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0483c000 fffff880`0484c000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0484c000 fffff880`04862000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`04862000 fffff880`04886000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04886000 fffff880`04887480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0488e000 fffff880`04dc9000 netw5v64 netw5v64.sys Thu Mar 26 16:21:24 2009 (49CBAB84)
fffff880`04dc9000 fffff880`04dfb000 Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`04e1b000 fffff880`04e75000 usbhub usbhub.sys Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`04e75000 fffff880`04e8a000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`04e8a000 fffff880`04fc4000 SmSerl64 SmSerl64.sys Fri Sep 26 09:45:56 2008 (48DCA144)
fffff880`04fc4000 fffff880`04fd3000 modem modem.sys Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`05406000 fffff880`054ac000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`054ac000 fffff880`054b7000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`054b7000 fffff880`054e4000 srvnet srvnet.sys Tue Jul 14 00:24:58 2009 (4A5BC24A)
fffff880`054e4000 fffff880`054f6000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`054f6000 fffff880`0555f000 srv2 srv2.sys Tue Jul 14 00:25:02 2009 (4A5BC24E)
fffff880`0555f000 fffff880`055f7000 srv srv.sys Tue Jul 14 00:25:11 2009 (4A5BC257)
fffff960`00020000 fffff960`0032f000 win32k win32k.sys unavailable (00000000)
fffff960`005c0000 fffff960`005ca000 TSDDD TSDDD.dll unavailable (00000000)
fffff960`00740000 fffff960`00767000 cdd cdd.dll unavailable (00000000)
Unloaded modules:
fffff880`01480000 fffff880`0148e000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`0148e000 fffff880`0149a000 dump_pciidex
Checksum: 00000000
ImageSize: 0000C000
fffff880`0149a000 fffff880`014a5000 dump_msahci.
Checksum: 00000000
ImageSize: 0000B000
fffff880`014a5000 fffff880`014b8000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
You seriously need to do some updating, Your drivers are really old and could be causing the blue screens, start by updating graphics drivers then, sound drivers, lan drivers, wireless sound bios etc, include all service packs too
Remove anti virus and replace with Microsoft security essentials,
Thanks
but I cant run windows to install drivers, it comes to windows logo splash screen and crashes, it only works in safe mode, everything worked fine until today without any problems for about a year.
Elmer
Can you run Safe Mode with Networking? You'll at least get to the internet. Alternatively, locate the drivers for your machine on another PC and stick them on a USB, Transfer them over that way.
Thanks,
I have drivers on laptop hard disk, but ATI install manager says " Failed to load detection driver" when i try to install from safe mod.
maybe this is important, I have to connect desktop screen, laptop's screen doesnt work for some reason.
Is it possible that something is wrong with BIOS, after fresh windows installation same thing happens or its a hardware problem.
